1/72 HMS Brave Borderer
1 hour ago, gunzo said:
Could this 'panelling' be an anti slip application- grip paint, linoleum, grid plate, metal/wood stripĀ  or whatever?
I've been unable to find any information regarding the Braves' decks. Ā However,Ā my guess would be there was some sort of anti-slip coating on the deck, giving the 'panel' look, or at least covering the larger panels.
Ā
John Ā Ā
I just finished painting the main deck. Ā You'd think airbrushing the deck would be a simple process, since it's relatively flat, it's primed, & it's masked. Ā Wrong!!!!!!!!!!!!!
Ā
I ran into a couple of issues. Ā I've spent the last week painting, repairing, & repainting the deck.Ā Ā First, we've had a heat wave over the past 20 days with high humidity levels feeling like 40Ā°C+. Ā Even though our house is air conditioned, the heat & high humidity are causing havoc with my air brush. Ā Rather than having a nice smooth paint coat, the paint ends up drying too quickly, resulting in a rough stipple finish. Ā The good news here is that I think that BB's deck had an anti-slip coating, so unknowingly & unplanned I now have an anti-slip deck, too.Ā :yes:Ā Ā My second problem had to do with masking tape. Ā Brave Borderer has a border running around the outside of the toe rail, painted the same colour as the sides of the hull. Ā I decided I would paint the border before painting the deck. Ā So, I sprayed the border, waited a couple of days for it to dry, then masked it off & painted the deck. Ā Tamiya tape is my masking tape of choice, however this time I tried Testors flexible thin line masking tape. Ā Because the Testors tape is flexible, it was really easy to mask off the border around the curved edge around deck. Ā Once I painted the deck & let it dry for a day or so, I removed the Testors tape. Ā Much to my surprise, I found there were a number of small spots where the Testors tape lifted the border'sĀ paint coat & some masked lines were very uneven. Ā The Testors tape is supposed to have low stretch & low tack to prevent paint lifting & for ease of removal.Ā :(Ā Ā I've very seldom have had this problem with the Tamiya tape. Ā The lifting may have been caused by the heat & high humidity, but I'm blaming the tape.:angrysoapbox.sml:Ā
I ended up sanding the spots where the paint lifted,Ā masking with Tamiya tape, & re-painting. Ā No lifting problems this time.
Ā
Here's a photo of the finished deck area showing how the deck panels look. Ā I had to play around with the lighting so the deck panels would show up. Ā As a result, the deck colour looks different in the photo than what it actually is.
Ā
Ā
Finally, the hull is ready for the hull & draught number decals.
Ā
I've taken the following teaser photos showing the model with the superstructures & raised decks dry fitted.
Ā
Ā
Ā
Next up, I'll start applying the inkjet printed hull decals (seeĀ post #102 re: decals).
Ā
Thanks for looking in.
Ā
Stay safe!
Ā
John
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Edited by JohnWS
  • Like 15
Looking great there John even with the paint problem I always use Tamiya tapes always gives me a clean line not used the Testors before so will just stick with the Tamiya canā€™t wait to see the rest going onĀ šŸ‘
Ā
Stay SafeĀ
beefyĀ
Good to see you've got around your problems....
Ā
When I need to follow tight curves I lay down a strip of Tamiya tape on glass on cutting mat and cut thin strips.
Seems to work for meĀ
Ā
BB is looking rather sexyĀ
Ā
Stay safe
Ā
Kev
Works for me too. Ā That is my normal way of masking curves, but when I saw the Testors tape it looked like an option to save having to cut the thin strips. Ā Just goes to show that if it's not broken, there's no need to fix it.Ā Ā :doh:Ā You'd think I would have learned that by now.Ā :clif:
Edited by JohnWS
  • Haha 3
Another couple of milestones completed - propellers, rudders, & hull decals have been added.Ā :yahoo:
Ā
FirstĀ I've glued the propellers & rudders in place to minimize the manhandling of the hull after the decals are applied. Ā The propellers, propeller shafts, & two of the three rudders are taken from the Perkasa model kit. Ā The third rudder was scratch built to match.
Ā
Ā
Next, I've applied the home made hull number & draught mark decals to the hull sides. Ā The decals turned out pretty good for being printed on my inkjet printer. Ā I sealed the decals with matt clear lacquer so they would blend in with the hull paint finish.
Ā
Here's a photo of the hull with the decals applied;
Ā
Ā
... and a photo with the superstructures dry fit in place, andĀ comparison photos of Brave Borderer;
Ā
Ā
Next up, start making the deck equipment & accessories.
Ā
Thanks for looking in & following along.
Ā
Stay safe!
Ā
John
Ā
Ā
Ā
Ā
  • Like 18
Those decals look great John I would have said that you had painted them very neat work which papers are you using for themĀ šŸ¤”
Ā
Stay SafeĀ
beefyĀ
The master class continues!Ā :worthy:
Ā
With the masterful job done on the deck panels, you couldĀ have left others to assume you brought those same madĀ skills to bear onĀ the anti-slip coating. :whistle:
3 hours ago, beefy66 said:
Those decals look great John I would have said that you had painted them very neat work which papers are you using for themĀ šŸ¤”Ā ...
Thanks beefy.
Ā
I usedĀ Testors decal paperĀ - clear paper for the black numbers & white paper for the white numbers (printing a black background and leaving the number white). Ā The clear paper decal film is really thin & blends very well. Ā The white paper decal paper is a little thicker. Ā In certain lighting conditions the cut edges of the thicker white paper can be seen when looking close up. Ā The secret is to not look at these decals too closely.Ā :rofl:
Ā
Here's a close up photo showing light reflecting off theĀ edges of a white paper decal against the black hull paint.Ā
Ā
John
Ā
  • Like 11
Thank you!
Ā
... you couldĀ have left others to assume you brought those same madĀ skills to bear onĀ the anti-slip coating. :whistle:
Skills... that's it! Ā Years & years developing the anti-slip technique. Ā I like it!
Ā
Ā Shhh, but don't tell anyone it was the result of years & years of screw ups. Ā lolĀ :laugh:
Ā
John
Edited by JohnWS
  • Haha 5
Great work so far... A keen eye to detail, but that's something we knew allready.
Ā
Ā
Something I couldn't help noticing, but here you see 3 protrusions/plates underneath the windshield, breaking up that flat surface. It's also visible in other pictures.Ā
Thanks Silenoz!
Ā
My early photos show this area below the windscreen flat. Ā At some pointĀ in Brave Borderer's career she hadĀ a nameplate with the words P1011 Brave Borderer added below the windscreen. Ā Then later photos show the nameplate has been removed with only what looks like the mounting hardware/holes remaining. Ā Could this be what you're seeing?
Ā
John
Edited by JohnWS
I don't know that much about the ship, but in the shown pictures:
Ā
Ā
These are clearly visible.
Ā
Ā
Here it looks like some hooks only (maybe for a tarp when moored) there's something breaking up the large flat surface underneath the windshield.
