Lockheed Hudson
NigelC
It is a bit of a challenge. You need a shim in front of the windscreen to widen the fuselage and you need to trim the navigators table. Engines are a tricky fit as is the wing to fuselage joint. Most of the nice interior is invisible and although the door and dinghy stowage is separate, the door is moulded closed and needs to be drilled out if you use it. Strongly reccomends getting the Eduard masks as the turret and nose are pigs to mask.
Mine narrowly avoided a flight in to the bin...
20170905_151230
  • 1 month later...
