Rigging Practice
Just wanted something quick and easy to try out rigging using EZ Line so picked up a new e.iii from Hobbycraft for £7. I wasn't bothered about the colour scheme as I was concentrating on the rigging so kept it as per the cad rendering on the side of the box.
  • Like 17
Looks great to me, possibly a little on the thick side but certainly neatly done. I found that by agitating the end of the line (rolling it between finger and thumb) I got it to fray, thereby allowing me to split the line lengthways. Using this thinner line meant I could achieve finer rigging without having to stretch it further.
Did you drill holes or just stick the end of the line to the wing surface?
Drilled the wing holes to allow me to do it in 2 runs, both starting and finishing at the undercarriage, everything that went from the fuselage was just stuck to the surface. I'll have to give splitting it a go
The dark colour of the thread may make it look „thicker“ than it actually is. Painting it in a lighter colour ( eg with a felt pen) should help to tone down the effect.
Another option is invisible sewing thread, comes in different shades and can easily be straightened with a gentle heat source such as a heated screwdriver or a soldering iron on „low“.
Interesting low visibility scheme for WWI plane ;)
Nice job on riging. The EZ is really very helpful to do proper riging. I think the 0.4 mm is optimal drill regarding effect/effort...Have you any problems with 0.3 mm holes?
Regards
J-W
