Challenger350Pilot
Eastern Express DC-10-30 Released!
Eastern Express has released the DC-10-30!
Wonder of it could be modified using an EE MD-11, sanding and remolding the tail section, to make a DC-10-40?? Anyone willing to try???
1/144Here are sprue pics.....
30558c5b88fcc268f159e20c9b2509ad b2e208f7675d2a71aa02d3b5f7de3740 14274bbd886ec57e2fefe7313a592571 87dd537b2fdae6ae8ffa9387e86b3f88 3684653e1e5844d4fb715abc50fa18e1 d571a26617ddc68e51bd6c1d68f60014 16a9ee7ad20692a96b96e0182c668b6f
Interesting.
It looks like it has a conventional wing to fuselage joint rather than the nonsensical fitting on the MD-11. After a bad and expensive experience with that kit I won't be parting with any money until I read an actual build report on the DC-10 rather than the "Oooh look how pretty it is in the box" stuff which tends to greet anything from Eastern Express these days.
With @Skodadriver's caveat ringing loud, I'll give it a conditional "Yes please, there is a Air NZ one lurking in those sprues, hopefully," :)
Steve.
Steve.
Hi Steve,
Unfortunately as far as I know all the ANZ airframes were the earlier model with the different wing body fairing.
AA do the early model DC10 though!
Ian
Ok, more research required on my part, I thought all the Air NZ aircraft were -30s & assumued they would all be the same, the AA kits are a little out of my price range. :(
Steve.
Having had a furkle around on Airliners.net & comparing Air NZ aircraft with  BCal & Lufthansa ones which feature on the liverys for the EE kit I can see no differences but then again, I'm not sure what I'm looking for, These are some of the images I compared.
ZK-NZT, ZK-NZS, ZK-NZP D-ADMO, D-ADBO, D-ADFO, G-BNDH I tried to find photos that showed fore & aft wing fairings & I'm not seeing any glaring differences but stand to be corrected/guided in this.
Steve.
DC-10s, and in particular DC-10-30s are a minefield of modifications.  McDonnell Douglas created an ongoing series of performance improvement packages which could be applied to earlier build aircraft in addition to being fitted to new ones on the assembly line.  Most airlines bought them. The EE kit represents basically the latest version of the Performance Improvement Package with the large forward wing/body fairing at the leading edge of the wing root, the longer aft fairing (common to all -30s), the small fillet at the base of the vertical fin, the horizontal stabilizer root leading edge fairings, and the larger horizontal stabilizer fuselage fairings.
This article is a must-have if you’re interested in doing an accurate DC-10 model:
https://www.airlinercafe.com/page.php?id=392
Edited by Jordi
Right, I'm seeing from there that the Air NZ DC-10s did not have the forward wing root fairing, I haven't checked for the rear stab fairings etc yet but its starting to look like a fair bit of work. Doable? :unsure:
Steve.
5 hours ago, stevehnz said:
Doable?
Hi Steve,
Yes I'd say it is doable as basically all you'll have to do is sand off the forward part of the fuselage fairings for both the wings and tailplanes and reshape them and remove the wing/tail/tailplane fillets.
Good luck!
Ian
1 hour ago, Turbofan said:
Hi Steve,
Good luck!
Ian
Thanks Ian, cheered me up heaps hearing that. :)
Steve.
