Had a thought pop into my head at work the other day, black nitrile rubber dust from sanding down cores to moulds could possibly become tarmac?
20190529_181243
It's a black squishy powder that can be manipulated and sort of sculpted. It's already been vulcanised.
20190529_181258
Rolled out flat onto a board
20190529_181613
Smeared with pva and black paint
20190529_215119
The surface doesn't look to bad, like a cracked hastily built and now neglected airstrip. Have to tone down the white.
20190529_213530
Popped the gloster meteor on there just to see how it looks
Don't know if to persue this further. Build some ground crew etc. It was just a test really to see if the nitrile rubber dust worked. I think I could have smoothed it out a bit better and not so cracked. Although the road outside my house looks worse than this.
Well, as you say, I've seen roads that look worse than that! It does look like tarmac, but I think it would suit larger scales of 1/35th upwards. If you could get much finer dust and scatter that over PVA or wet plaster, that might be better for the smaller scales.
Rearguards,
Badder
Ideal to depict a UK road at this moment in time 😀
Maybe lay some waxed paper over it and try to roll it out flat?
Colour and texture look interesting...
I think next time I'll warm it up a little, and not squish it out on the shed work bench, which has sawdust and bits of tobacco on it 😕
As fine sandpaper painted usually passes for tarmac, I wonder if You could press it under some coarse sandpaper to get that textured effect? Or would it just stick to the sandpaper?
Tile grout also makes good tarmac and concrete.
