Ran Posted May 31, 2019 Share Posted May 31, 2019 (edited) With the Typhoon finally done its time to pick the next build. I recently listed my entire stash (who's size is a well kept secret) to ScaleMates .One of the nice things about that is I now have some statistics. It turns out the most popular kit in my stash is ..... Spitfire - 9 kits of different models. I looked up my work room stash and noticed a pair of Spitfires - a Fujimi one and an ICM. A double-build came to mind but when I open the kits and cleaned them up it became very clear that these are way too different to allow that. The Fujimi is a 80' era, ~20 so parts, very crude and simple and rumor has it it's not even 1/48. The ICM on the other parts has probably the most detailed 1/48 spitfire out there with lots of parts and options. So, it won't be a double-build but I will try to start them together and see how it goes. You can follow up on the ICM build here. The Fujumi is VERY simple: Edited May 31, 2019 by Ran Link to comment Share on other sites More sharing options...
Ran Posted July 13, 2019 Author Share Posted July 13, 2019 You know how it is - building beats writing every time. At least for me. I'be been doing some building but was not able to bring myself to sit down and write. So here goes. This is a very basic kit - to say the least. It's also adorned with flash, ill-placed gates and very soft plastic. I did spend some time painting the pilot figure - which I will put this time (first) as the cockpit is just .... when - empty. I did add some scratch behind the "cockpit" bulkhead - as it can be seen even through the close canopy The cockpit is not wide enough to sit tight in the fuselage - resulting in a very low stance - or a very very short pilot: Dealing with the various seems was not that easy as the soft plastic makes the allignment of parts a problem. This time I opted to use liquid mask instead of masking tape for the canopy - mainly due to its small size and Very pronounced frame. Pre shading: I then moved my attention to the exhaust stacks. I'm working on these together with the stacks of the other spitfire I'm building. Drilling: Base painting with Silver/Aluminum: The pinkish hue is just due to lighting. Following a heavy brown wash of oil paint. Still not happy with that. I could also use help with how to drill these pesky small stacks. Till next time Ran Link to comment Share on other sites More sharing options...
Ran Posted November 2, 2019 Author Share Posted November 2, 2019 This build has been waiting for the other Spit to progress - for a long time. I suffered from PTS-AMS following building and detailing the other spit's engine. But finally - both kits were ready for primer - and there I hit a problem - you can read about it here. Next it was time for the camouflage. I was low on MOJO so decided to skip the masking. I drew, with a white pencil, the lines and when on with free airbrushing the paints. Before painting I did the yellow/red strips at the leading edge of the wing. For the camo was using the following: - Underside: Pollyscale Light Blue F505396 (an old bottle I have) - Gray: Tamiya Ocean Gray 2 (RAF) XF-82 - Green: Tamiya Dark Green 2 (RAF) This was followed by Gloss Klear, Decals and then some more Klear. Decals performed OK - I like the green strip and a/c code. The bunch of stencils came as a single large decal you had to cut and also had white background which made them useless - I skipped them. That's it for today. Comments are welcomed as always. 3 Link to comment Share on other sites More sharing options...
bigbadbadge Posted November 9, 2019 Share Posted November 9, 2019 Wow you have done well with this kit, the hard work you have put in has paid dividends as this and the other one look great. Keep up the good work All the best Chris Link to comment Share on other sites More sharing options...
Ran Posted November 19, 2019 Author Share Posted November 19, 2019 Kit got layers of some Clear Gloss, panel line washes, some Klear cote flat, and some filters. Small items installed and we are ready for "Ready for inspection". Some pictures just before that. That's it. Comments are welcomed. Ran Link to comment Share on other sites More sharing options...
Ran Posted December 2, 2019 Author Share Posted December 2, 2019 Ready for inspections photos can be found at: Link to comment Share on other sites More sharing options...
