Dave_R Posted May 30, 2019 Share Posted May 30, 2019 Hi All, For starters I'm going to build the Eduard Fw 190. According to the info the aircraft below was flown by Feldwebel Alfred Bindseil who went MIA on June 20th near St. Lo after an engagement with Spitfires. All being well I'm planning on building several more D-Days kits. Dave. 8 Link to comment Share on other sites More sharing options...
Robert Stuart Posted May 30, 2019 Share Posted May 30, 2019 Looks like a good choice Dave. Link to comment Share on other sites More sharing options...
PlaStix Posted June 4, 2019 Share Posted June 4, 2019 Hi Dave. I really like the Fw190s and Eduard's kit looks like it should build into a really nice version! Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
trickyrich Posted June 5, 2019 Share Posted June 5, 2019 good to see, gotta keep those pesky Spitfires under control! 1 Link to comment Share on other sites More sharing options...
Dave_R Posted June 13, 2019 Author Share Posted June 13, 2019 Hi All, I've got the fuselage halves together. There's a lot pieces to the engine assembly. This kit has clearly been designed to be built with all the panels open. Unfortunately I prefer to have everything buttoned up so it's going to be a pain to get all the panels fitting. Dave. 4 Link to comment Share on other sites More sharing options...
Robert Stuart Posted June 13, 2019 Share Posted June 13, 2019 That looks like good progress Dave. 6 minutes ago, Dave_R said: This kit has clearly been designed to be built with all the panels open. Unfortunately I prefer to have everything buttoned up so it's going to be a pain to get all the panels fitting. Can you leave some stuff off to get her buttoned up? 1 Link to comment Share on other sites More sharing options...
Dave_R Posted June 13, 2019 Author Share Posted June 13, 2019 Just now, Robert Stuart said: That looks like good progress Dave. Can you leave some stuff off to get her buttoned up? I think I'm going to file down the MGs a bit, but you need the whole engine in place for the exhausts and prop to be fitted. Dave. 2 Link to comment Share on other sites More sharing options...
Valkyrie Posted June 13, 2019 Share Posted June 13, 2019 I’ve got this stalled at the engine point too, my first 1/48 build, I thought bigger would be easier...nope, it’s taken me 8 weekends on the built for the engine! I hope you figure it out so I can follow how to do it. I’ve got the cowling ring built completed and on with a big space for the engine and the guns have still be say back on...I was just going to support the engine and push through the exhaust stacks later. Nice build, it looks good so far.. Link to comment Share on other sites More sharing options...
Dave_R Posted June 14, 2019 Author Share Posted June 14, 2019 20 hours ago, Valkyrie said: I’ve got this stalled at the engine point too, my first 1/48 build, I thought bigger would be easier...nope, it’s taken me 8 weekends on the built for the engine! I hope you figure it out so I can follow how to do it. I’ve got the cowling ring built completed and on with a big space for the engine and the guns have still be say back on...I was just going to support the engine and push through the exhaust stacks later. Nice build, it looks good so far.. I got the engine on OK - in the end. I followed the construction sequence exactly as per the instructions. The first tricky step is putting on the exhausts, very fiddly - but doable. It took me ages to do, constantly dropping the damn things and having them fall off again and again. Much patience required. The next tricky bit is attaching the engine to the fuselage. Again frustrating but possible. The only tip I can give is to follow the instructions in sequence. I don't think adding the exhaust later would work at all. 4 1 Link to comment Share on other sites More sharing options...
PlaStix Posted June 17, 2019 Share Posted June 17, 2019 Fantastic progress (and patience) Dave! Looking very good. Kind regards, Stix Link to comment Share on other sites More sharing options...
Dave_R Posted June 18, 2019 Author Share Posted June 18, 2019 Hi All, And all that engine stuff disappears... ...and it's ready for primer. Dave. 2 Link to comment Share on other sites More sharing options...
Robert Stuart Posted June 18, 2019 Share Posted June 18, 2019 But ... you know that the engine is there Good progress Dave, I like what I see so far. Link to comment Share on other sites More sharing options...
Dave_R Posted June 20, 2019 Author Share Posted June 20, 2019 Hi All, Primed and ready for paint. The painting might be a bit tricky with all that overspray and mottling. It might take a few goes to get it rightish. Dave. 3 Link to comment Share on other sites More sharing options...
Robert Stuart Posted June 20, 2019 Share Posted June 20, 2019 6 minutes ago, Dave_R said: Primed and ready for paint. {snip} The painting might be a bit tricky with all that overspray and mottling. It might take a few goes to get it rightish. Good to see it primed Dave, good luck with that mottling Link to comment Share on other sites More sharing options...
Dave_R Posted August 1, 2019 Author Share Posted August 1, 2019 Hi All I've made a bit more progress. The U/C and the Licht Blau are on. ...and I've done a little panel lining on the right wing. The RLM74/75 camo, and mottling are going to test my feeble airbrushing skills - so a lot of patience and crossed fingers are going to be required next step. Dave. 2 Link to comment Share on other sites More sharing options...
Parabat Posted August 1, 2019 Share Posted August 1, 2019 Looking good! With those simple colours on, you can see what a fantastic shape the Fw190 has. Best fighter of WW2. Keep up the good work! Link to comment Share on other sites More sharing options...
Dave_R Posted August 6, 2019 Author Share Posted August 6, 2019 Hi All, The camo painting is done. The next job will be the red band on the fuselage and the yellow panel under the nose. Dave. 4 Link to comment Share on other sites More sharing options...
Valkyrie Posted August 7, 2019 Share Posted August 7, 2019 You’ve really done well with that camouflage scheme. I found it quite tough to follow but looks bang on. You will know this but I wished id noticed the yellow bar is the length of the red tail band, I just guessed. Good work Link to comment Share on other sites More sharing options...
Dave_R Posted August 17, 2019 Author Share Posted August 17, 2019 Hi All, The yellow panel and red band are done and ready for some decals. Dave. 6 Link to comment Share on other sites More sharing options...
Lawzer Posted August 19, 2019 Share Posted August 19, 2019 looking good! 👍 Link to comment Share on other sites More sharing options...
Dave_R Posted August 21, 2019 Author Share Posted August 21, 2019 Hi All, All the decals are on. Matt Coat, weathering and breaky off bits to do and it's nearly done. Dave. 5 Link to comment Share on other sites More sharing options...
