FL200 Posted May 14, 2021 Share Posted May 14, 2021 Sorry to hijack this thread, but I would like a 1/72 model of the 2x Howard 500s that I have flown. If anyone has had success of making a reasonable model of this aircraft I would be pleased to hear about what kits they used and what was needed to convert them? Any photos of the finished model would also be good to see. thanks, Jon. Link to comment Share on other sites More sharing options...
rob Lyttle Posted May 14, 2021 Share Posted May 14, 2021 Hi Jon @FL200 I hope you have success with the project. It's not an easy thing to do. Have you got photo references for the planes? Here's what I have to offer...... I've done the Academy PV1 Ventura in 1.72 and civilianised it in a what if way.. Scratch built windows and door (port side) and the bulge under the back end is still there. Also done the MPM Lodestar in 1.72 which is a better shape, but the engines + nacelles etc are all wrong for the Howard. So I'm wondering...... And this is just off the top of my head...... about the possibility of bashing the 2 kits, Lodestar fuselage married to the Ventura wings with the P&W Double Wasps and Bay doors. There could be some heavy going with kits from 2 different manufacturers. Howard basically made a whole other fuselage, and I'm wondering if the Lodestar fuselage would get you started on the right track. I've never really got a handle on what the differences are with the Howard. Longer nose? Window count? Panoramic windows? I think they did away with the wing trailing edge extension pieces that make the dogleg shape along the wing shape. Any photos and references you have of the aircraft in question might help you decide what is going to be required. That's the best I can come up with 👍 1 Link to comment Share on other sites More sharing options...
FL200 Posted May 14, 2021 Share Posted May 14, 2021 (edited) The 2 aircraft are N500LN and N500HP. There are plenty of photos on Google of both of them showing the aircraft shape and configuration. I wonder if anyone has considered converting a Flight Sim 3D model into a 3D printable model? Edited May 15, 2021 by FL200 Error in aircraft registration 1 Link to comment Share on other sites More sharing options...
rob Lyttle Posted May 14, 2021 Share Posted May 14, 2021 21 minutes ago, FL200 said: I wonder if anyone has considered converting a Flight Sim 3D model into a 3D printable model? That is all way out of my zone but there is more activity all the time with this kind of model developing. I have a feeling that BM has set up a 3D print area on here somewhere. Might be worth chatting to the "boffins". I looked through some of the online info on 500LN. If you want to stay in 1.72 scale the Academy PV1 will get you to the starting line. The dorsal gunners bulge needs to be faired, Windows and door, 4 blade props,, bomb bay door joints, and the flaps /trailing edges looks like they are modified a bit. But the shape is there including the tail extension out behind the tailplanes. But a good dedicated 3D print fuselage would be very nice! 👍😎 Link to comment Share on other sites More sharing options...
wallyinoz Posted May 15, 2021 Share Posted May 15, 2021 After seeing and drooling over the Howard at Oshkosh,I too wanted a model, when Home Bargains was selling the Revell Ventura kits for what seemed like pennies a few years back I bought one and took it back home to Perth to start the conversion, gathering as many references as I could I found such a conversion was beyond my modelling skill level.. I'll have a look to see if I kept the references to assist anyone, but am not hopeful Link to comment Share on other sites More sharing options...
Space Ranger Posted May 15, 2021 Share Posted May 15, 2021 I found drawings, but none agreed with each other. Some were for a flying model, and none agreed with photographs. Link to comment Share on other sites More sharing options...
72modeler Posted May 18, 2021 Author Share Posted May 18, 2021 These might have been posted before, but I found these Howard 500 photos- mighty handsome oil burner! Mike 2003 photo: https://www.airliners.net/photo/Untitled/Lockheed-Howard-500-L-237/331964/L?qsp=eJwljTsOgzAQRK%2BCpqYgikhBl0%2BRLhS5wMpeAQrJWuuViIW4e4zTPb0Zzaxw8jH%2B2jMFRofIpG5EjUBK74huxYvTIuoz48Zc3WUh9VXbNHtrFJMrGQ%2BiCV1bI4raJSN8tmfnOBh7/P1DPesecXTlYsiXhwysfWEcT9n7KYaZygYbTTO27Qd4hTcq same airplane, same date: https://www.airliners.net/photo/Untitled/Lockheed-Howard-500-L-237/331962/L?qsp=eJwljTsOgzAQRK%2BCpqYgikhBl0%2BRLhS5wMpeAQrJWuuViIW4e4zTPb0Zzaxw8jH%2B2jMFRofIpG5EjUBK74huxYvTIuoz48Zc3WUh9VXbNHtrFJMrGQ%2BiCV1bI4raJSN8tmfnOBh7/P1DPesecXTlYsiXhwysfWEcT9n7KYaZygYbTTO27Qd4hTcq 2001 photo: https://www.airliners.net/photo/Untitled/Lockheed-Howard-500-L-237/144921/L?qsp=eJwljTsOgzAQRK%2BCpqYgikhBl0%2BRLhS5wMpeAQrJWuuViIW4e4zTPb0Zzaxw8jH%2B2jMFRofIpG5EjUBK74huxYvTIuoz48Zc3WUh9VXbNHtrFJMrGQ%2BiCV1bI4raJSN8tmfnOBh7/P1DPesecXTlYsiXhwysfWEcT9n7KYaZygYbTTO27Qd4hTcq Link to comment Share on other sites More sharing options...
