magpie1832 Posted May 25, 2019 Share Posted May 25, 2019 Hi all, Having started a FW190 but had many ships sat waiting and I was itching to build another so the plane has taken a back seat. I'm build this with the Eduard Big Ed set and wooden decks. The paint scheme Will be the disruptive colours. Only thing is the ship is being built as 1945 refit. So paint won't match the year, I'm not after too much accuracy but a nice looking model to display at home. This is my first Tamiya kit so hopefully it will be a good one. I started by drilling the portholes out then cleaning the decks up. Chris 8 Link to comment Share on other sites More sharing options...
magpie1832 Posted May 26, 2019 Author Share Posted May 26, 2019 I have now installed the decks and cleaned up the joints around the edge of the decks. I have started adding the PE lockers parts too. Chris 8 Link to comment Share on other sites More sharing options...
magpie1832 Posted May 27, 2019 Author Share Posted May 27, 2019 Hi guys, I've now finished with the locker tops and the front wave breaker slowly getting there. Chris 8 Link to comment Share on other sites More sharing options...
magpie1832 Posted June 11, 2019 Author Share Posted June 11, 2019 Hi guys, here is a quick update. I've now painted the hull in the camo scheme and started on the deck structures. Chris 15 Link to comment Share on other sites More sharing options...
Courageous Posted June 11, 2019 Share Posted June 11, 2019 Looking pretty neat, smart scheme. What are the square holes for? Stuart 1 Link to comment Share on other sites More sharing options...
Modelholic Posted June 12, 2019 Share Posted June 12, 2019 I'd imagine they're for ladders. 1 Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted June 12, 2019 Share Posted June 12, 2019 Hi Chris, The second lightest tone on KGV was MS4. https://www.iwm.org.uk/collections/item/object/205188330 1 Link to comment Share on other sites More sharing options...
magpie1832 Posted July 11, 2019 Author Share Posted July 11, 2019 Hi Guys , here is the latest batch of pics. Iv'e started with the railings and they are fiddly. Chris 18 Link to comment Share on other sites More sharing options...
rom1 Posted July 24, 2019 Share Posted July 24, 2019 very nice work! 1 Link to comment Share on other sites More sharing options...
Ripaman Posted July 24, 2019 Share Posted July 24, 2019 Looking good Chris, Regards Richard 1 Link to comment Share on other sites More sharing options...
Kev The Modeller Posted July 25, 2019 Share Posted July 25, 2019 Superb work, I'm following along with interest 1 Link to comment Share on other sites More sharing options...
Courageous Posted July 26, 2019 Share Posted July 26, 2019 As others have said, great work. I really the the step-by-step assembly builds, very informative. Stuart 1 Link to comment Share on other sites More sharing options...
magpie1832 Posted August 6, 2019 Author Share Posted August 6, 2019 Thanks for the nice comments guys. Been busy doing minuscule work. I've been adding more etch and generally building up the towers. Had no major faults or parts missing. The Eduard instructions are very good but you do need to go between the them and then tamiya ones many times over and over to make sure you get them right. Chris 11 Link to comment Share on other sites More sharing options...
magpie1832 Posted August 11, 2019 Author Share Posted August 11, 2019 (edited) Thanks for looking in. Here are the latest picture from this weekend. This camo pattern is tricky to keep it wrapping around correctly. Chris Edited August 11, 2019 by magpie1832 15 Link to comment Share on other sites More sharing options...
magpie1832 Posted June 12, 2020 Author Share Posted June 12, 2020 I have been away for a while moving home etc, and have started back at it. I have got this for over last few weeks. I have the tops of the funnels to do then onto the weaponry or the life boats which have many PE parts. Here are the pics. Chris[/size] 12 Link to comment Share on other sites More sharing options...
Gisbod Posted June 13, 2020 Share Posted June 13, 2020 Good job on the camo Chris, Have you airbrushed the superstructures or brushed? Guy 1 Link to comment Share on other sites More sharing options...
robgizlu Posted June 13, 2020 Share Posted June 13, 2020 Nice progress - good to see this back on line and really nice paintingI I wondered the same as Guy? Rob 1 Link to comment Share on other sites More sharing options...
beefy66 Posted June 13, 2020 Share Posted June 13, 2020 Great start back at it beefy 1 Link to comment Share on other sites More sharing options...
magpie1832 Posted June 14, 2020 Author Share Posted June 14, 2020 (edited) Thank you all for the nice comments. The structure is airbrushed first in grey then mostly hand painted camo but the hull and major parts are Completely masked and airbrushed. I have done the tops for the funnels and now started the weapons. First had problems with the PE. I shaved off the plastic to make the discs and got the PE part. Wrapped it around and it was short. So i attempted to file them down but failed. So Got some 3mm dowel and made 1mm discs to do them. I am pleased with the result of these considering the size. Glued fingers and parts and tooth pick to everything in the process. Chris Edited June 14, 2020 by magpie1832 5 Link to comment Share on other sites More sharing options...
OutcastJoel Posted June 15, 2020 Share Posted June 15, 2020 Wow, this is stunning! Are those buttons the Oerlikon tubs? I have just trawled through the the whole thread and have to say you are making me want to build this kit! I don't really have the space for it so I shall resist but you have made it pretty hard. 1 Link to comment Share on other sites More sharing options...
magpie1832 Posted June 15, 2020 Author Share Posted June 15, 2020 Hi OutcastJoel. Yes it is the Oerlikon tubs. Very small and fiddly. Its not to big, I have Trumpy 1/350 USS Nimitz, USS Kitty Hawk and 1/200 USS Iowa to do. Now they're big lol. Here they are al painted and fitted, also made a start on the Turrets. Number 1 is ready for paint. Chris 2 Link to comment Share on other sites More sharing options...
magpie1832 Posted June 16, 2020 Author Share Posted June 16, 2020 (edited) Morning all. I have now finished the PE on the other turrets and primed ready for the main colours. Then get them fitted. Chris Edited June 16, 2020 by magpie1832 4 Link to comment Share on other sites More sharing options...
Jasper dog Posted June 16, 2020 Share Posted June 16, 2020 Having never built a boat your build is tempting me to have a go... Great work, the photo etch and wood enchantments really lift this kit. Following with interest. Atb Darryl 1 1 Link to comment Share on other sites More sharing options...
magpie1832 Posted June 16, 2020 Author Share Posted June 16, 2020 Cheers for looking in. Ships are quite the same as Planes just lots more fiddly bits. I couldn't do a 1/72 aircraft as to small for my eyes lol All painted and drilled out the barrels. Just weathering then fitting properly. Chris 7 Link to comment Share on other sites More sharing options...
FlyingSpanner Posted June 16, 2020 Share Posted June 16, 2020 Stunning work! Paintwork is looking great 👍 4 hours ago, magpie1832 said: These turret photos are so clean they look like Shapeways CAD renders 1 1 Link to comment Share on other sites More sharing options...
