Alyward Posted May 24, 2019 Share Posted May 24, 2019 Hey, Im wanting to start a 1/72 Hasegawa Kfir c2 and Iam needing help with paint colours for the two blues (mixes of 2-3 colours). Im fairly new and would prefer to stay away from mixing colours right now. so any suggestions or colour recommendations in enamel would be great for the Light blue (Gunze H307 60% + H323 20% + H316 20%) and dark blue (Gunze H307 80% + H323 20%). Thanks Link to comment Share on other sites More sharing options...
Giorgio N Posted May 24, 2019 Share Posted May 24, 2019 Hasegawa made a mistake in their instructions and for some reason believed that the two-grey Kfirs used some kind of blue. The actual colour scheme used two blue-greys, FS 36320 and 36375. So the greys to use are just Gunze 307 for the darker colour and Gunze 308 for the lighter, without having to mix paints. Most modeling paint ranges have these two colour, what are your favourite brands ? Link to comment Share on other sites More sharing options...
Alyward Posted May 24, 2019 Author Share Posted May 24, 2019 7 hours ago, Giorgio N said: Hasegawa made a mistake in their instructions and for some reason believed that the two-grey Kfirs used some kind of blue. The actual colour scheme used two blue-greys, FS 36320 and 36375. So the greys to use are just Gunze 307 for the darker colour and Gunze 308 for the lighter, without having to mix paints. Most modeling paint ranges have these two colour, what are your favourite brands ? Thanks for the reply. I use Humbrol or model master. Link to comment Share on other sites More sharing options...
Giorgio N Posted May 24, 2019 Share Posted May 24, 2019 1 hour ago, Alyward said: Thanks for the reply. I use Humbrol or model master. Model Master's range of FS matched paints is onen of the best when it comes to accuracy, can't remember the codes for the two paints you need but the bottles have the FS number printed on the label, so no problem here. Humbrol's paints for these two colours are 127 and 128. 1 Link to comment Share on other sites More sharing options...
Hook Posted May 26, 2019 Share Posted May 26, 2019 On 5/24/2019 at 9:00 PM, Giorgio N said: Model Master's range of FS matched paints is onen of the best when it comes to accuracy, can't remember the codes for the two paints you need 1728 Light Ghost Gray FS36375 and 1741 Dark Ghost Gray FS36320. HTH, Andre 2 Link to comment Share on other sites More sharing options...
Alyward Posted May 26, 2019 Author Share Posted May 26, 2019 Thanks for the help ill have to stop in at my the hobby shop and pick some up.. Shayne Link to comment Share on other sites More sharing options...
meindert Posted July 6, 2019 Share Posted July 6, 2019 Hi, you can check out the 1/72 Kfir models I made (also in the grey scheme) with some ideas here: https://designer.home.xs4all.nl/models/kfir/kfir-1.htm Enjoy Modelling! Meindert 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted August 20, 2019 Share Posted August 20, 2019 rather than start a new thread, currently painting the green on a kfir build (the recent revell issue) and went with FS34244 when ordering paints, but google seems to have led me to believe it should be FS34227 as per the revell guide? Would I be wrong to switch? Link to comment Share on other sites More sharing options...
Hook Posted August 20, 2019 Share Posted August 20, 2019 2 hours ago, PhantomBigStu said: rather than start a new thread, currently painting the green on a kfir build (the recent revell issue) and went with FS34244 when ordering paints, but google seems to have led me to believe it should be FS34227 as per the revell guide? Would I be wrong to switch? It depends on which Kfir. The C1 and C2 used FS34227, while the later C7 used FS34244. HTH, Andre Link to comment Share on other sites More sharing options...
PhantomBigStu Posted August 20, 2019 Share Posted August 20, 2019 20 minutes ago, Hook said: It depends on which Kfir. The C1 and C2 used FS34227, while the later C7 used FS34244. HTH, Andre Mines a c2 so that’s answered it thanks Andre Link to comment Share on other sites More sharing options...
