Hi all, I start this update with an dohhhh moment! After finishing the main camouflage scheme. I realised I'd missed of the external trim tabs of the ailerons.(which are missing from the kit airerons. The kit airerons  are of me 210.  )  As I had made a few extra copies of the elivators I decided to cut the trim tabs down of them.
2019-07-19_06-02-22
These needed sanded down to match the ailerons then the ailerons resprayed. In hinesight  might have been easier to use 5" plastic card. Oh well.
2019-07-21_01-38-19
With this sorted I masked the fuselarge band.
2019-07-21_01-39-02
2019-07-21_01-39-43
And finally. If some of the panel lines get lost I uses this method to replace them.
Spray a light mottle over them
2019-07-17_07-30-08
Then after 10 mins or so, run a cotton bud dipped in thinner over the mottle
2019-07-17_07-28-27
Thanks for looking, comments and feedback are welcomed. Nick
Edited by Niknak
Hi all, I have started the decaling. I have decided to finish it in the markings of a 2./zg26. For the balkenkreuz I used aeromaster. Swastika's I used xtradecal's. The aircraft codes I used fantasy printshop luftwaffe serials solid and outlines. The centres of the fuselarge balkenkreuz has been filled in with rlm 75
2019-07-28_01-23-10
2019-07-25_10-11-03
The decal setting solution has reacted with the k decal which will need touching up. Grrr
2019-07-25_10-11-18
 Thank you for looking. Comments and feed back is welcomed. Nick
Edited by Niknak
Hi all all decals have been applied and the airframe giving a brushed coat of vallejo matt varnish ready for the masking to be removed an the rest of the build to continue.
2019-07-28_01-22-14
The spinners have had the spirals masked using tamiya tape.
2019-07-28_01-22-37
And sprayed humbrol white and the masking tape removed
2019-07-28_01-22-50
Thank you for looking comments and feedback welcomed. Nick
Hi, there hasn't been much done since the last update. Most of the  masks have been removed. In a couple of places the conopie masks pulled some paint of with them. Luckily the pant was large enough to be able to fixed back in place with Johnson's clear.
The engine and the other cowlin has been fitted to the airframe. I did it after painting so the painted and weathering of the exhausts would be easier. But there has been a bit of blending in of the cowlings where thay join the airframe. So could I have fitted the cowling before painting and fitted the exhaust's through the front after painting.
2019-08-02_03-50-25
2019-08-02_03-50-57
The barbette's  which were pushed in place for painting have peen removed and the mg 131's have been fitted to them.
2019-08-02_03-51-52
Tank you for looking. Comments and feed back is welcomed. Nick
On 03/08/2019 at 02:49, Thom216 said:
She's looking good! Real nice work.
Thanks thom216, its not a bad kit realy i think most of the issues are because of the thickness of the canopie . Nick
Edited by Niknak
Hi all here is the latest update, the undercarriage has been finished. I used 0.3 mm lead wire for the brake lines.
2019-08-08_08-14-40
The wire was painted rlm 02 and the flexable hoses painted humbrol 67 Also the gun barrels have been added to the external gun pack.
2019-08-08_08-15-07
The propellers have been fitted to the spinners. I have feathered one og the props
2019-08-08_08-15-20
The wheels have been been finished by dry brushing and stapling hunbrol 29 over the tread
2019-08-12_11-42-34
 The undercarriage has been fitted. Props and flaps have been placed in place
2019-08-12_11-42-59
2019-08-12_11-43-52
Thank for looking comments and feed back are welcomed. Nick
On 12/08/2019 at 20:08, Greg Law said:
Excellent build. Very nice spiral work on the spinners
Thanks Greg, spirals are easier to do now you can get tape that's designed to curve. Nick
Yes I was thinking that. I have the bomber version of this kit a will build it one day as I have always liked this plane.
Yip, I took me awhile to decide which version to build myself.
Edited by Niknak
Well, Would you look at that. Looks great Nik, super work!
Thanks antb. I think the rlm 75 after the varnish coat has gone too dark tho. But it's getting there.
Hi all this up date starts with a back track... I assumed the radiator flaps were the same as the bf 109. I was wrong. When I tried to fit them thay wouldn't fit extended. So after some more research. I found a few videos of the flaps beening deployed then retracted from the rear. In the videos the inner side of the flaps are connected to the end of the main flap. Ahhh. So I cut the part from the radiator sides and used 10 " plastic card to make them and fitted them to the flaps
2019-08-25_12-53-10
2019-08-25_12-55-23
After these were fitted to the flaps and spayed. The flaps were taped retracted to the wing, then the exhaust stains were sprayed on using mrp smoke. The flaps were then glued to the wings in the deployed possision. The radiator flaps have  had a shampher added so thay can be dropped to match the main flaps.
2019-08-25_12-54-41
I have replaced the trim Activision rods with copper wire ready for touching up.
2019-08-25_12-59-40
The rear mg 151 have been fitted to the fusalarge slightly depressed to match the controls
2019-08-25_12-55-01
Also I have started to weather the airframe using  ak's aircraft engine set. Using 10/0 & 5/0 brushs
2019-08-25_12-54-16
2019-08-25_01-23-04
I have used 10 thou plastic card for the leading edge slat suports
2019-10-17_12-03-27
2019-09-22_03-31-01
The gun packs have been added also
2019-10-17_11-00-36
The entry step will be made from strips of plastic card. The blind landing aproch airel will be replaced with copper wire. This will finish this build as the radio airel will be made from streached sprue and fitted after its on its base. Thank you for looking. Nick
