MickE Posted May 14, 2019 Share Posted May 14, 2019 Hi all Can anyone confirm if the tracks on a Stormer HVM are the same as on the Scorpion/Scimitar family? I have the Accurate Armour Stormer HVM to build and don't fancy using the tracks that came with it. Regards Mick Link to comment Share on other sites More sharing options...
Dads203 Posted May 14, 2019 Share Posted May 14, 2019 CVRT I think , late type 👍 Link to comment Share on other sites More sharing options...
MickE Posted May 14, 2019 Author Share Posted May 14, 2019 Ok thanks. Mick Link to comment Share on other sites More sharing options...
ivan-o Posted May 14, 2019 Share Posted May 14, 2019 Isn’t the stormer family longer than a cvrt? you might need to buy two sets! Link to comment Share on other sites More sharing options...
MickE Posted May 15, 2019 Author Share Posted May 15, 2019 It does look longer. You could be right about two sets although I suppose I could use some of the resin track for the top run, which are hidden. Mick 1 Link to comment Share on other sites More sharing options...
MickE Posted June 3, 2019 Author Share Posted June 3, 2019 Next question on the same subject. How many track links are there per side for the Stormer? Also does anyone have any good pictures of the idler wheels showing the angle of the arm? The Accurate Armour instructions are very poor in this area. Regards Mick Link to comment Share on other sites More sharing options...
ivan-o Posted June 3, 2019 Share Posted June 3, 2019 (edited) Can’t help on the No of links.after a bit of digging on the inter web the track for Stormer and CVRT are indeed different! The horn on the side of the track is different and the Stormer sprockets are bigger. Edited June 3, 2019 by ivan-o Link to comment Share on other sites More sharing options...
MickE Posted June 4, 2019 Author Share Posted June 4, 2019 Ok thanks, I was told that the late CVRT tracks were a match for the Stormer tracks. I will find out when the CVRT tracks I ordered turn up 😀 Link to comment Share on other sites More sharing options...
MickE Posted August 6, 2019 Author Share Posted August 6, 2019 Next question - does anyone know how many links per side there should be? Regards Mick Link to comment Share on other sites More sharing options...
Kingsman Posted August 6, 2019 Share Posted August 6, 2019 I can't provide the number. But don't forget that links would be removed as the tracks stretched in use beyond tensioning with the idler, so the number could vary. The vehicle's AESP would say how many links could be removed before the tracks needed to be replaced. It probably says how many when new. You can buy the Stormer AESP on line, but they seem to be £50+. Link to comment Share on other sites More sharing options...
MickE Posted August 7, 2019 Author Share Posted August 7, 2019 Ok thanks. Link to comment Share on other sites More sharing options...
mshackleton Posted August 18, 2019 Share Posted August 18, 2019 The Stormer family has chevron shaped track shoes, not rectangular. I can offer these here, but they are designed for Spanisn Scorpion and Scorpon 90. Link to comment Share on other sites More sharing options...
MickE Posted August 21, 2019 Author Share Posted August 21, 2019 Thanks, they look nice but I already have the resin track that that came with the kit and they need to be formed like yours. I was looking for some link and length or individual track links. Link to comment Share on other sites More sharing options...
mshackleton Posted August 21, 2019 Share Posted August 21, 2019 No-one else does them that I know of. Link to comment Share on other sites More sharing options...
MickE Posted August 21, 2019 Author Share Posted August 21, 2019 Ok thanks I will bear you in mind if I mess up the resin ones. Link to comment Share on other sites More sharing options...
Ozzy Posted August 22, 2019 Share Posted August 22, 2019 On 06/08/2019 at 15:27, MickE said: Next question - does anyone know how many links per side there should be? Regards Mick I will find out for you. Link to comment Share on other sites More sharing options...
MickE Posted August 22, 2019 Author Share Posted August 22, 2019 (edited) Thanks Ozzy Accurate Armour said that the resin track lengths supplied were enough to make two complete tracks and to trim them to size. Knowing how many links there were would be better. Edited August 22, 2019 by MickE Link to comment Share on other sites More sharing options...
Ozzy Posted August 22, 2019 Share Posted August 22, 2019 1 minute ago, MickE said: Thanks Ozzy Accurate Armour said that the resin track lengths supplied were enough to make two complete tracks and to trim them to size. Knowing how many links there were would be better. Definitely Mick, I asked some of my cloud punching pals and this is what I got. 82-84 per side. Dependent on what tention you require for the terrain. Link to comment Share on other sites More sharing options...
MickE Posted August 22, 2019 Author Share Posted August 22, 2019 That's great, many thanks for your help. 1 Link to comment Share on other sites More sharing options...
