Andre B
Which Cold War Aircraft needs noseweight and wich doesn't?
Hi,
Sometimes questions showes up concerning noseweights. There must be lot of builders here with experiences so why not making an chart of wich aircraft that needs noseweight and wich doesn't?
I will try to update the chart if there is interest...
Cheers / André
Edited by Andre B
Brittish Aircrafts
Attacker - Yes
Buccaneer - Yes
Canberra - Yes
Gannet - Yes
Gnat - No
Harrier - No
Hawk
Hunter - Yes
Jaguar - No
Javelin - Yes
Jet Provost - Yes
Lightning - Yes
Meteor - Yes
Scimitar - Yes
Sea Hawk - Yes
Sea Vixen - Yes
Swift
Typhoon - Yes
Vampire
Venom
Canadian Aircraft
Avro Arrow
US Aircrafts
A-3 - Yes
A-4 Skyhawk
A-5 Vigilante
A-6 Intruder - Yes
A-7 Corsair
A-10
B-45 Tornado
B-66 - Yes
FH-1 Phantom
F2H Banshee - Yes
F3D Skyknight
F3H Demon - Yes (15 g 1/72)
F4D Skyray - Yes (5g 1/72)
F5D Skylancer
F6D Missiler
F6U Pirate
F7U Cutlass
F9F Panther
F10F Jaguar
F11F Tiger - No
F-80
F-84
F-86D Sabre (20g 1/48)
F-89
F-100 Supersabre
F-101 Voodoo
F-102 Delta Dagger
F-104 Starfighter - No
F-105 Thunderchief
F-106 Delta Dart
F-108 Rapier
F-111 Ardvaark
F-4 Phantom - No
F-5
F-6 Skylancer
F-7
F-8 Crusader - No
F-14 Tomcat - No
F-15 Eagle - No
F-16 Falcon - Mostly not...
F/A-18 Hornet - No
F-20
F-21 - No
F-22
F-23
F-35
Russian Aircrafts
Il-28 Beagle
MiG-15
MiG-17
MiG-19
MiG-21
MiG-23
MiG-25
MiG-27
MiG-29
MiG-31
Su-25 - Yes
Swedish Aircrafts
J-21
J-29 Tunnan - Yes
J-32 Lansen - Yes
J-35 Draken - Yes
J-37 Viggen - No
JAS-39 Gripen - Yes
French Aircraft
Mirage III - No
Edited by Andre B
Update
Airfix 1/48 Meteor - yes
MiG-17 1/48  KP/etc  and Trumpeter  a lot!
MiG-15 1/48 Trumpeter with CWS resin tail.. a lot
Su-25 1/48 Monogram yes
Edited by exdraken
Airfix 1/48th:
Lightning, yes,
Hunter, yes, Javelin, yes
Sea Vixen, yes
Buccaneer, yes
Jaguar, no
Tornado, tes
Canberras, yes
Meteor, yes
Airfix 1/72th
Jet Provost, yes
Vampire, yes,
Me 262, yes,
Lightning, yes
Phantom, no
MiG 15, yes,
Sabre, yes
B-25 Mitchell, yes
B-26 Marauder, yes
It's so easy to accomplish without a chart. Just tape the major components together until you have a substantially complete airframe. Then plug in some toothpicks or matchsticks in the main gear sockets. Place on your workbench and see if it's tailheavy. Then temporarily affix some weight to the nose or in the cockpit or even in the engine nacelles forward of the main gear until the model is no longer tailheavy. That's how much weight to add in those locations. Add a bit more for insurance. That's all there is to it.
Painter's Pyramid stands are great for this purpose instead of toothpicks/matchsticks:
Here's one source:
http://www.leevalley.com/us/wood/page.aspx?p=57821&cat=2,42194,43390&ap=1
Here's one source:
Thanks,
But if one knew one don't need to do that work. And don't have to cut of all parts from the sprues...
Cheers / André
Edited by Andre B
Monogram B-29: the world's supply of lead might...might keep the front end down
HK B 25 , loads of it , under the `pit floor , behind it and behind the engines as well . Makes for quite a heavy model ! .
Revell 48th Tornado (GR4) and Typhoon (Eurofighter) - need it but nowhere near as much as Revell suggest.
It would be really helpful if reviewers that say "I used x gm lead to prevent tail sitting" would then say if this was a reasonable amount, was the result really nose heavy, about right or not enough.
Edited by kingcanberra
Qualify which versions
Sorry Space Ranger --
You can lead a horse to drink, but you can't make him water....
Ed
7 hours ago, Andre B said:
Thanks,
Cheers / André
The instructions for most kits produced within the last 10-15 years indicate how much weight to add (I usually add more just in case), Each modeler has a different idea of what to use for weights, and amounts can vary accordingly. And you have to cut the parts from the sprues anyway!
What many modellers fail to realise when adding weight to the model is to take into the consideration the stress added to the undercarriage, especially nosewheels, you either need to add reinforcement to the undercarriage or consider buying replacement undercarriage made from white metal or brass
Yes, but when it comes to older kits it doesn't. And it's sometimes good to let parts stay on sprues as long as possible and not loose or damage them. I made this thread for those builders who are interested in knewing if they need noseweight of not...
Good point.
You don't need to remove every part, just the major airframe components: Fuselage, wings, tail surfaces, occasionally an interior tub, and anything aft of the main gear such as a jet engine (I'm thinking here of some kits, such as those from Trumpeter, which include complete jet engines that will never be seen). It's not rocket science.
Actually no. not quite. Unless you've added a heap more weight that you needed to prevent tail sitting, the added weight on the nose wheel SHOULD be fairly small, the main undercarriage wheels should be taking the most of it, as the weight added up front is being balanced out by what was causing the model to be a tail sitter in the first case. To my mind, a good reason not to add more than is necessary.
Steve.
Mach 2 Bristol Britannia filled the nose compartment with lead and am now debating the engine cowls.
SAAB aircraft: All with nosewheel need noseweight. That is Draken (not so much), Tunnan (plenty!!!), Lansen, J 21, Gripen, Saab 105 (all three normal).
But there is one exception: Saab Viggen (any brand) does not need any noseweight (unless you don't fill the rear part with tons of resin).
As mentioned on here previously.....
https://hobby.uk.com/materials/plastic/styrene-rod/triangular.html
Painted Rubber Black, glued to wheels, looks like Chocks.
I put these on the wheels, a bit of weight at the front.  Seems to solve most issues.
As per the above list
1/72 Revell Meteor - Yes
1/72 Revell Vampire - Yes
1/72 Airfirx Gnat - No
I built a British Phantom from Hasegawa kit (1/48 scale). Normally Phantoms don't need extra weight but in this case heavy resin jet pipes and FG.1's long nose landing gear leg dictated otherwise. Lead was needed.
Antti
Supermarine Attacker: No, unless portrayed in a certain "post-landing" mode.
