Sign in to follow this
JeffreyK
New products released: A-4 Skyhawk early nose gear door, F-4 Phantom canopy sets for Zoukei Mura
Folks,
I've just released a couple of new resin products.
First of all, to coincide with Hasegawa's re-release of the A-4C kit there is a new nose gear door suitable for all early Scooters until the A-4C. It differs in quite some way from the kit supplied door which is the later type, only suitable from the E onwards.
The other item is a canopy detail set for the Zoukei Mura Phantoms (all variants), in the same way as my sets for the Hasegawa and Academy Phantoms. Unfortunately, a little bit of extra work is required in that a moulded-in raised detail on the inside of the forward ZM canopy has to be sanded off first. For this, a pre-cut piece of masking tape is provided in the set so you can protect the canopy transparency from damage when sanding.
Available at now at hypersonicmodels.com
Jeffrey
