Lanmi Posted May 12, 2019 Share Posted May 12, 2019 Very known Fujimi kit that is in my stash for ages. I will add a few extras, firstly Eduard canopy masks and etched seatbelts and fabulous brass cannons that I purchased in Moson model show a decade ago. Gun barrels I started with the cockpit assembly and added some structural details to the completely flat cockpit side walls. I also glued nose halves to the fuselage halves. I hope I will keep you updated with the progress. 7 Link to comment Share on other sites More sharing options...
dogsbody Posted May 12, 2019 Share Posted May 12, 2019 I have the G-1 kit in the stash, so I'll be watching your build. Chris 1 Link to comment Share on other sites More sharing options...
trickyrich Posted May 12, 2019 Share Posted May 12, 2019 welcome along and great to see another Stuka in the build with BMFC's!!! Those little extras should really make it standout. Good luck with the build, hopefully it'll be a trouble free one and I look forward to seeing her completed in the gallery. 1 1 Link to comment Share on other sites More sharing options...
Col. Posted May 18, 2019 Share Posted May 18, 2019 As Rich says, there's something rather interesting about the Ju-87 with a set of F-off big guns, the box art is rather good as well You've made a good start with this one and it looks as if we're in for a treat between your added aftermarket extras along with scratch-building 1 Link to comment Share on other sites More sharing options...
Lanmi Posted May 20, 2019 Author Share Posted May 20, 2019 Thank you for your encouragement. Here is a little progress I added scratched details at the fuselage sidewalls and here and there few boxes: Then I sprayed Gunze RLM 66 interior color I used oils and then a bit of drybrushed in the interior, and I glued Eduard's seat belts. Then I glued the fuselage halves together. There will be some putty needed, but nothing dramatic I find out that the protective paper has glued itself to decal sheet and I was not happy with selection from the start, so I ordered aftermarket decals from Hannant's. I polished canopy with Tamiya polishing compound 3 stage paste. I put it just to test the transparency: That is for now, hope I will update soon again. 3 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted May 20, 2019 Share Posted May 20, 2019 34 minutes ago, Lanmi said: I find out that the protective paper has glued itself to decal sheet and I was not happy with selection from the start, so I ordered aftermarket decals from Hannant's. I just had the same thing happen to my Fujimi A-7D decals. Another member saved my caboose on that front ? Liking your Stuka so far. 👍🏻Will you be adding the armor plate around the cowling/cockpit ? I built a Late war Ju-87D-5 last year and still have my research if you need anything ? Dennis 4 Link to comment Share on other sites More sharing options...
Lanmi Posted May 21, 2019 Author Share Posted May 21, 2019 @Corsairfoxfouruncle Thank you, your Stuka looks great, I like the cammo. Hm, I am not sure about the armor plates that I understand. As far as I see on the plans I downloaded, I do not see any significant difference in panel lines nor its thickness. I will be grateful for any help, indeed. 1 Link to comment Share on other sites More sharing options...
Lanmi Posted June 6, 2019 Author Share Posted June 6, 2019 (edited) I am not progressing as quick as I would like, but here is a small update. New decals arrived, which is nice and nice reference for armor plates thanks to colleague @Corsairfoxfouruncle So, I had to dive in and scratch them. It was not too complicated. After that, I joined wings and tails and started to fill in some gaps with Tamiya putty. I hope I will be able to speed things up a bit in the coming days. Edited June 6, 2019 by Lanmi 3 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted June 6, 2019 Share Posted June 6, 2019 Great work on this Lanmi, I think I have a few photo's of the yellow nosed "G2" ? Is that the one you're going to do ? Dennis 1 Link to comment Share on other sites More sharing options...
trickyrich Posted June 7, 2019 Share Posted June 7, 2019 just caught up with this one....lovely work here, nice job with the extra armour plates. 1 Link to comment Share on other sites More sharing options...
Lanmi Posted June 7, 2019 Author Share Posted June 7, 2019 Thanks guys, yes it will be yellow nose G2. Link to comment Share on other sites More sharing options...
Lanmi Posted June 28, 2019 Author Share Posted June 28, 2019 Some update at last: This picture is just to show it is good to invest in aftermarket barrels, compared to the kit ones: I sprayed Gunze, finishing gray primer 1500 and then sprayed yellow areas firstly with Gunze white, and then gunze RLM 04 yellow. After that I sprayed some preshading along the panel lines with dark gray, and Gunze RLM 65 for the undersides, and RLM 70 and RLM 71 for the upper sides: Unfortunately, Tamiya tape left some marks on the masked areas of RLM 70, I am starting to be suspicius to the Mr. Leveling Thinner. I polished those areas with polishing cloth and after new layer of Tamiya clear all the marks gone away. Then I put the decals on. 6 Link to comment Share on other sites More sharing options...
Greg Law Posted June 29, 2019 Share Posted June 29, 2019 Looking good you are almost over the line. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted June 29, 2019 Share Posted June 29, 2019 gee she looks great, those AM barrels were a good buy for this build, they're what those gun pods needed. I would say you're right with the Levelling Solution being the cause of the tape marks. It slows the drying time alright but even after it's touch dry I'd still give it a further 24 hours to completely cure. I've used it and while it works I never really was 100% happy with it. Then I read about Tamiya's Lacquer Thinners (with the yellow cap, not the Orange cap one, that one has a retarder in it as well but it's too hot for plastics), I been sold on it. It'll work with Mr. Hobby as well, dries in about the same time but cures then as well, plus it gives the paint a super tough finish, I love the stuff. Anyway, she does look really nice, well done on her so far, keep it up you're almost there. 1 Link to comment Share on other sites More sharing options...
Lanmi Posted July 1, 2019 Author Share Posted July 1, 2019 @trickyrich Thanks for the recommendation I will try Tamiya lacquer thinner, until now I have only used their X-20A Thanks for encouragement, I hope I will finish it on time. Link to comment Share on other sites More sharing options...
Lanmi Posted July 6, 2019 Author Share Posted July 6, 2019 I managed to finish her yesterday, sorry for mobile phone photos. 2 Link to comment Share on other sites More sharing options...
trickyrich Posted July 6, 2019 Share Posted July 6, 2019 very nicely done!!!! Well done on completing her, she looks fantastic, and that's a really nice clean finish on her as well. Thanks for joining us here and for bringing along a Stuka, we don't get a lot of these in builds so always nice to see one. I hope you enjoyed the build, it was great that you could join us. 1 Link to comment Share on other sites More sharing options...
Greg Law Posted July 7, 2019 Share Posted July 7, 2019 Excellent first rate finish. Well done. 1 Link to comment Share on other sites More sharing options...
