Scale solutions resin model of the Derelict from Alien,a fairly hefty chunk of nicely cast resin,No air holes and a reasonable fit,Have been watching this kit for a while,However the company is based in Australia,so,with the initial outlay,along with postage and tax,it seemed unlikely I would ever get one,However a partially built one came up on E-Bay and I was the proud owner of  another "Grail " kit.The seller was grand too,chucked in some miliput and styrene wire as well.
As you can see,the two main booms had been already built.
A little space jockey figure can be built into the main hull.
You can build one of two versions,the intact version as seen in "Alien",or the damaged version with a collapsed beam as as seen in "Aliens" An extra base piece is added to lay the collapsed beam on.
As i was building the alien version this base piece was not required,but I hate to see good resin go to waste,so ,with a bit of flipping and modelling clay I have joined the two together.
A bit of minor surgey later.
And all blended in.
And given a coat of primer.
I think the Derelict is an iconic design,and really sold the  idea that it was designed by an Alien culture,Giger at his awesome best,hope to do it justice.
Andy
Looks like a great kit and nicely-detailed to boot. I will be watching your progress with great interest.
Thanks for sharing.
Chris.
Thanks Guys,Little update.
The teeny space jockey,soon never to be seen again!
Some base work
The ship starting to take shape.
😮 that should be lovely once done! Looking forward to it...
Looking great!
If you put a clear hemisphere over the top of the space jockey that would make a really cool ornament
On 5/15/2019 at 10:10 PM, Hunter Rose said:
Looking great!
Wish I'd thought of that before I buttoned it all up😜
Progress so far,ship built up and given a coat of Silver.
Ship after a few coats of thinned Sage green and burnt umber ink
In true"Jumping in before learning to swim" fashion I thought the base looked a bit "Weedy"So to bulk it up and save weight,I cut out a couple of polystyrene sheets as support and built up the edges with clay,it gives it a bit more "Heft"
That's a bloody good paint job! And that base looks so much better like that, great idea
Thanks all,final hurdle now,ship all done and ready.
Base all done
 Both together.
Should be RFI soon.
Andy
