Italian Typhoon - more shades of grey, anyone?
Just now, keefr22 said:
You could always build it as a RAF 74 Tiger Squadron jet - then it wouldn't be....!!
Hold on Keith, I have the Airfix kit for a proper British Phantom, this one
airfix-a06016-1-72-mcdonnell-douglas-pha
good work on the gaps!
Thanks, I'm quite happy with that :thumbsup:
24 minutes ago, perdu said:
Hey guys Giorgio is cheating, he's using FURREN SUPERGOO
:rofl: Wait, is that a real thing? Where do I get it? :D
Ciao
  • Haha 4
2 hours ago, giemme said:
Yes, I've explained it to Erwin in post #344, but here it is again just for you:
Ah yes.  Just yesterday then.......Looks like I've got problems with attention as well as memory.......
  • Haha 5
I've got a soft spot for the 74 squadron jets as well (altho IIRC isn't there a debate about what colour grey they were painted? (More shades of grey anyone? - boom - boom :blush:)) cos back in the day my Jag squadron and 74 used to do a lot of affiliation training together (and had the odd party.....)
Edited by Fritag
Steve, Silvano @phantom61 is the guy for that, he has probably already built one of that squadron :)
Ciao
Edit: I didn't supposed you had parties... :rofl:  :rofl:
Edited by giemme
Sorry G, but you can't do a 74 machine from that one. 74 only used the F-4J (UK) and FGR2. The only RAF squadrons to use the FG1 were 43 & 111. Or I suppose you could do one of those there fishhead jets... :rofl2:
They were delivered in US 'equivalent' colours over a particularly strong yellowish primer that gave them a greenish grey hue. There's a Lifecolor Japanese Navy grey acrylic that's supposed to be a very good match! IIRC they also had an incorrect serial font. Most (all?) of them were eventually resprayed into the correct UK greys with the correct serial font.
Keith
Yes, that's what I meant. They are British after all, aren't they? :confused:  :rofl: :rofl:
Ciao
Ciao
74 Squadron
of course...
I built 8 phantoms all UK  🇬🇧
IMG_6207
IMG_6205
IMG_6168
this is the last born ...
FG1 111 Sqn XV 574
Edited by phantom61
  • Like 9
Lovely fixing up G. I can’t remember having the step problem when I built mine.
hang on I’ll have a look.
B32DAD7F-6FF3-4920-B24C-1AAB512E179C_zpsvplydrqq
ahhhh as you can see it looks like I didn’t realise that the under wing step problem was a problem. Seems I made quite a feature of it. Ahhhhh ignorance is indeed bliss in my case. 🤣😇 good luck with your one though, a shim and some filling. I’m always reluctant to co cRaZy with the files mind.
Johnny.
  • Haha 2
On 05/09/2019 at 17:04, keefr22 said:
Or it was a cunning plan Johnny - hide it in plain sight...!! :)
K
Indeed! :rofl:
:rofl: TBH, after I read your post I spent quite some time looking for a decent picture of the Eurofighter underside. In fact, there is a panel line there, both sides, so I somewhat understand Revell's rationale in engineering the kit this way. Too bad that they got it wrong in size, though: the rectangular part should extend more backwards (see pic, sorry for the size)
underside
the black line is the actual panel line, the red one shows where Revell put it. The back portion of that rectangle simply isn't there. So it's gonna be shimming, filling, reshaping (riffler files arrived, @CedB :wink: ) and rescribing. Fun! :)
Ciao
The Typhoon is coming along splendidly Giorgio. I thought of your byuild a few days back when we had the Bournemouth Air Festival down here. We live just the other side of Poole Harbour, which is where a lot of the fast jets often hold while waiting their turn to display. We were treated to our very own low level flypast (3 or 4 times) by a very noisy Typhoon. Certainly livened up the sleepy village of Langton Matravers for a few minutes! The Draken was quite neat too.
Terry
Thanks Terry :thumbsup: The Typhoon flypasts must have been exciting! I was lucky enough to see one a couple of years ago, while at the seaside in Southern Italy.
BTW, my eldest daughter was in Bournemouth for a couple of week of studying holiday last August - she liked the place :)
 Ciao
Hi everybody, time for WE progress report.
Wings: as I mentioned, I will tackle the bad fitting underside once the top wings are in place. Before that, more surgery was needed, since I want to represent the flaperons in the up position; so out came Airwaves micro saw, and I started separating the two movable surfaces
wings6
and after some time and patience
wings7
As you can see, the four of them sport a sink mark, in correspondence with the hinge moulded on their underside; a quick fill in with CA+flour, some sanding and polishing and..
wings14
here they are. Time to dry fit the wings, then:
wings8
wings9
:hmmm: Gappy, especially port wing.
Underside:
wings10
The seam parallel to the leading edge will be a lot less evident once the wings are clamped for gluing, but the segment that runs along the wing tip must simply be filled in (it also goes across the slats panel lines ... ). Same for the other side
wings11
So, before fitting them permanently, I thought of gluing some plastic shims on the wing roots (wing side), 0.3mm thick for port wing and 0.15mm - from yogurt cup, yeehh :D -  for t'other (I used TET for the job)
wings12
wings13
Once cured, I trimmed the excess with a razor blade and refined by sanding/polishing. You may notice that the corner formed by the leading edge and the root is quite irregular, so I filled it in again with CA+flour and reshaped, prior to gluing the wings in.
Another dry fit
wings15
Less gappy, but it will probably require more TLC after gluing.
Clamps on!
wings16
TET again for the job, now curing overnight.
Comments welcome :)
Ciao
  • Like 14
9 hours ago, CedB said:
Nice work Giorgio :)
Thanks Ced :thumbsup:
2 hours ago, Biggles87 said:
Looks like you have more clamps than Ced!
I don't know, John: what you see in that last pic it's almost all I have ... :rofl:
Ciao
Edited by giemme
  • Haha 2
Looking good Giorgio. I do like the look of the big clamps, is that a locking one on the rear of the port wing? If so, where from?
My main problem with clamps is keeping them attached on curved surfaces!
Ian
4 hours ago, Spookytooth said:
Nobody has more clamps than Ced LOL.
Nice and steady G.
You will sort this problem out in no time what so ever .
Simon.
Thanks Simon - yes, a bit more filling required but I'm almost there now :D  :thumbsup:
4 hours ago, keefr22 said:
That sounds like a challenge...!!
Neat gappy filling G!
Keith
:rofl: A challenge I will not take up, Ced is unbeatable! And thanks for the comment, Keith :thumbsup:
Ian
Thanks Ian :thumbsup: Yes, it's a locking clamp (there's actually two of them in that pic, one being upside down and not showing the release trigger). I bought them in a hobby and craft store, Le Roy Merlin to be precise, years ago. I have no clue about the maker, but I can check if there's anything moulded or stamped on them
Edit: Found this on Amazon.it I wouldn't know how to call it in English, though: http://tinyurl.com/y2bjom5z
As for the curved surfaces, the trick is to use blue tack: just put a blob on the curved part where the clamp is supposed to "bite", it will prevent it from slipping away. HTH
Ciao
Edited by giemme
