Merlin Posted April 27, 2019 Share Posted April 27, 2019 Hi, need to tack a canopy into place then remove it later on when I get an open variety. Which glue should I use that wont damage the aircrafts paintwork etc. Also amazed this forum hasnt got a glue section, as glue is pretty much at the roots of our hobby ! Merlin Link to comment Share on other sites More sharing options...
Beazer Posted April 27, 2019 Share Posted April 27, 2019 Microscale Kristal Klear. You can use it for securing the cockpit as will. Temporary masking and put a couple dots down and it will hold that canopy in place until you’re done. Easy to remove and I’ve never damaged any paint with it. Link to comment Share on other sites More sharing options...
Merlin Posted April 27, 2019 Author Share Posted April 27, 2019 excellent thanks. I also have found a substance I forgot I had ...ambroid tac and place. Liquid pressure sensitive adhesive temp or permanent joining of plastic wood paper fabric glass foam metal items may be removedand repositioned again and again it says. Merlin Link to comment Share on other sites More sharing options...
