Allan31 Posted April 25, 2019 Share Posted April 25, 2019 (edited) So I did some www research but didn't find anything definitive about the best way to get here.... Apparently I have several choices. vac conversions, injected molded kits, resin, etc., etc.. In 1/72 scale what is the best way to get a good "Ascalon"? Also, to my eye, the name ASCALON written on the nose looks to me to be in yellow rather than white, I'm looking at the roundel on the fuselage for grey tone comparison and it looks much closer to the yellow ring than the white ring. Any thoughts? Edited April 25, 2019 by Allan31 Link to comment Share on other sites More sharing options...
Work In Progress Posted April 25, 2019 Share Posted April 25, 2019 Depends how much money you want to spend. Personally, as a cheapskate with several 1979-vintage Airfix Lancasters in stock, if I wanted Ascalon specifically, with its atypical rectangular windows, I would be making my own fuselage out of balsa according to the Granger drawings. I think all the Czechmaster conversions are for the circular-windowed majority. Much discussion here of Yorks in general April 1967 Airfix Magazine can usually be found fairly readily and includes a good Alan W Hall article on the DIY approach, using the original Airfix Lancaster, but the 1979 issue would be the best bang for the buck IMO. Link to comment Share on other sites More sharing options...
JWM Posted April 25, 2019 Share Posted April 25, 2019 You can use Czech Master Resin fuselage (with round windows of course) or Mach 2 new York (also with round windows) or Mikro-Mir one (? - it is still "to be" I think) Then you can cut out whole sides (rectangular) of fuselage containing all windows and glue in a clear plastic card from CD box - for instance. However - in case of York the fuselage sides only almost flat - som maybe some more frlxible clear card than CD box will be better or use plastic card divided into smaller pieces. . Mask all windows with Tamiya tape and then use putty/sanding to make transition between fuselage and this clear part then rescribe surface on this area, paint and finally unmask windows. Good not to forget to add curtains behind windows... Regards J-W 1 Link to comment Share on other sites More sharing options...
Hhhalifaxxx Posted April 26, 2019 Share Posted April 26, 2019 Or you could do it the slightly harder way: get a Sanger York vacform, cut out its fuselage, tails and engine pods and marry them to the wings and smaller parts of an injection-moulded Lancaster. You could putty over the engraved round windows, level the excess putty by sanding it down and cut out new, square window frames. A clear plastic strip glued on the inside over the cutout window frames would simulate window glass panels. Link to comment Share on other sites More sharing options...
dogsbody Posted April 26, 2019 Share Posted April 26, 2019 This is the Wingspan drawing I got from Admiral Puff. It's quite light but I don't know how to darken the lines. Chris Link to comment Share on other sites More sharing options...
silberpferd Posted April 26, 2019 Share Posted April 26, 2019 If I may 1 Link to comment Share on other sites More sharing options...
dogsbody Posted April 26, 2019 Share Posted April 26, 2019 NICE! Thank you for posting that. Right clicked and saved. Chris 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted June 26, 2019 Share Posted June 26, 2019 Should have scrolled down first ? I darkened it up as well. 1 Link to comment Share on other sites More sharing options...
