Renek
Bentley Blower 1:12
I was planning to build two cars out of two kits. One classic Bentley with my accessories, I have a few dozen possible modifications and exchanges for metal parts.
The second car ... but what to say to him is the special Henry Birkin's, he has an extended wheelbase, a different body, and was probably the biggest GP of all time.
So far, I have postponed the construction of the second model.
The building will be with my modifications according to the possibilities of hand tools. The building has been going on for some time, so I will shorten it a bit :)
file.php?id=1459917
file.php?id=1460169
file.php?id=1460167
Basic engine block ... 31pcs in base and color ...
The original divorce was cracked in the frame, I drilled the individual parts and replaced the whole tube with brass ...
file.php?id=1460237
file.php?id=1460238
file.php?id=1460240
Basic frame assembly, test block installation, tank modifications and a few details ...
file.php?id=1460458
file.php?id=1460460
file.php?id=1460664
file.php?id=1460663
file.php?id=1461079
file.php?id=1461075
Rear lamp holder adjustment.
Bottom frame assembly with drive shaft.
Adjustment of handbrake mechanism and lever itself, all made of duralumin and brass
file.php?id=1461227
file.php?id=1461501
file.php?id=1461530
file.php?id=1461532
file.php?id=1461722
file.php?id=1461721
file.php?id=1462337
file.php?id=1462336
Very nice. A lot of nice little extras going on here. By the looks of it, you will end up with a fantastic model. Best of luck with the rest of the build. I’ll be sure to drop by for the updates.
3 minutes ago, Cooper645 said:
Velmi hezké. Je tu spousta pěkných drobností. Podle vzhledu skončíte s fantastickým modelem. Hodně štěstí se zbytkem stavby. Budu určitě upustit o aktualizace.
Thank you very much .... I'll try what my old eyes will allow me :)
Interesting to see me quoted in Czech, I always knew I could speak many languages 🤣.
recently used a Czech shop MN modelar and had excellent service. You may wish to check them out if you didn’t already know about them.
4 minutes ago, Cooper645 said:
Zajímavé, že mě citují v češtině, vždy jsem věděl, že mohu mluvit mnoha jazyky 🤣.
nedávno použil český obchod MN modelar a měl vynikající služby. Můžete si je zkontrolovat, pokud jste o nich ještě nevěděli.
Well I have the translator turned on, my English is not good :)
MN modeler is cool, big choice, no problem ... one MN shop I have about 20 kilometer ... I'm there often :)
Lovely detail work, Renek. I like very much!!!!
I will be watching...…:clap2:
22 minutes ago, harveyb258 said:
Krásné detaily práce, Renku. Mám velice rád!!!!
Budu se dívat ... ...: clap2:
Thank you. It pleases me :)
It was necessary to make a holder, it works well ... equipped some other parts ... I put some crumbs on it, I do not understand the sense of doing a piece of the kit from three four pieces (see magneta) in order to look like a lump of plastic in the finals.
Magneta on the spot + a few details, I removed the funny hints of grinding control, added brass ducts, the control rods are made of polished duralumin + ignition straps
file.php?id=1463664
file.php?id=1463663
file.php?id=1463660
file.php?id=1463931
file.php?id=1463930
file.php?id=1463929
Maybe it seems a little ... cabs and pipe production ...
The first attempt I invented the tube supply and shake it, drilling 0.8mm hole ... On a few photos, the cables on the candles are not screwed but on "pipes", so I cut the brass tubes and powered them on 0.8 cables. Then it was time to throw everything on the engine :)
I think nerve: lol:
file.php?id=1464107
file.php?id=1464108
file.php?id=1464109
file.php?id=1464110
file.php?id=1464112
From the brass old coin, I made two turbo suction caps and fitted them with a net, although it won't be much visible on the model but the original one was just the one I couldn't let :)
Of course, I made the pressurizer from duralumin fitted with brass micro screws
I modified the horny assembly and put it back in steel mesh
file.php?id=1464218
file.php?id=1464219
file.php?id=1464220
file.php?id=1464221
file.php?id=1464222
file.php?id=1464346
file.php?id=1464347
file.php?id=1464253
file.php?id=1464254
file.php?id=1464255
file.php?id=1464256
file.php?id=1464257
Do not worry about translating - your work speaks for itself.
And your clamps and stand are better than my models - !
BRAVO !
7 hours ago, Codger said:
Nebojte se o překlad - vaše práce mluví sama za sebe.
A vaše svorky a stojan jsou lepší než mé modely -!
BRAVO!
Thank you very much for the words of praise. I have been watching your buildings for a long time and have gathered the courage to present myself.
superb detailing!
1 hour ago, noeyedears said:
superb detailing!
Thank you very much :)
Another approach was to drill holes and make stitches on leaf springs and braid them
He had to figure out the connection of the steering column mechanism, although in the manual it is folded but probably not counting with coloring, I reworked the whole system of connection with the crank handle and fitted it with a steel pin, it works great. A few tubes and some real matrix instead of the funny ones, and another plastic tank, which is missing in the kit.
file.php?id=1464780
file.php?id=1464934
file.php?id=1464933
file.php?id=1466885
file.php?id=1466884
file.php?id=1466882
file.php?id=1466954
file.php?id=1467030
Production of roughly 5mm buckles ... original in the kit was missing, I would probably not give them there ...
file.php?id=1467505
file.php?id=1467506
I have virtually finished the entire bottom frame ... I still find more and more inaccuracies in burrs and dividers, when assembling the front axle immediately snapped plastic pegs as a swivel joint and had to replace them with steel ... the whole geometry is so weird, a lot has to be adjusted and finishing
file.php?id=1469184
I started working on the mudguards and their fitting with the frame ... it is a shock, the carrying rods have unequal profiles, the fenders are not the same and I am seriously thinking that I will not give them there anymore and throw away a few hours I have spent grinding them ... Geometry I repaired by warming the entire axle and changing its shape
file.php?id=1469262
file.php?id=1469260
file.php?id=1469344
file.php?id=1469343
Test assembly of frame components, paint and varnish
file.php?id=1470124
file.php?id=1470122
file.php?id=1470121
A few details ... thermal insulation with braid, production of brake drum cooling. I was wondering what their color would be, some of the body-color drums in the photos, and some as bare metal, probably an aluminum alloy. So I kind of mixed the color, the green is already pretty much there
file.php?id=1470400
file.php?id=1470401
file.php?id=1470402
file.php?id=1470403
file.php?id=1470404
Mark details and steering wheel adjustment
file.php?id=1470418
file.php?id=1470695
file.php?id=1470696
file.php?id=1470698
file.php?id=1470872
file.php?id=1470869
Another adjustment of the protective net of lights .... I was inspired by the building on the net and decided to finish by grinding the indicated net on the clear plastic and adding the net to the real ... for a while, I got stuck when it bursts ...
file.php?id=1471538
file.php?id=1471537
file.php?id=1471536
file.php?id=1471535
file.php?id=1471568
Dashboard adjustments, duralumin instrument frames and deposition tests
file.php?id=1471888
file.php?id=1471887
file.php?id=1471988
file.php?id=1472133
file.php?id=1472298
file.php?id=1472297
Production of exhaust holder, again part missing in kit
file.php?id=1472502
file.php?id=1472503
Patina seats, still focus on them, to distinguish colors: construction - gray surf + green + paint, seat - black surf + green + wash, just assembled
file.php?id=1472607
file.php?id=1472750
file.php?id=1472748
Petrol tank lid detail
file.php?id=1472978
file.php?id=1472979
file.php?id=1472980
Production of girders and other details
file.php?id=1474344
Assembly of wheels
file.php?id=1474342
file.php?id=1474353
file.php?id=1474352
file.php?id=1474351
Beautiful!
Since I like the details, I drove out the position seat beams using an aluminum template, made a new one instead of what looks like a hammer - it's some kind of valve, I adjusted the row and I am trying to make some cables, probably win, colored lead wires, are more subtle
I made something like a sort of shifter ... so that the stick wasn't just murdered, some wires, color of abrasion ...
Modifying additional radiator and oil tank lids ...
Ignition magnet rods adjustment
file.php?id=1474502
file.php?id=1474501
file.php?id=1474499
file.php?id=1474633
file.php?id=1474640
file.php?id=1474639
file.php?id=1474638
file.php?id=1474637
file.php?id=1474635
file.php?id=1474756
file.php?id=1474755
file.php?id=1474754
file.php?id=1474753
file.php?id=1474751
file.php?id=1474752
file.php?id=1475227
file.php?id=1475226
file.php?id=1475224
So the next step, I made a shipping box for competitions and exhibitions.
Modifications to the model, since the kit is more than 20 years old, parts are incomplete and damaged, some unnaturally bent. Cooler adjustment, strainer is made of bronze mesh
file.php?id=1475970
file.php?id=1475968
file.php?id=1476178
file.php?id=1476177
file.php?id=1476176
file.php?id=1476175
file.php?id=1476174
file.php?id=1476860
file.php?id=1476865
file.php?id=1476864
file.php?id=1476863
Beautiful work!
14 minutes ago, Dieter said:
Nadherna prace!
Thank You :)
Whats there not to like, it's a Bentley Blower!!😍
I'm liking all the detail work that is going into this monster, absolutely magnificent!👍🤩
Other adjustments are related to the bonnet, made of brass plate and pipe I made a "piano" hinge
file.php?id=1479418
file.php?id=1479419
file.php?id=1479420
file.php?id=1479421
file.php?id=1479608
file.php?id=1479606
I made a crossbar (or longitudinal) of a duralumin bonnet, I carved a "l" bracket and riveted a 1mm rivet to the end of the bracket ... it's just rough. Next to it is the original plastic part on which the bonnet was just lying
file.php?id=1481718
file.php?id=1481719
file.php?id=1481737
Little Evolution of the Great Shield ... Terrible ... The original frame was in the frame on the bald as well as the two places cracked ...
I used a steel mesh and produced a slightly better version than the plexiglass that is the original kit component
file.php?id=1481824
file.php?id=1481825
file.php?id=1481826
on the test he assembled the lower frame of the big label ... well ... the plastic holds only the chromes and in addition does not fit the profile, the lower paws bend ... First I tried to grind but then I decided to make the whole lower frame of dural and I will also try to move the upper segments of the frame ... semi-finished.
file.php?id=1482224
file.php?id=1482225
file.php?id=1482226
file.php?id=1482227
Bottom frame finished and after basic polishing. I even managed the 3D effect of the bottom "paws" where the bolt will be acknowledged. I'm still thinking that I'm gonna get thin ... but the car looks good ...
file.php?id=1482451
file.php?id=1482452
file.php?id=1482453
I made my rivets to mount the frame in place, I put down the test with the car as it would look ... I think making the new part was the right decision ...
file.php?id=1482515
file.php?id=1482513
file.php?id=1482512
file.php?id=1482511
I replaced the original hinges of the bonnet flap with new wire, I think it's a bit better :)
file.php?id=1482653
file.php?id=1482654
I made other parts for the model, missing in the kit again.
Mains suction turbo, material dural
file.php?id=1485620
file.php?id=1485619
file.php?id=1485618
file.php?id=1485617
file.php?id=1485616
file.php?id=1485633
file.php?id=1485632
Adjusting the interior of the bodywork from 2D to 3D
file.php?id=1486035
file.php?id=1486036
file.php?id=1486702
Adjusting wind labels, gradual assembly and machine work
Steering wheel adjustment
file.php?id=1487462
file.php?id=1487461
file.php?id=1487460
file.php?id=1487458
file.php?id=1487703
file.php?id=1488091
Adjusting the roof overlay to the final variant
file.php?id=1488222
file.php?id=1488285
Details and decals :)
file.php?id=1489421
file.php?id=1489420
file.php?id=1489419
file.php?id=1489613
file.php?id=1489922
file.php?id=1489921
file.php?id=1489919
file.php?id=1489918
file.php?id=1489917
file.php?id=1489915
file.php?id=1489914
Bentley is not yet finished and is already collecting prizes at competitions :)
file.php?id=1490091
I drove out the positions of rivets and bolts on the fenders and went to fit, especially the front ... I got them to the same shape as possible by heating, but those cars did not fit on the car - the brackets and as my colleague prophesied, I was forced to use the front fenders 2mm wire. Now all four are on the right proportions and waiting for the MFH's studs and rivets.
Interestingly, at all similar Bentley buildings, no one is burdened by riveting on the mudguards ...
file.php?id=1490838
file.php?id=1490839
file.php?id=1490840
file.php?id=1490841
file.php?id=1490843
file.php?id=1490844
file.php?id=1490845
