MarkH206
Halifax bomb load explanation January 1944
I thought of adding this to my queries on building the Revell 1/72 Halifax but realised this is more generic.
From the ORB of 77 Squadron in January 1944 this was the bomb load:
a) 1 x 2000lb HC
b) 2 x 500lb cluster inods
c) 32 x 30lb inc ordy
d) 450 x 4lb inc ordy
e) 90 x 4lb 'x' type
From searching here and elsewhere I understand that this is a mixed load of High Capacity and incendiary and that the x type had delayed fuses. The smaller bombs would have been in containers (SBCs). What I haven't been able to figure out is the meaning of 'inods' or 'inc ordy' although I would guess the 'inc' is 'including'.
Any help appreciated
thanks
Mark
I suspect that the 500lb cluster inods is also incendiary ordnance, ie an incendiary cluster bomb
a) 1 x 2000lb HC
thanks
Mark
two chaps who may well be able to help,  @Selwyn  , works with munitions in the RAF, and @Finn   who has posted details of bombs loads.
the load looks like a typical 'cookie and cans'
The 4lb incendiary http://www.wwiiequipment.com/index.php?option=com_content&view=article&id=114:4lb-incendiary-bomb&catid=43:bombs&Itemid=60
HTH
Thanks to all. I've just realised I've been daft. Of course 'inc' means incendiary so that leaves me with two abbreviations I don't understand:
'inods'  and  'ordy'
Any ideas?
'inods'  and  'ordy'
Any ideas?
As this bomb load is basically a incendiary bombload,  the 2000lb HC would  blast open buildings and the 4lb incendiaries would then set fires  on what exposed.  I believe;
"Ordy" is short for "ordinary" that is the basic 4 lb incendiary  as opposed to the 4 lb "X"  type  incendiary (also part of the quoted bombload) which were 4 lb incendiaries with an additional explosive charge incorporated, used to actively discourage firefighters from attempting to extinguish the incendiaries.
"Inods" is used as a descriptor for the 500lb Cluster bomb.  Various different munitions such as smoke bombs  J type incendiaries  8lb frag bombs  and 4 lb incendiaries could be used in this cluster bomb.
 Inods  I think in this case probably means  the type of 500lb cluster was the type also filled with 4 lb incendiary ordinary.
Selwyn
