Magua87
RAF Coastal Command B-17 Lettering / Codes and Roundels
Evening, all.
I've got an Academy B-17E on the go, which will be built as FK186. Two images linked below.
https://www.iwm.org.uk/collections/item/object/205210450
http://zoom.iwm.org.uk/view/7513&cat=photographs&oid=object-205018261
I've been looking at the availability of decals for a Coastal Command Fortress, and I've got choices between Xtradecal and Kitsworld. What those sheets don't have are the lettering I need; the 8 inch serial, the large J on the fuselage (36"?) and the S up front (size unknown?).
I haven't seen any recent threads on Coastal Command codes / serials, but it seems we have slim pickings? I understand the colour of the codes / serials should be light slate grey, but it seems the closest we have is either dark grey or medium sea grey. And even then, no 8 inch serials available at all in those colours.
Dark.
https://www.hannants.co.uk/product/AOD72C02
Medium sea.
https://www.hannants.co.uk/product/X72145
Two questions.
Are there any sheets in dark slate grey that I've overlooked?
Any idea on the size of the "S" on the nose of my chosen aircraft?
Ventura had a sheet of light grey serials for RAAF fighters, it may still be available from Red Roo?  I don't recall which grey was intended.
For the size of the S on the nose, I suggest taking the kit nose and try marking it out in pencil until it looks to be the same size as in the photo.
We don't have much of a Ventura range but their own site seems to have a good assortment. For instance
http://www.venturapublications.com/store/index.php?main_page=product_info&products_id=187
Or even Hannants:
https://www.hannants.co.uk/product/VA7253
Think the grey intended is Medium Sea Grey though.  Can't think of a source for Light Slate Grey codes and serials other than the old Modeldecal sheets: sorry.
I have a sheet of Light Slate Grey codes and serials I got from an outfit called Flying High (I think) many years ago. I can send you a couple of J's in 48" which is the usual large aircraft size and FK186 in 8" if you PM me your address.
A technique I have used where I can't get the right colour decals could be used for the S - if you can find something similar in a different colour cut closely round it and then paint it the correct shade and apply as a decal in the normal manner. Or scan it, change the colour in a photoediting or graphics package and print onto decal paper. I can't give you RGB values for Light Slate Grey but Medium Sea Grey is given as 137, 145, 148 here https://www.e-paint.co.uk/Lab_values.asp
Edit - A quick Google reveals Light Slate Grey values here https://www.colorhexa.com/778899
