Svedberg Posted April 8, 2019 Share Posted April 8, 2019 (edited) Yet another piece of work equipment on my part. This time a somewhat older type and model, namely a Ferguson TE20 "Little Grey Fergie" tractor. The kit is by Heller and is in 1:24 scale. First subassembly was the powertrain (minus the wheels). Edited September 10, 2023 by Svedberg Bad image links. 2 Link to comment Share on other sites More sharing options...
JeroenS Posted April 8, 2019 Share Posted April 8, 2019 Oh, yes, I just added this one to my stash a couple of weeks ago! I love it. I'll be following your build closely! Link to comment Share on other sites More sharing options...
Marco F. Posted April 8, 2019 Share Posted April 8, 2019 Very interesting, I like this model very much. What's your plan, used or new look? I'll have an eye on this WIP. Good luck and show us each step of your progress Cheers Marco F Link to comment Share on other sites More sharing options...
Svedberg Posted April 8, 2019 Author Share Posted April 8, 2019 2 hours ago, JeroenS said: I'll be following your build closely! 2 hours ago, Marco F. said: I'll have an eye on this WIP. Good luck and show us each step of your progress Thanks guys. Nice to have you aboard. 😀 2 hours ago, Marco F. said: What's your plan, used or new look? Used. That's more interesting I think. Also, I plan to eventually build a small diorama for it and then a new and unused tractor would look out of the place. 1 Link to comment Share on other sites More sharing options...
Svedberg Posted April 9, 2019 Author Share Posted April 9, 2019 (edited) After having built and primed the power train (with Vallejo grey primer from a rattle can) I decided to paint and weather the power train, since it would be easier to reach all the details at this point rather than when the model was fully assembled. Overall, the paint job would not be complicated. Everything except a few details should be grey, unless you do the French built FE20 tractor in which case some parts, as the motor, would be red. The Heller kit did actaully include paint, but I found the grey paint a little to dark for my taste. After all, my "Fergie" was to be old and sunbleached, and besides, I did not now how that paint would spray. I did the following - added the dashboard - sprayed the complete assemby with Vallejo 70.989 Sky grey - added the battery and brush painted it black as per the instructions - painted the radiator piping black as per the instructions - added miscellaneous cables and pipes using phosphor bronze wire. The wire that stood in for cables I painted black. - painted various details such as the ignition coil and distributor in miscellaneous non-grey colors to add some visual interest - gave everything a wash of turpentine and black and burnt umber oil paints. I also gave some parts a wash of AK Track Wash Here is the result Edited September 10, 2023 by Svedberg Bad image links. 4 Link to comment Share on other sites More sharing options...
MarkSH Posted April 9, 2019 Share Posted April 9, 2019 Will watch with interest I too have recently acquired this cracking looking little kit. Very nice work on the engine and other components. 1 Link to comment Share on other sites More sharing options...
Svedberg Posted April 12, 2019 Author Share Posted April 12, 2019 (edited) Next up were the wheels. I wanted the rims to be partly rusty so I made them a multi-step affair: - Primer, from a rattle can - Sprayed them with a Tamiya red brown color, from a rattle can - A very light coat of hair spray - Airbrushed the final color (Vallejo Silver grey) When the final coat had cured I used a wet cotton swab to gently and partly remove the top coat, revealing the red brown color below. Here is the result, with tires attached: Edited September 10, 2023 by Svedberg Bad image link. 5 Link to comment Share on other sites More sharing options...
Marco F. Posted April 12, 2019 Share Posted April 12, 2019 The wheels looks real good, congratulation! Now you got to give an used look to the tires... looking forward to see how you'll going to manage this...bcs oob they look not so realistisch. I belive you will entertain us with a great progress...so... please don't stop Cheers Marco F 1 Link to comment Share on other sites More sharing options...
Svedberg Posted April 14, 2019 Author Share Posted April 14, 2019 Thanks everyone for all the likes and comments! 😀 On 12/04/2019 at 20:24, Marco F. said: ... looking forward to see how you'll going to manage this...bcs oob they look not so realistisch. I'll do my best, I promise! Link to comment Share on other sites More sharing options...
Svedberg Posted April 14, 2019 Author Share Posted April 14, 2019 (edited) I did not take any more pictures from the actual build. But I thought I would share some experiences I had during the build. I will be referring to the Heller build instructions. Three-point linkage The first thing concerns the short arms that act as the attaching points between the hydraulic system and the three-point linkage. Those arms are part C16 attached to the power line very early in the build (step 2), and are shown encircled in the photo below. These short arms are supposed to be able to swing freely up and down, and C16 shall not be glued down, but be held in place by part B13. The arms on my model did also swing freely, originally. But while my applied turpentine wash was drying I forgot to make sure that the arms did not get stuck. But of course they did, so when I reached the last step in the build (step 59), and was about to attach the three-point linkage, the linkage lifting arms did not reach those short arms. I had to use some considerable force, applied with a pair of pliers, to make the arms “swing” down. Fortunately nothing broke. Lesson learned: Make sure these arms do not get stuck! Rear wheel axles Another mistake I made concerned the rear wheel axles. At some point during the build I realized that one of the axles was rotated a half turn. A rectangular hole that would eventually accept and hold the righthand mudguards was facing down instead of up. The mistake was made in steps 20 and 21 (see below). The wheels are designed to be able to turn, and in step 20 axle parts D5 and D2 are glued together, but part D24 (part of the fixed axle housing and not part of the wheel rim) shall not be glued to the axle parts. However, the connection between parts D5 and D2 did not seem very sturdy, and I did not want the large rear wheels to wobble around so I decided to skip the “turning wheel” option and glue all parts in steps 20 and 21 together. The potential problem with this is in step 21. Here you must be aware of the fact that part B22 will later (in step 23) be attached to a hole in part D24, which in turn must decide the orientation of parts D14 and D15 in step 21. This to make sure the hole in D24 for part B22 faces forward while at the same time the rectangular hole in D14+D15 faces up (to accept the mudguard). And this must be true for the axle assemblies on both sides (left and right). Here somewhere I f-d up. Not a very big deal in the end, but embarrassing all the same. I managed to attach the mudguard anyway, and the misplaced hole on the underside of one of the axles does not show. Linkage and pedals This is not about a mistake on my part but about the kit itself. In step 30 you assemble some kind of pedals and linkage, and then, in step 31, you attach those assemblies to the tractor. The first problem is that, in my opinion, part B16 is a little too short! It barely reaches part B22 (shown earlier in step 23). It is supposed actually fit in a hole in B22, but does not reach that far and I had glue it to B22 outside of the hole. You might want to find a way to lengthen B16. The second problem here was a pedal that shall be inserted in another hole in B22, just outside of the previously mentioned hole. The pedals (one for the left side and one for the right side) are assembled in steps 46 and 47, and attached to the tractor in step 48 (shown as subassembly 46). The problem is the receiving hole in B22. It is very shallow, allowing for a very weak joint only. I would recommend that you try to make the hole deeper using a drill bit. But then you must remember do that before you attach B22, which is way back in step 23! I did not realize this problem until it was too late, and had no way of reaching B22 with a drill bit and pin vise. Front wheel linkage The next thing I want to point out is an error in the build instructions. It concerns steps 34 and 36, where the front wheel linkage is assembled. Arrows in the instructions are intended to show where the parts shall join. Unfortunately the arrows point at the wrong locations. Should be as indicated in blue, and not as the original black arrows show. Hood When you look at steps 53 and 54 in the build instructions you get the impression that you shall first assemble the hood and then snap it onto the hinges below the radiator. It also looks as if it shall be possible to open and close the hood. This is however not true! Unless my radiator is installed wrongly, but I cannot see how that would be. If you snap the assembled hood onto the hinges it will not be possible to lower it since it will snag on the upper part of the radiator. Fortunately I detected this before the hood had completely cured and was able to pry it apart and re-assemble it “in situ”. Exhausts This is just a tip. You have an option to choose between a low and a high exhaust. The low exhaust has a hole at the end, making it look like the end of an actual pipe. The high exhaust lacks this hole, making the end look more like a rod than a pipe. If you choose the high exhaust you might want to drill a hole in the end before you install it. I did not, since I did not think about this until the exhaust was already in place, but painted the end jet black instead. Good enough! After reading all this you might think that I am not satisfied with the kit, and I must admit that the kit itself, and its instructions, had some weak points. But I still believe that the model will come out OK in the end. Of course I will post some pictures once I feel that I'm done. Edited September 10, 2023 by Svedberg Bad image links. 1 Link to comment Share on other sites More sharing options...
JeroenS Posted April 14, 2019 Share Posted April 14, 2019 Thanks for the tips, that's always good to know! I'll be sure to read them again once I get started. Link to comment Share on other sites More sharing options...
Svedberg Posted April 15, 2019 Author Share Posted April 15, 2019 The last hand has been put to this build. More pictures will come in the RFI section. 3 Link to comment Share on other sites More sharing options...
Svedberg Posted April 15, 2019 Author Share Posted April 15, 2019 (edited) The RIP RFI thread is here Edited April 15, 2019 by Svedberg Typo corrected Link to comment Share on other sites More sharing options...
BIG X Posted April 15, 2019 Share Posted April 15, 2019 That really is a lovely looking piece of work 1 Link to comment Share on other sites More sharing options...
JeroenS Posted April 15, 2019 Share Posted April 15, 2019 1 hour ago, Svedberg said: The RIP thread is here I sure hope you mean the RFI thread 😉 1 Link to comment Share on other sites More sharing options...
Svedberg Posted April 15, 2019 Author Share Posted April 15, 2019 1 hour ago, JeroenS said: I sure hope you mean the RFI thread 😉 Oops! Yes of course! Link to comment Share on other sites More sharing options...
