I would like to share a dual build OOB of two kitty hawk 1/48 Su-34. Making 2 at a time is such as laborious task, which most certainly can be categorized as a form of self-torture and I shall gladly never attempt again.
The kit is incredibly detailed buth riddled with many issues and unclear instructions.
  • Like 26
I like your models very good there.
Can you give some details of the pitfalls or things to correct please, as this model is waiting in the wings for me.
Simon
I've never completed any dual build I've started so congratulations on that alone!
The results speak for themselves though - they both look superb. Well done!
Both look very good indeed and thanks for the pics. What were the pitfalls you mention as like others, I have one in the stash and would be grateful for any pointers or tips to look for/avoid etc...?
Gary
They both came out great!  I think I am partial to the lighter blue version as I can see all the work you have done to weather/accent the panel lines, which turned out looking very nice.
Gary
  1. The cockpit base has fitting issue. When you place the cockpit on the lower fuselage, the upper fuselage cannot close. I had to trim and cut off major chunk of the base of the cockpit.
  2. Instruction menu does not tell which pylon to use with which ordnance
  3. Some parts have the small pimples that suppose to help you glue and fit onto the main fuselage but there are no holes available. So I end up trimming them off.
  4. Some tiny parts are super fragile
  5. landing gear has fitting issues
  6. Nose is light will tilt slight backward, recommend to add weight inside the nose cone.
They are all manageable but can make life easier if knew beforehand.
Edited by jzsn
Just made a note of these on the instruction sheet. Thank you for taking the time to reply; I appreciate it.
Kind regards.
Gary
