Soldering a Tornado ladder, Flightpath 1/32
Some of you may known me more for biplanes, but sometime I'm doing also more modern models. After a search for something else I found this report on soldering a ladder some years ago:
I made something similar so I decided to show my build of that ladder here too.
Tornado Ladder, Flightpath 1/32
The kit:
Two manual pages:
One PE sheet and 3 x 1.0mm brass:
Soldering the steps.
8 steps done
View from top. The anti-slip covering is etched already.
For the remaining parts some PE needs to be soldered together. Rivets needs to be pressed through before!
Also the wheels are done with 3 PE, for centering I used a 0.8mm drill.
With solderingt you will get "one metal pieces", the 3 single PEs are no more visible.
The upper platform will be done in next update ...
Prepared for mounting:
Very clever idea: bending templates for the 1mm brass are etched into PE sheet.
The steps will be mounted in next update.
I hope you like my soldering work. The next update will follow soon.
Frank
Ladder completed
All steps are soldered from below:
Some struts are made from 0.8mm brass. It fits exactly into the holes, but was not part of the kit.
No, my ladder can not be folded ;)
Some small parts are added too, here the "rubber" stand:
And the normal view:
The wheel housings. The wheels will be mounted after painting.
The handrails are bend from 1mm brass of the kit and have nearly the intended form:
The remaining rails are also bend and soldered:
A lot of work at all, and at some place hard to do, because there are 6 PE layers are together. That needs some soldering experience because of the needed heat - without destroying the other soldering points.
On the other hand it looks great - here mine in comparison to a picture in my Tornado book.
On the upper platform there is a rubber bulge to protect the aircraft.
I had some trouble, but later I noticed a wrongly bend part. I was able to recover it.
On the other side also a handrail, and a diagonal strut.
All three soldered PE parts creates a "rubber bulge":
Two very small PE parts closes the ends:
So far completed, with a lot of work.
Conclusion so far: like all other things from Flightpath very detailed, clever enginereed and well produced parts!
One example:
The next update will talk about the painting.
Frank
Hi Frank, that looks great. What kind of soldering iron are you using? Electric or a small gas pen type torch?
That soldering iron is a cheap 20W electrical one from do-it-yourself store. Important for me is a copper tip, which most of the controlled soldering stations do not have.
Frank
Thanks. I have the Flightpath A-10 ammunition loader and cart to build at some stage in the future to go along with an A-10 build. It's basically a box full of etch! 😬
Painting
To be able to scratch the paint later the ladder was tinned.
uc?export=view&id=1U9__Tb6kv5FROlk-JFdHL
The wheels are painted and will be mounted with 0.8mm nickel silver pipe.
uc?export=view&id=1Fv28GxVWqZ4gD1ZB4aKx-
Painted with MRP orange yellow, the steps and the rubber bulge with Gunze tyre black. The yellow was scratched, some rust painted and a light wash with oil paint.
uc?export=view&id=13M55a4Dw0eSV04y-f_2QH
uc?export=view&id=1j92lcCzYTfIYDHsp_Gtvu
uc?export=view&id=19CCTzojmiJ438t4D5RVSy
uc?export=view&id=1KsynF05_XepHCLOR5eB5n
A picture in different light:
uc?export=view&id=1TLB1AabKonAML8r1qN5v1
This beast is finished.
Frank
Yes - with around fifty castings included.
David Parkins
Flightpath
Of course, looking forward to assembling it David 😁
On 4/9/2019 at 9:15 AM, djparkins said:
David Parkins
Flightpath
Oh, very nice to see, that the creator of this nice kit is watching :worthy:
So this reminds the builder, to work carefully.
Thanks,
Frank
