Sign in to follow this
PhantomBigStu
***Finished*** Vampire T11
Had hoped to enter the provost reissue despite its canopy issues (I have a spare from the first issues) but not yet in stock so seemed a natural alternative
Edited by PhantomBigStu
Nice one Stu,which boxing are you using?
Starter though I will be using spare decals from the first issue build that went wrong, though I’ve not picked between the two schemes
The latest boxing's I'm doing have some of the best decal's I;ve seen from Airfix so far Stu,the RAF scheme with the dayglo done as decalling in
particular is a stunner,I've a spare set if you wanted to have a go,happy to post them off FOC.
Cheers for then offer, I also have them spare, did the Swedish reissue last year :)
And now togethor, though slight complication before the silver can be sprayed, the vampires got a couple of shrink marks on the rear of one boom and the migs nose gear doors need work
Sanding them here and there, once they dry will stuff the pits with kitchen roll and spray the first coats of silver
Good plan to work these as a parallel project. Easier to paint both in one session with the same colour.
Indeed, though work on the Vampire has paused, hadn’t been diligent enough in the sanding stages with the migs gear bays, will be back on the spray bench later.
Delayed as I ran out of silver, now to crack on with the interior touch a ups, pilots and canopies as well as the red nose ring
Yesterday was a bit depressing, had a major issue prop up with one, and a seconds become a groundhog day model and lost a former finished build that I was trying to repair which has changed my build and buying schedule as I like to do another of the same type as a replacement. But at least these will be decal ready once the canopies are cleaned up
Both look to be going well for you Stu.
Decals were a pain not least had a couple of breaks and to my horror Humbrol 209 didn’t match, so decided to sacrifice a spare set of JP dayglo decs to make up the gaps
Both are still looking good regardless of the decal issues Stu :speak_cool:
cheers col, now in the gallery :)
33971724438_583c57bb2b_b.jpg 33971724648_09d1def22e_b.jpg 33971724638_7ff6b4773d_b.jpg
Nice silver finishes Stu and the Vampire looks particularly cool with the dayglo :coolio:
Is there a reason why you didn't fit the canopies before spraying the silver?
Cliff
