quangster
Kitty Hawk 1/48 RF-101C VOODOO... complete build
Hello gents,
Let me say it straight. I waited 50 years for this kit.
The RF-101 has been one of my favourite airplanes since, as a schoolboy, I saw one roaring over our home in Saigon like a giant lizard. So when last year Kitty Hawk released their 1/48 Voodoo, I knew the wait was over.
Of course, the kit is not perfect. People in forums complained about the multiple inaccuracies, the terrible fit, the bucketload of putty needed,… but then … this my chance of a lifetime to build it.
So I took the plunge and do what we, old timers, have always done: buy the kit, marvel at the box art, fondle the plastic, correct the mistakes, add some detail and voilà.
This is not a step-by-step WIP per se, rather some notes about problems I encountered, how I fixed them and also about the inaccuracies, how I corrected them. I hope some of you will find it helpful.
FIRST IMPRESSIONS
4824-B8-CE-5-FF1-4-B6-F-8-B77-90071-E5-A
The kit looks very nice: the light gray plastic is smooth, rather soft and easy to work with. The surface detail is delicate as are the panel lines. The parts are well moulded while being rather basic, are accurate and cry out to be detailed. The fit the main parts is very positive, no Tamiya but definitively Hasegawa. Like other new kits from China, the assembly is very precise – there is almost no tolerance. Parts have to be carefully prepared before gluing. Frequent dry fitting is a must!
Like with most recent kits, the instructions are drawings only – no text. I suggest you only use them to locate the parts. At any time do not follow the assembly sequence. Instead study the kit and the way the different components fit together. Make up your own assembly sequence.
Apart from the Eduard Interior photoetch set, I'm not using any aftermarket stuff.
Printed documentation come in two ancient magazines lent by old IPMS comrades. The main documentation comes from the internet.
Thank you for watching,
Quang
NEXT STEP: THE COCKPIT
Edited by quangster
Always loved the Voodoo, I wish I'd gotten to see one fly in the metal flesh like you did! I'll be watching with interest :D
Thanks for sharing the progress with us, Quang!
The terrible fit is misconception. With some patience the kit parts comes together perfectly.
And don’t use it as a painting reference - there’s something wrong with the research.
The detached flaps position in the instructions is also wrong. If you’re interested, take a look at this article: https://www.themodellingnews.com/2018/08/dry-fit-review-gary-puts-together.html?m=1
Looking forward to see your build.
Cheers! 😎
Nice to see the thread, Q.
I recall the Europe based RFs at airshows in the 60s but they were always simple fly pasts. I was lucky enough to see B-models departing and arriving during two visits to the Texas ANG in the late 70s/early 80s.
Martin
Edited by RidgeRunner
THE COCKPIT
is disappointing. I discarded the inaccurate IP and consoles and replaced them with good effect by Eduard printed photo etchings. I made a rubber shroud for the Instrument panel from scored tin foil.
AC513-F71-BF26-45-EF-A361-379-C6-D10562-
2662923-F-1-BB6-4-B4-B-A143-3404-D7-B506
The seat is rather good if a little bare. As it’s usually the focal point of attention, I decided to dress it up. I added a back parachute with restraints from Milliput, some wiring on the sides and the photo etched harness from the kit.
03-B65773-422-E-46-DC-804-D-80-D15-C28-F
AE19-E1-DD-E9-B1-4-BCC-8-A56-1-B6168-A45
The works
18-BC9-AFC-AE84-4344-943-B-D05-B0428-BEB
24-DCA8-EF-A454-4-D5-B-8-D7-F-AD8-E29-C5
A05-FC533-906-E-474-E-A701-57219653-F018
Hope you like it. All your questions and comments are welcome.
Thank you for watching.
Quang
NEXT STEP:: THE CAMERAs
Edited by quangster
It is because they are at rest and they thus sit slightly "reclined". It is the same for many aircraft. Look, for example, at the F-105, the F-100, etc. Having said that most do not sit with flaps down when parked, especially the Voodoo.
Martin
Good work, Quang. I have this set, but using it is a bit dubious to me. I’d prefer an unpainted etched parts and the decals over it.
Looks well! Have you tried to shape up shroud provided by Eduard? Also, notice that this IP is for later production RF-101Cs (SEA).
Yes, now it looks like a Weber seat! 👍
Forgot to tell you that the intake cones are black, and an intake trunks are aluminum for NMF and white for the SEA scheme airframes.
Cheers! 😎
@Nikolay Polyakov The Eduard IP is actually a very good replica of the real thing. I cannot guarantee the accuracy of the consoles but they look OK once the fuselage is buttoned up.
As for the shroud,it's easier for me to use tin foil than to try and shape up the Eduard etching.
Thanks for the tip on the intake cones.
Q
Another Voodoo build is always fascinating. Personally I don't recall seeing a recce bird, but pointy nosed single seaters aplenty, screaming overhead leaving prodigious trails of black smoke. Although rarely photographed, I have seen them carry 3 drop tanks as well. On with the good work.
@bentwaters81tfw Three drop tanks! Those were the days.
Back to the build. The focal point of  every recce bird is the camera window(s). What we get in the kit is a really sloppy interpretation ( the side cameras were even not facing the window!). So I decided to open up the camera windows and put in some lens behind.
7-C751707-2-DC6-41-D0-85-AE-1-D9678-C365
The cameras came from the KH 1/48 Photo Cougar, but for our purpose, some plastic tubes would do the trick. The 3 cameras were glued on a bulkhead inside the aircraft nose to make sure they are facing their respective window.
837-D416-F-704-A-4005-83-C9-52-E6-CD5-C2
A nice lens effect is achieved by a small drop of UV-cured glue.
D59-F05-A7-2530-4-E7-E-9859-1820-F6-FFF1
The cameras are dry-fitted to check their positions.
169-FD35-E-53-BE-48-A0-A9-B9-6-A2-DB33-B
49-B1-D077-8-A3-F-470-B-97-FE-23-F5-EE4-
47-F78-CE4-4340-418-B-B9-B6-8-E1-DB5-AB5
That’s all folks!. Questions and comments are welcome of course.
Quang
NEXT TIME: FRONT WHEEL WELLS
Great work with the cameras, Quang! 👍
As I remembered correctly, the front wheel well top side is green (FS34102), but the walls remain aluminum/silver. @bentwaters81tfw, Frank, correct me if I’m wrong.
Cheers! 🙂
Edited by Nikolay Polyakov
Thank you guys.
As for the wheel wells, I think the colouring varies depending on the period.
NMF and earlier Voodoo had their wells painted green and aluminium like you said. But in the SEA conflit, at the introduction of camouflage, wells were painted white.
8226-EC43-945-A-4-AA8-8245-214-F9-B42-B2
Anyhow that's what I did. Thin wires were added to the top side to simulate the numerous tubing.
As a side note, contrary to what the instructions say, you don't need to install the undercarriage at this stage. Leave it to the very end of the build.
130-D9171-E10-C-40-D3-9668-46-E65-C30-B0
21-C6-D5-A6-8542-4-F2-F-9-A3-B-A592-FD7-
410-EE805-FA22-44-A4-B371-530-B06016-E57
The front fuselage is finished and ready to be buttoned up.
Questions, comments, yadda yadda ...
Quang
NEXT STEP: REAR FUSELAGE
Great research, thanks!
Yes, the nose landing strut fits tight at the end of an assembly (before the doors attached).
Cheers! 😎
Moving on the rear fuselage.
Discard the instruction and assemble the entire tail, keel et al.
There's a clear cover with two navigation lights at the rear of the vertical fin. In all its weirdness, KH gives it to us as a solid part :headbang:
We'll replace it with a piece of plexiglas, glued in position, shaped up and polished. Two tiny holes in the plexi simulate the light bulbs.
2-AB196-DD-ACBA-4739-8-FF2-9-A5-B162710-
64578-B88-5685-41-FD-A39-E-5-A7-E71-E43-
B72-B8757-63-BE-4-D35-8-D28-1-D8-A4-FC4-
06-ECE249-672-C-4-D00-A0-F0-CA2-E19-A6-A
A piece of brass tubing is inserted on the leading edge of the fin to simulate the vent which distinguished the –C from the –A variant.
464-B8-E6-F-1864-4-D3-C-8-C97-97-EAE7-A9
52648-FEC-A744-48-C8-BA29-15-CE0-B222-B1
For a typical SEA conflict bird, RHAWS bumps are added to the nose...
AC21-E592-BFF7-4-E9-E-B021-1-DBEEC54-DA9
0-B083-A60-8-E73-42-DE-927-E-83602-F6-C5
B54-E54-DE-832-E-43-AC-B291-83608506-F6-
...and the tail.
7-DFF563-B-F93-A-4-F5-F-8332-6010-EB3-A6
9054-BC2-A-18-D7-418-F-BE69-A322-A449-D1
While we're at it, the drag chute cover is cut off. It will be posed open like on many photos of parked 101s.
702-BD121-2-D78-4981-B418-0781-DEF7-F628
That's all folks.
Thank you all for looking,
Have a good day,
Quang
Edited by quangster
And as the clear additional part in a «B» boxing.
Excellent results! 👍 I did mine from the clear sprue and it was boring.
Looks great, your work is superb on this Voodoo.
As you’re intended to make an air brakes in closed position, there is some little gap on the air brakes aft:
And some additional photos:
Cheers! 🙂
I'll tag ailing if I may, I remember seeing '101s ( andF100s ) when I was at an Air Cadet summer camp many years ago.
John
I’ve noticed the gap but in my obsession to obtain a seamless fit, I’m afraid the resulting gap is less apparent than I would like it to be. Like they say, better can be worse 🤢.
@Finn Terrific pics, Jari. They beat every other walkaround. Very useful for my build.
@Biggles87 Strangely the 101 makes a lasting impression on everyone who sees her. To me it was like the famous ‘Cadillac of the skies’ sequence in Spielberg’s film Empire of the Sun.
Thank you all for your input.
Sincerely,
Quang
She's coming along beautifully, Q
Perfect. It was rare to see parked Voodoos with brakes open. The same applies to the flaps. Remember also the parked tsilplane position.
M
M,
Brakes and flaps will be closed. It's a pity because they are well-detailed in the kit.
I have yet to decide about the tailplane position as it affects the opening on the rotation mechanism.
Your opinions are welcome.
Q
