fjaweijfopi4j48 Posted March 25, 2019 Posted March 25, 2019 A model (OOB) of the known Revell kit (that has its many shortcomings) from 2006 (13 years ago ) Yes, I built one too. who didn't. A nice kit overall, but many of its inaccuracies came to light after modelers started to build them. But let's not dwell on that. Instead, praises for Revell releasing a classic civil plane that had a very important role in aviation. Prolific designer Hugo Junkers built many flying machines from corrugated metal sheet that will influence other designers and entice them to follow the trend. This particular aircraft was a light transport used in many countries in land and sea configurations. The model Revell launched time ago into the market is also well designed and beautifully done. It offers the two options described above, with several decaling options, in long-run technology, which draw a sigh of relief from this modeler used to struggle -in order to satiate his appetite for arcane designs- with short-run spawns that require the best of you to arrive to a happy modeling end. A very nice interior is provided, and if you look carefully you may notice that the cowl that covers the engine -part of the upper fuselage slab- can be easily separated (there is a groove that runs on the back of the part) to pose it open if you so wish. To do that, though, you have to remove two small sections of the fuselage sides and attach them to the above-mentioned part. An engine is also provided, and the parts in general are well molded. I cut out one of the doors, which implied separating one of the fuselage sides -since the door runs from top to bottom-, hoping that general alignment wouldn't be difficult later. Elevator and rudder were scored and deflected. Plenty of images can be found on the Internet for reference. The pontoons were built, braced together and left aside. A few structural details were added to the front fuselage sides, the cowl and the firewall. The fuselage sides were partially assembled, the interior added and the remaining parts cemented. Since the sub assemblies were painted as much as possible, the exterior was next. In this issue Revell provides several options. I liked two very much: the version on floats and a colorful machine (DZ. 40) depicted on the box top. I finally went for the seaplane, but in this case I may be doing the other one too. Corrugated surfaces are not the best friend of modelers, but you may apply diluted filler or a liquid filling product and then carefully smooth things out with a cotton bud soaked in the correspondent thinner, which reduces sanding to a minimum. I then thinned the wing trailing edges a bit and cemented the wing halves, taking care of drilling the holes marked on the lower half and depicted in the instructions. Once the main sub assemblies were ready, a coat of black paint was airbrushed in preparation for the metal finish, but to my horror, I was out of Alclad II. I ended up using Testor's enamels, mixing aluminum and blue -just a tad of the last one-, applied chord-wise in shades. Then, after masking -I made a special mask photocopying the side of the fuselage and transferring the profile to masking tape- black paint was reapplied in the correspondent areas. All main assemblies were then put together, touched up, and the little fiddly things were added. A couple of Future coats, removal of the masks that covered the windows, and ready for the decals. The decal sheet is very generous and in good register, the images are beautiful, matt, and the whole thing is totally...useless. No matter what I did to them, they refused to blend into the corrugations. I ended up using Future as a decaling agent and getting close to a decent finish. So frustrating after all that work. I was able to find on the Internet some alternatives in JBOT decals, but didn't try them yet. Anyway, the somewhat cartoonish look of this attractive plane is a sight for delight, and a welcome option for those who want to explore further into the more arcane –and rewarding- subjects of aviation history. (Contemporary note: I have seen somewhere a corrective set of resin parts, but the price drove me away. This is one that I wouldn't mind building again, now that I have much more information on the type and gathered some nice colorful liveries) 35 1
Tweener Posted March 25, 2019 Posted March 25, 2019 I've got one of these in the stash I really should have gotten to by now, I've long thought it to be one of the better looking planes of it's day. With your talents, I'm surprised you haven't produced the Finnish F13s with radial engines. Perhaps in the future? 1
fjaweijfopi4j48 Posted March 25, 2019 Author Posted March 25, 2019 52 minutes ago, Tweener said: I've got one of these in the stash I really should have gotten to by now, I've long thought it to be one of the better looking planes of it's day. With your talents, I'm surprised you haven't produced the Finnish F13s with radial engines. Perhaps in the future? I have the file on it (so you guessed correctly). Some day.... Cheers
kapam Posted March 26, 2019 Posted March 26, 2019 A masterpiece for sure! I don't have the kit, but always rather liked it. Definitely a nice looking plane of the era. Brilliant job! 1
jeaton01 Posted March 26, 2019 Posted March 26, 2019 Yours is far nicer than mine, C. I scraped off the kit decals and replaced them with some made with my ALPS. Have you built the Revell 1/144 G-38 yet? 4
fjaweijfopi4j48 Posted March 26, 2019 Author Posted March 26, 2019 13 minutes ago, jeaton01 said: Yours is far nicer than mine, C. I scraped off the kit decals and replaced them with some made with my ALPS. Have you built the Revell 1/144 G-38 yet? John, 1/144? You know me better than that! Macramé before dishonor! 15 minutes ago, jeaton01 said: Yours is far nicer than mine, C. I scraped off the kit decals and replaced them with some made with my ALPS. Have you built the Revell 1/144 G-38 yet? I don't see anything wrong with your model! 1
roginoz Posted March 26, 2019 Posted March 26, 2019 Another masterpiece from Studio Moa !! I built mine in the Danzig scheme, and couldn't go past the "agricultural" landing gear. Painted the majority of the decalled area, next time I'll mask and paint the script as well. Looking out for another to do in this scheme to model as the floatplane........love floatplanes !! Rog 1
fjaweijfopi4j48 Posted March 26, 2019 Author Posted March 26, 2019 10 minutes ago, roginoz said: Another masterpiece from Studio Moa !! I built mine in the Danzig scheme, and couldn't go past the "agricultural" landing gear. Painted the majority of the decalled area, next time I'll mask and paint the script as well. Looking out for another to do in this scheme to model as the floatplane........love floatplanes !! Rog Post it!
pheonix Posted March 27, 2019 Posted March 27, 2019 Somehow when I used to build kits OOB they never looked half as good as this.... And I get the distinct impression that some of the internal details may have been slightly modified/added to... Lovely model of an important type. P 1
fjaweijfopi4j48 Posted March 28, 2019 Author Posted March 28, 2019 43 minutes ago, pheonix said: Somehow when I used to build kits OOB they never looked half as good as this.. I don't believe that, P 😉
occa Posted May 25, 2020 Posted May 25, 2020 Fantastic impressions from the past, oh and this time even an Österreichische theme The model is a delight to look at but that applies to all of your builds. 1
fjaweijfopi4j48 Posted May 26, 2020 Author Posted May 26, 2020 6 hours ago, occa said: Fantastic impressions from the past, oh and this time even an Österreichische theme The model is a delight to look at but that applies to all of your builds. Thanks! This is an old post, quoted just as reference.
sjsald Posted May 26, 2020 Posted May 26, 2020 This looks spectacular! Awesome and motivational work as always 1
fjaweijfopi4j48 Posted May 26, 2020 Author Posted May 26, 2020 13 minutes ago, sjsald said: This looks spectacular! Awesome and motivational work as always Old post, though. 1
Aces High Posted May 26, 2020 Posted May 26, 2020 It is a funny looking plane, you've made a great job of it, nice one! 1
invidia Posted May 26, 2020 Posted May 26, 2020 looks fantastic, inspiring me to get mine out of the stash. 1
