Elias
CMK Spitfire MkI Engine 1/48-Tamiya
Hello,
Does anybody knows if the CMK engine set for Tamiya's Spitfire MkI in 1/48 can be used for the new tool Spitfire?
38 minutes ago, Elias said:
Hello,
BY this, you mean a CMK set designed for the old tool Tamiya Mk.I fitting the new tool Tamiya Mk.I?
I'd suggest listing the part number for the set,  as that would explain better, ideally with a picture.
But, as a direct fit?  I'd think not, simply as the old tool Tamiya Mk.I is too wide, and resin sets tend to be made to fit a certain kit.
It maybe adaptable, but unless you really need it NOW, I'm sure a set will be done in time for the new tool kit anyway.
10 hours ago, Elias said:
I don't have the new tool Tamiya Mk.I, I do have the old tool, and spent some time comparing that, and correcting it dimensionally.
As it's too wide in the fuselage, the resin firewall will be too wide if it is made to fit the existing kit, if the new tool kit is now correct....
see here for more on the old tool Tamiya
Or another option would be to scratch your own firewall and modify the rest to suit, assuming that accuracy is not a major concern!
