Alan P Posted January 22, 2020 Share Posted January 22, 2020 19 minutes ago, stever219 said: The Airbus jets haven’t been subjected to airframe/power plant/systems changes that have significantly altered the aircraft handling characteristics in certain critical flight regimes that have then required a deliberately-concealed piece of software/hardware which can be disabled by a single failure to correct them. That's right. The degradation of control laws (a concealed piece of software that significantly alters handling characteristics possibly from a single failure) was built in from the beginning and is not accessible by the pilots, which is why Airbus aircraft feature disproportionately in upset and LOC-I incidents, and still do. Software 'upgrades' and additional training has been and still is necessary with each new or repeated incident. The Airbus philosophy has been to make the handling of each member of the family as near to that of the others that, whichever jet they are flying, crews can respond instinctively to any given upset without having to go through several pages of the QRH or FCOM to find a nearly-concealed check list. The whole point is that pilots CAN'T react instinctively to Airbus flight instrumentation degradation without specific training as the cues are all given through the visual channel - there is no analogue feedback through control forces or positions. It requires specific and ongoing training for pilots to recognise and handle degradation and instrument disagreement, which can be caused by a single failure, like an ADC or sensor. Control and instrumentation failures are not Airbus-specific issues, but pretending that Airbus aircraft have all these things ironed out is denying reality. 1 Link to comment Share on other sites More sharing options...
JohnT Posted February 19, 2020 Share Posted February 19, 2020 BBC reporting further issues with the 737 Max production. FO in the fuel tanks found in stored aircraft. I dont know how much of an issue that really is - not enough knowledge on my part - or if its just newspaper alarmism in the sense that these things can happen and are routinely dealt with - or is it something that should never happen in production. I'd bet on the latter but have a scepticism on journalism these days. No doubt wiser and more knowledgeable heads than mine will advise https://www.bbc.co.uk/news/business-51499777 Link to comment Share on other sites More sharing options...
Paul Bradley Posted February 19, 2020 Share Posted February 19, 2020 To quote form the article: "The head of Boeing's 737 programme has told employees that the discovery was "absolutely unacceptable"." If the head of the 737 programme feels the need to address this in these terms, it's an issue. Link to comment Share on other sites More sharing options...
NoSG0 Posted February 19, 2020 Share Posted February 19, 2020 (edited) Dilemma over 737 wiring. Where does Airbus get it's wiring from? https://www.seattletimes.com/business/boeing-aerospace/faa-faces-dilemma-over-737-max-wiring-flaw-that-boeing-missed/?utm_source=twitter&utm_medium=social&utm_campaign=article_inset_1.1 Edited February 19, 2020 by NoSG0 Link to comment Share on other sites More sharing options...
EwenS Posted February 19, 2020 Share Posted February 19, 2020 5 hours ago, JohnT said: BBC reporting further issues with the 737 Max production. FO in the fuel tanks found in stored aircraft. I dont know how much of an issue that really is - not enough knowledge on my part - or if its just newspaper alarmism in the sense that these things can happen and are routinely dealt with - or is it something that should never happen in production. I'd bet on the latter but have a scepticism on journalism these days. No doubt wiser and more knowledgeable heads than mine will advise https://www.bbc.co.uk/news/business-51499777 Same issue was found last year on KC-46 leading to the USAF stopping accepting them. https://www.airforcetimes.com/news/your-air-force/2019/04/02/air-force-again-halts-kc-46-deliveries-after-more-debris-found/ 1 Link to comment Share on other sites More sharing options...
stever219 Posted February 19, 2020 Share Posted February 19, 2020 (edited) 5 hours ago, NoSG0 said: Dilemma over 737 wiring. Where does Airbus get it's wiring from? https://www.seattletimes.com/business/boeing-aerospace/faa-faces-dilemma-over-737-max-wiring-flaw-that-boeing-missed/?utm_source=twitter&utm_medium=social&utm_campaign=article_inset_1.1 It’s not so much where the wiring comes from but how it is routed and bundled within the aircraft. In the 737MAX there is a bundle containing a “hot” wire routed close to two “cold” wires which are part of the tailplane trim system. The concern is that chafing within the bundle could lead to arcing from the “hot” wire to either or both of the “cold” tailplane trim wires which could produce rapidly alternating nose up and nose down signals to the tailplane motor which the pilots might not be able to override. Some of the Boeing hierarchy deem this to be a low-probability event but an RAF Puma, IIRC, was lost as a result of very similar damage to part of its wiring loom leading to the power supply for a flashing anti-collision light feeding spurious alternating pitch demands to the main rotor cyclic controls. Eventually the uncommanded control inputs caused one of the main rotor blades in the rear arc of their travel to lower sufficiently to strike the tail boom and disrupt the tail rotor drive shaft. All too often aviation has demonstrated the ability of lightning to strike in the same way more than once... It remains to be seen whether the FAA will compel Boeing to do something about this or not. Apparently very similar wiring has been used on the 737NG with no reported failures, yet, and Boeing will probably rely on that to get a laissez-faire decision from the FAA. Boeing has so far failed to heed the FAA’s ruling that the rudder cables on 737s should be separated in order to increase survivability in the event of structural damage as it hasn’t resulted in an accident yet/recently. The conspiracy theorists can have a field day with how much influence Boeing has on and over the denizens of Capitol Hill and the White House (Trump, after all, has a blinged-out 757) and thereby the FAA, even though the USAF has possibly fallen out of love with the company over the delays, cost overruns and quality control issues in the KC-46A programme. EASA, and other airworthiness authorities, may not follow the FAA’s lead even if the latter does recertificate the 737 MAX 8 and even though Trump is already instigating a trade war with Europe which includes duties on civil aircraft. A retaliatory duty charge by Europe can only do further damage to Boeing which the company presently can ill afford. Apparently KLM is considering abandoning its plans for an all-Boeing fleet and is sizing up the A321 as a potential 737/737 MAX successor but Airbus could be very hard pushed to increase production rates even allowing for them having four assembly sites, one of which is in America, for the A318/319/320/321 family whilst maintaining quality. It’s probable that any entirely new site would take four to five years to come on stream, by which time Boeing might just have got the MAX 8 can of worms back into its bag of nails. Edited February 19, 2020 by stever219 4 1 Link to comment Share on other sites More sharing options...
NoSG0 Posted February 20, 2020 Share Posted February 20, 2020 Let us all hope that if the FAA does not force a fix that nothing serious happens. Link to comment Share on other sites More sharing options...
stever219 Posted February 20, 2020 Share Posted February 20, 2020 (edited) On 2/20/2020 at 1:52 AM, NoSG0 said: Let us all hope that if the FAA does not force a fix that nothing serious happens. That's their dilemma; if they force a fix it will cost Boeing and their MAX customers dear which will lead to higher fares for the travelling public at the very least. If they don't force a fix and people are hurt or killed as a result the ambulance-chasers' feeding frenzy will have to be seen to be disbelieved and there will be higher fares for the travelling public. Also the FAA's credibility as a regulatory authority will be seriously compromised. Damned if they do damned if they don't.... Edited February 23, 2020 by stever219 Sppelinn Link to comment Share on other sites More sharing options...
Paul Bradley Posted February 20, 2020 Share Posted February 20, 2020 (edited) At this point, the FAA's credibility as a regulatory authority has already been seriously compromised - the relationship with Boeing has been exposed as being far too cozy, and their failure to take serious action on airline maintenance and safety issues is appalling. This country has been forced into a Wild West situation where the federal government and its agencies are forced to abdicate their authority and credibility to the interests of cold hard cash. Edited February 21, 2020 by Paul Bradley 4 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 20, 2020 Share Posted February 20, 2020 21 hours ago, NoSG0 said: Dilemma over 737 wiring. Where does Airbus get it's wiring from? Airbus at Broughton in North Wales Trevor 1 Link to comment Share on other sites More sharing options...
stevehnz Posted February 21, 2020 Share Posted February 21, 2020 18 hours ago, Paul Bradley said: This country has been forced into a Wild West situation where the federal government and its agencies are forced to abdicate their authority and credibility to the interests of cold hard cash. Sounds a lot like the basis of Neo Liberal Economics, where making a buck (trumps *) overules ethics, humanity, safety, & morals. The 737Max thing couldn't or shouldn't have happened without it. Steve. * probably an apt choice non-the less. 7 Link to comment Share on other sites More sharing options...
stever219 Posted February 21, 2020 Share Posted February 21, 2020 On 2/20/2020 at 12:34 PM, Paul Bradley said: At this point, the FAA's credibility as a regulatory authority has already been seriously compromised - the relationship with Boeing has been exposed as being far too cozy, and their failure to take serious action on airline maintenance and safety issues is appalling. This country has been forced into a Wild West situation where the federal government and its agencies are forced to abdicate their authority and credibility to the interests of cold hard cash. I was trying to be polite and diplomatic, which is unusual for me. I’ve often thought that the relationship between Boeing and the FAA was a bit too cosy for comfort. 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 22, 2020 Share Posted February 22, 2020 More... https://www.google.co.uk/amp/s/fortune.com/2020/02/21/boeing-737-max-warning-light-new-faa-fines/amp/ and more.... https://www.google.co.uk/amp/s/www.bloomberg.com/amp/news/articles/2020-02-22/boeing-suspends-co-workers-of-pilot-at-center-of-max-scrutiny Boeing must really have no more hair to collectively tear out at this point. Will there come a point when Boeing throws its hands up and give up on the Max? I assume it’ll be the bean counters who will have the final say on that point. Trevor Link to comment Share on other sites More sharing options...
bzn20 Posted February 22, 2020 Share Posted February 22, 2020 It's the routing of the wiring that's the problem . The wiring used is fire resistant and used all over the aircraft industry. Link to comment Share on other sites More sharing options...
Jure Miljevic Posted February 23, 2020 Share Posted February 23, 2020 Hello Trevor I agree MAX's fate is going to be decided by the bean counters. However, if somehow the type makes it to the air again it is almost inevitable that this same group will eventually try to push through yet another new version of 737. As Steve said, it is basic neo-liberalism: they got away with it more than once, so why not try it again? Of course, I do hope this reasoning of mine is just a product of my cynicism, which had been amplified by a night-long reading of many variations on Murphy's law. Cheers Jure 1 Link to comment Share on other sites More sharing options...
EwenS Posted February 23, 2020 Share Posted February 23, 2020 Of course it will be made to fly again. The bean counters will see to that for sure. If it doesn’t then Boeing will be bankrupt. 387 B737 MAX delivered to airlines and sitting idle. Approx 400 undelivered sitting in the desert somewhere. Another 4000+ orders taken (on which some money will probably have changed hands to at least some degree). Boeing has already provided $19 billion for the 737MAX problems leading to its first financial loss in more than 20 years. If it is scrapped how much more has to be written off / repaid? If Boeing goes bankrupt then the US has a major defence problem. It looks to me like the US Govt already recognises that. Look at the talk of new F-15EX orders the day before Boeing made the announcements of losses. Cynical me says the two are connected. The share price actually rose in the immediate aftermath of those announcements, only to fall again. Put simply Boeing is too big and important to the US economy to be allowed to fail. Also, where else are the airlines going to get these 5000 new clean fuel efficient aircraft in the short term? Airbus? They already have an extensive back order list for A319/320/321 despite having 4 factories churning them out. >6000? In an attempt to increase production, the A380 space is being turned over to A321 production, according to what I read recently. 3 Link to comment Share on other sites More sharing options...
stever219 Posted February 23, 2020 Share Posted February 23, 2020 (edited) YWith so much media attention on the 737 Max 8 issues the maiden flight of the 777X has gone almost unremarked upon. However it appears that Boeing is trying to certificate this (sub) type using the same “grandfather” rules that allowed the 737 Max 8 certification. Boeing is basing their approach on the twenty-year-old data submitted for the 777-200. That might not be too bad, but the X has an entirely different wing built from a completely different material and with folding tips (I believe that at one point these were considered for the -200 but dropped due to reasons of potential lack of public acceptance). The engines, avionics, systems are different and even the cabin windows are a different size. The FAA is in an unenviable position with this programme, if they allow the certification under “grandfather” rules and there’s an accident involving deaths, injuries and or significant damage to property whoever signs off the certification will be hung out to dry. On the other hand if they make Boeing jump through the hoops for a new type that will increase the programme costs and put a major US defence contractor and revenue-generator at risk for years to come and whoever dictates that course of action will probably be manning a radar tower in Alaska very early the next morning. Edited February 24, 2020 by stever219 3 Link to comment Share on other sites More sharing options...
NoSG0 Posted February 24, 2020 Share Posted February 24, 2020 (edited) A thread on 777x changes https://www.airliners.net/forum/viewtopic.php?f=3&t=1441751&sid=ec34b7dd74971aee41e4c23da286e263 I think all the worldwide Certifying Authorities are likely under a magnifying glass because of the agreements to accept each others approvals. Should another hull loss occur with questionable decisions made by BA coming out after the fact, then I think that will be the end of these agreements. JMHO Edited February 24, 2020 by NoSG0 1 Link to comment Share on other sites More sharing options...
NoSG0 Posted March 5, 2020 Share Posted March 5, 2020 (edited) More training may be required for pilots than originally thought. https://www.claimsjournal.com/news/national/2020/03/02/295757.htm I've read on a A.net, PPRUNE that sim time training has been cut back by the airlines? This seems like a bad idea to me. Do not the airlines have a responsibility to ensure that pilots(via training) can correctly assess and take corrective actions? Edited March 5, 2020 by NoSG0 1 Link to comment Share on other sites More sharing options...
stevehnz Posted March 5, 2020 Share Posted March 5, 2020 A good article that, maybe we're seeing a way forward. Steve. Link to comment Share on other sites More sharing options...
Agent K Posted March 5, 2020 Share Posted March 5, 2020 5 hours ago, NoSG0 said: More training may be required for pilots than originally thought. https://www.claimsjournal.com/news/national/2020/03/02/295757.htm I've read on a A.net, PPRUNE that sim time training has been cut back by the airlines? This seems like a bad idea to me. Do not the airlines have a responsibility to ensure that pilots(via training) can correctly assess and take corrective actions? Airlines will provide and manage sim and line flying to the required level to achieve type authorisation. If anything I believe (at least major/international) airlines have increased sim training hours vs. line flying? I'm not sure how to interpret what you highlight, or what is being suggested? as always the statements need to be interpreted with a full understanding! 1 1 Link to comment Share on other sites More sharing options...
Alan P Posted March 5, 2020 Share Posted March 5, 2020 On 2/23/2020 at 7:32 PM, stever219 said: Boeing is basing their approach on the twenty-year-old data submitted for the 777-200. That might not be too bad, but the X has an entirely different wing built from a completely different material and with folding tips (I believe that at one point these were considered for the -200 but dropped due to reasons of potential lack of public acceptance). The engines, avionics, systems are different and even the cabin windows are a different size. The 787 (completely different aeroplane) is already on a common type rating with the 777 so that's not going to be a problem. The issue here is not with the manufacturers, or even the regulators. It's just plain old capitalism. Link to comment Share on other sites More sharing options...
Alan P Posted March 5, 2020 Share Posted March 5, 2020 7 hours ago, NoSG0 said: I've read on a A.net, PPRUNE that sim time training has been cut back by the airlines? This seems like a bad idea to me. Do not the airlines have a responsibility to ensure that pilots(via training) can correctly assess and take corrective actions? It's not so much time has been cut back, it's more about making efficient use of sim/ground training time to get the most out of training. Historically, a typical European airline training schedule would be three or four days every six months, of which two days would be sim training and the other day(s) in the classroom doing technical refreshers and SEP training with cabin crew. In addition to that you'd have a line or route check annually on a normal operational flight. The ground tech training day has mostly disappeared in favour of online examinations, so that's a day saved. The SEP is only once a year, so it boils down to those two days in the sim. It has evolved over the past ten years into less checking and more training, or incorporating more line-oriented flying as part of the assessment. This is because the standard LPC check is so predictable and regimented that most of us can fly it in our sleep yet it takes up half of our allocated sim time. To help make this more efficient, the sim schedule is being adjusted to actually allow for more training time, not less. Airlines and other training organisations are actually putting far more time and emphasis on flying the aeroplane. This is because of incidents like the AF447 and 737 Max among many many others. The leading cause of aircraft accidents is now loss of control, and has been for five years. This is the focus of most modern training and is the fruit of all those warnings from decades ago that pilots relying too much on automation would gradually lose their feel for flying. So (as a trainer) I'd have to respectfully disagree with the people on the aforementioned forums and say training is more focused and effective nowadays even with the more efficient sim schedules than when I started 20 years ago. 3 1 Link to comment Share on other sites More sharing options...
Agent K Posted March 5, 2020 Share Posted March 5, 2020 48 minutes ago, Alan P said: It's not so much time has been cut back, it's more about making efficient use of sim/ground training time to get the most out of training...….. Interesting insight and thanks for sharing. As always things are not as easy as a bold statement believes and as you illustrate it's not just about pure sim time, it's about the overall training package. With over 30 years in the airline business I have seen how these things have progressed, especially training and technology and the use of. 1 Link to comment Share on other sites More sharing options...
bzn20 Posted March 6, 2020 Share Posted March 6, 2020 As well as the 737 MAX saga and airlines already suffering because of the MAX delivery delays . Now add the drop in people flying and some route slashing already due to Coronavirus . Airlines are really in a bad place . Will they be wanting to defer any deliveries ( if it ever happens) . The Coronavirus has tipped one airline that was already teetering over the edge , how many more ? Summer holiday flight cancelations haven't started yet either . Can anyone see the Olympics going ahead ? Just saying . 2 Link to comment Share on other sites More sharing options...
