Col. Posted June 30, 2019 Share Posted June 30, 2019 Oooh that's nice! A lot of work perhaps but the harness looks great Will make a nice centre-piece within the cockpit. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted July 1, 2019 Share Posted July 1, 2019 it does look rather nice but wow complex!! 1 Link to comment Share on other sites More sharing options...
Marlin Posted July 1, 2019 Share Posted July 1, 2019 Real nice work Werner. Can't wait until I can start my own. The CWS set was shipped from Bulgaria yesterday, so perhaps in a fortnight from now I can start it. /Bosse 1 Link to comment Share on other sites More sharing options...
exdraken Posted July 1, 2019 Author Share Posted July 1, 2019 thanks guys, I actually planned to do the rest of the decals yesterday.... stencils I mean .. and lots of them... instead I tried to train seatbelts to stay calm and relaxed on an ejection seat I also will do some work to the seat base color, I think it is a bit too dark now..... 7 Link to comment Share on other sites More sharing options...
IPMS19 Posted July 1, 2019 Share Posted July 1, 2019 - I'm not sure to be ready to spent hours trying to get the best of this CWS part of the transkit owing to the tiny size of those buckles and straps even if I recognise it is an upmost adding to get an exceptionnal looking seat. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted July 1, 2019 Share Posted July 1, 2019 Awesome work on the seat Werner, that really does look fantastic. Your build is really nice and those KH-58's look like they would do some serious damage. Link to comment Share on other sites More sharing options...
exdraken Posted July 2, 2019 Author Share Posted July 2, 2019 23 hours ago, IPMS19 said: - I'm not sure to be ready to spent hours trying to get the best of this CWS part of the transkit owing to the tiny size of those buckles and straps even if I recognise it is an upmost adding to get an exceptionnal looking seat. not sure myself if I'd do it again.... Eduard Steel seatbelt are also very nice..... just that I only had some for the PD... not sure if also appropriate and as time is running out I took out the scissors and some tranquilizers to thread the straps into the buckles..... 22 hours ago, modelling minion said: Your build is really nice and those KH-58's look like they would do some serious damage. indeed! and 4 of them! how accurate they where/ are will probably remain a mystery though! but they where also used with the Su-17/22. and a special targeting pod (Vjuga) https://i729.photobucket.com/albums/ww293/binhbeo78/53-kh-58.jpg the West should be quite aware of this capability! I assume though that a Mach 1.5 -Mach 2.5 launch velocity capability would add some punch and element of surprise! whatever, some decals: lots of stencils on the pylons as well--- times 4 adds a lot of decaling time to my tight schedule! luckily some of them are grouped, and the behave quite wonderfully! great job Begemot! but worth the effort i'd say! 6 Link to comment Share on other sites More sharing options...
Marlin Posted July 2, 2019 Share Posted July 2, 2019 Love the missiles Werner. Good job on the stencils too. /Bosse Link to comment Share on other sites More sharing options...
exdraken Posted July 3, 2019 Author Share Posted July 3, 2019 daily updates now..... if not -->> stencils are a mix of BEgemot, Revell and ICM 4 Link to comment Share on other sites More sharing options...
trickyrich Posted July 3, 2019 Share Posted July 3, 2019 she's all coming together nicely now, won't be long before she's in the gallery, am looking forward to that. Link to comment Share on other sites More sharing options...
Col. Posted July 4, 2019 Share Posted July 4, 2019 Certainly worth the effort Werner Link to comment Share on other sites More sharing options...
exdraken Posted July 5, 2019 Author Share Posted July 5, 2019 some weathering.... did use a new method.. an acylics wash...that I left on for a bit too long.. so I had to remove it with quite some solvent and force..... ok, heavy weathering 4 Link to comment Share on other sites More sharing options...
IPMS19 Posted July 5, 2019 Share Posted July 5, 2019 1 hour ago, exdraken said: some weathering.... did use a new method.. an acylics wash...that I left on for a bit too long.. so I had to remove it with quite some solvent and force..... ok, heavy weathering - - Looks good Werner, the joint between resin nose and plastic fuselage this side seems difficult. I have problem with the painting of the missiles, it didn't stand the masking I have to strip all the remaining paint off , spray a primary and paint again , before begining working on them I had dipped them in klir but this time it didn't work I should have cleaned them and all their fins more seriously before , I fear it will be the same for the nose, I don't want to have the same problem once the model almost finished. 2 Link to comment Share on other sites More sharing options...
exdraken Posted July 5, 2019 Author Share Posted July 5, 2019 52 minutes ago, IPMS19 said: - - Looks good Werner, the joint between resin nose and plastic fuselage this side seems difficult. I have problem with the painting of the missiles, it didn't stand the masking I have to strip all the remaining paint off , spray a primary and paint again , before begining working on them I had dipped them in klir but this time it didn't work I should have cleaned them and all their fins more seriously before , I fear it will be the same for the nose, I don't want to have the same problem once the model almost finished. the joint is probably my fault I even redid it but not to my full satisfacion! especially in certain lighting conditions! ... the other side looks good I did not have problems with lifting paint fortunately, I only used revell enamels as a base. but I took more care when removing mask etc on the resin parts. I washed them before though. the same goes for the missiles. I used Tamiya tape mostly, 4 1 Link to comment Share on other sites More sharing options...
IPMS19 Posted July 5, 2019 Share Posted July 5, 2019 1 hour ago, exdraken said: the joint is probably my fault I even redid it but not to my full satisfacion! especially in certain lighting conditions! ... the other side looks good - I've had the same problem with this part of the nose, I've used some cyano as putty but it requires a lot of sanding and I still have problem at the left base of the winscreen as cyano is not clear plastic friendly. I will post the result in some days as I want to show the camouflaged bort white 37 but I still have not enough photos mostly of the left side as it look rather different from the right and I have to wait the weather becoming cooler for the paint. 2 Link to comment Share on other sites More sharing options...
Greg Law Posted July 5, 2019 Share Posted July 5, 2019 Looks really realistic. I've seen these birds looking exactly like that. It is one of the planes I have personal dislike for because of what it has been used for in current times. However, your model looks excellent. Link to comment Share on other sites More sharing options...
trickyrich Posted July 5, 2019 Share Posted July 5, 2019 12 hours ago, IPMS19 said: - - Looks good Werner, the joint between resin nose and plastic fuselage this side seems difficult. I have problem with the painting of the missiles, it didn't stand the masking I have to strip all the remaining paint off , spray a primary and paint again , before begining working on them I had dipped them in klir but this time it didn't work I should have cleaned them and all their fins more seriously before , I fear it will be the same for the nose, I don't want to have the same problem once the model almost finished. for resin bits try giving them a really good wash in bleach first, then prior to painting give the resin bits (and everything else for that matter) and good wipe over with enamel thinners (test it on the plastic first, some stuff will eat plastic) or alcohol. That should help with paint lifting. It does look good!! I really have to get one of these! 1 Link to comment Share on other sites More sharing options...
IPMS19 Posted July 6, 2019 Share Posted July 6, 2019 7 hours ago, trickyrich said: for resin bits try giving them a really good wash in bleach first, then prior to painting give the resin bits (and everything else for that matter) and good wipe over with enamel thinners (test it on the plastic first, some stuff will eat plastic) or alcohol. That should help with paint lifting. It does look good!! I really have to get one of these! - Thanks, I dipped the parts in a solvent bath whichdo not affect resin and sprayed an universal primer I think it will be enough,it is the first time I have to face this kind of problem, I read it many time on diverse forum but to thise days I always escape it. I have to say that I use acrylics paints only is this reason....can't tell.... Link to comment Share on other sites More sharing options...
exdraken Posted July 6, 2019 Author Share Posted July 6, 2019 last update I suppose: everything mounted antenna wise, ebgine wise, etc.... I even painted some germetika... so hopefully tomorrow, a final clear coat and photos for THE gallery! 4 Link to comment Share on other sites More sharing options...
trickyrich Posted July 6, 2019 Share Posted July 6, 2019 so close!!! Looking forward to finally seeing her in the gallery. Link to comment Share on other sites More sharing options...
IPMS19 Posted July 7, 2019 Share Posted July 7, 2019 - Just order the missile section to install Kh 58 under the wings and ready to go for another mission. Your FOXBAT is very good Werner....congrats.... -O.K but now the show must go on, which is your next project ,? another flying machine ? some lazy days on a sunny beach ? a trek in Austrian moutains ? or simply doing nothing just watching the birds flying, Whatever have nice time my friend.. 1 Link to comment Share on other sites More sharing options...
exdraken Posted July 7, 2019 Author Share Posted July 7, 2019 (edited) 7 hours ago, IPMS19 said: - Just order the missile section to install Kh 58 under the wings and ready to go for another mission. Your FOXBAT is very good Werner....congrats.... -O.K but now the show must go on, which is your next project ,? another flying machine ? some lazy days on a sunny beach ? a trek in Austrian moutains ? or simply doing nothing just watching the birds flying, Whatever have nice time my friend.. and the some work in the pit... and .... taking photos! next project? - Phantom GB Spanisch RF-4C CR,12...... then there is an IL-28 waiting next to me...... and 2 youngsters that need even more attentions gallery entry can be found here, with lot more great finishers to encounter canopy is quite small but highly transparent fortunately if course can open the canopy as well: thanks everybody for 4 pages of support! cheers, Werner Edited July 7, 2019 by exdraken 7 Link to comment Share on other sites More sharing options...
IPMS19 Posted July 7, 2019 Share Posted July 7, 2019 3 hours ago, exdraken said: and the some work in the pit... and .... taking photos! next project? - Phantom GB Spanisch RF-4C CR,12...... then there is an IL-28 waiting next to me...... and 2 youngsters that need even more attentions gallery entry can be found here, with lot more great finishers to encounter canopy is quite small but highly transparent fortunately if course can open the canopy as well: thanks everybody for 4 pages of support! cheers, Werner - These Foxbat, a real monster of a beast.......You've rally got it..... 2 Link to comment Share on other sites More sharing options...
helios16v Posted July 7, 2019 Share Posted July 7, 2019 Nicely done. I've got my eye on one of the ICM Recce beasties. This build only feeds that itch. 1 Link to comment Share on other sites More sharing options...
Greg Law Posted July 7, 2019 Share Posted July 7, 2019 Excellent finish on this ugly bird. You've made it so well I almost like it.👍 1 Link to comment Share on other sites More sharing options...
