Matt P Posted March 11, 2019 Share Posted March 11, 2019 Just as I was on the home straight and applying the final coat of Tamiya semi gloss clear this happened! Never happened before and I am at a loss as to why. Black paint was from Xtracrylix, then a coat of klear after the decals were applied. Then lastly a coat of Tamiya semi gloss thinned with Tamiya thinners. Bang, white marks all over the model. Any ideas please? Those of a sensitive disposition may want to look away 9 Link to comment Share on other sites More sharing options...
eng Posted March 11, 2019 Share Posted March 11, 2019 Not experienced this personally but looks like the Tamiya Thinners may have reacted with the Klear I personally only ever use Humbrol Acrylic rattle cans for the final varnish coats, I know that doesn't help here but might be worth trying next time round. Don't bin the kit though. Rub it back and have another go at it, I've got a couple of spare Revell GR.1 decals sheets if you want one. Eng 1 1 Link to comment Share on other sites More sharing options...
TallBlondJohn Posted March 11, 2019 Share Posted March 11, 2019 Fantastic frost effect - just add some strategic snow. Seriously, if you'd said that was the effect you were trying to achieve my jaw would have fallen off. 2 Link to comment Share on other sites More sharing options...
Martian Posted March 11, 2019 Share Posted March 11, 2019 Mr Muscle time methinks. Martian 👽 1 Link to comment Share on other sites More sharing options...
Wonky Donkey Posted March 11, 2019 Share Posted March 11, 2019 Has it affected the black paint, or is it like a "dust" you can rub off? I had a similar thing on a Ford Model T recently, and had not used klear or such - just tamiya clear over tamiya paints - most of the "frosting" wiped off when dry. Most, I should emphasise, not all. And yours looks "worse", if you see what I mean.. M Link to comment Share on other sites More sharing options...
ArmouredSprue Posted March 12, 2019 Share Posted March 12, 2019 It looks like you probably didn't mix the Tamiya semi gloss properly. It looks like the flat compound is too much. I would try to re-spray a Clear coat and see if it returns to previous state. and than try the semi-gloss again. 2 Link to comment Share on other sites More sharing options...
StephenCJ Posted March 12, 2019 Share Posted March 12, 2019 In Australia this wonderful effect is called 'blooming'. An EXsPERT has told me it is caused by a sudden change of temperature or humidity and or high humidity. This has happened to me recently when I sprayed a coat of clear gloss on a completed model, I sprayed on a bright sunny day but the humidity was very high, Solution: Swear, Swear, Swear and repaint or build another model. You could talk to a auto painter (that's where my expert came from). My 2 cents worth. Stephen 1 1 Link to comment Share on other sites More sharing options...
Sturmovik Posted March 12, 2019 Share Posted March 12, 2019 Try making it as part of an airfield in "The Day After Tomorrow," you know, where the entire UK was frozen solid by that mild winter. Link to comment Share on other sites More sharing options...
Jackman Posted March 12, 2019 Share Posted March 12, 2019 If it's any consolation, those decal markings come in Italeri's Tornado "Special Colors" kit: https://www.italeri.com/uploads/products/1336_profiliLR.jpg https://www.italeri.com/en/prodotto/2243 So you could just use this 'frosted' kit as a paint mule and build another Tornado or find someone who will donate those decals to you while you sand/strip the frost away from this one. My advise would be to use paint/clear from the same brand (eg Tamiya black paint followed by Tamiya Gloss -> decals on -> Tamiya SemiGloss). 1 Link to comment Share on other sites More sharing options...
Papa Delta Posted March 12, 2019 Share Posted March 12, 2019 Spray it with clear gloss. I had this happen before. Somehow the clear finish frosted on me. Someone told me to try it and it worked. Link to comment Share on other sites More sharing options...
NAVY870 Posted March 12, 2019 Share Posted March 12, 2019 Humbrol gloss coat sprayed a bit on the wet side should see you right. Just be gentle 1 Link to comment Share on other sites More sharing options...
perdu Posted March 12, 2019 Share Posted March 12, 2019 I had that on my first, of the present era, Wessex HC2 I was spraying a matt coat overall when the dark NATO Gren undersides went grey overall and induced panic I did get rid of mine by stiffbrushing Klear into the scummy surface eventually, it seems to be induced by using dis-similar products If there is a noticeable change in temperature or humidity. The reglossing route is worth a try before you do anything drastic Looks like a lovely Tonka inside there Link to comment Share on other sites More sharing options...
IPMS19 Posted March 12, 2019 Share Posted March 12, 2019 - I would follow armouredSprue solution, but if this doesn't work , I'm afraid the only solution will be to strip of paint the whole thing to bare plastic ,buy new decal and paint it again..... -Just an idea ,for my models I don't use dedicated varnishes for long now, but artist painters arcrylics varnishes like Pebeo for instance. They are far cheaper and in far larger rattle can than modelling dedicated products. Link to comment Share on other sites More sharing options...
Matt P Posted March 12, 2019 Author Share Posted March 12, 2019 10 hours ago, Papa Delta said: Spray it with clear gloss. I had this happen before. Somehow the clear finish frosted on me. Someone told me to try it and it worked. Well I gave the underside a blast with some rattle can Halford gloss clear varnish and....................... Hey presto the frosting completely disappeared! Thanks for the tips guys 👍. Managed to destroy a few decals when it first happened and tried washing it in a blind panic, but I think I can replace most from the stash. Sighs of relief all round 😁 6 1 Link to comment Share on other sites More sharing options...
perdu Posted March 12, 2019 Share Posted March 12, 2019 phew and hooray tip noted Link to comment Share on other sites More sharing options...
J.P. Posted March 12, 2019 Share Posted March 12, 2019 40 minutes ago, Matt P said: Well I gave the underside a blast with some rattle can Halford gloss clear varnish and....................... Hey presto the frosting completely disappeared! Thanks for the tips guys 👍. Managed to destroy a few decals when it first happened and tried washing it in a blind panic, but I think I can replace most from the stash. Sighs of relief all round 😁 Whew!!! Good save. Link to comment Share on other sites More sharing options...
thorfinn Posted March 12, 2019 Share Posted March 12, 2019 It's the same effect that occasionally happens when applying setting solutions over an acrylic clear coat. It's seriously horrifying the first time it happens...but as you discovered, the fix is fairly simple. Happy for your 'save'! Link to comment Share on other sites More sharing options...
Terry1954 Posted March 12, 2019 Share Posted March 12, 2019 Wow, sounds like you may have solved it, well done. I had a similar "disaster" a few months ago when some well tried and trusted "washes" for weathering, acted completely out of character. Took a while and some hard work to rectify. Modelling has these moments 😨 Terry Link to comment Share on other sites More sharing options...
corsaircorp Posted March 12, 2019 Share Posted March 12, 2019 Holy molly, I experienced the same thing twice Gently sand with the fine files. Sorry for you ! Sincerely. CC Link to comment Share on other sites More sharing options...
Torbjorn Posted March 12, 2019 Share Posted March 12, 2019 It really does look like frost. Would have loved to have the exact recipe of this disaster! Link to comment Share on other sites More sharing options...
Matt P Posted March 13, 2019 Author Share Posted March 13, 2019 13 hours ago, Torbjorn said: It really does look like frost. Would have loved to have the exact recipe of this disaster! Me too! I spent ages trying to get a winter finish like this on a tank diorama a while back and never got it this good. Link to comment Share on other sites More sharing options...
planehazza Posted March 13, 2019 Share Posted March 13, 2019 I don't wish to have a go or insult anyone's choices, but this is why I personally cringe whenever I hear people using floor polish as a modelling varnish. It may work for many, but to me, it's meant for floors, not models. Shame it's happened right at the end, but as said above, it gives a good frost effect if were inclined to not fix it Link to comment Share on other sites More sharing options...
J.P. Posted March 13, 2019 Share Posted March 13, 2019 1 hour ago, planehazza said: I don't wish to have a go or insult anyone's choices, but this is why I personally cringe whenever I hear people using floor polish as a modelling varnish. It may work for many, but to me, it's meant for floors, not models. Shame it's happened right at the end, but as said above, it gives a good frost effect if were inclined to not fix it It works great on canopies when you have to sand out a seam line, makes the sanding haze completely disappear. Link to comment Share on other sites More sharing options...
thorfinn Posted March 13, 2019 Share Posted March 13, 2019 No disrespect meant to your opinion..to which you are justly entitled...but the matter at hand has nothing to do with it being a 'floor finish.' It's a simple chemical reaction related to outgassing and relative humidity, which can happen with any material, acrylic, enamel or lacquer. They're all just tools. Everyone finds the ones that work best for their own way of doing things. 2 Link to comment Share on other sites More sharing options...
Andre B Posted March 13, 2019 Share Posted March 13, 2019 I used the Humbrol matt varnish rattle can ones on an Spitfire and the paint cracked completely. I don't knew why but to avoid such experiences I nowdays try paints, future and varnish on an scrapkit before painting the real kit... /André Link to comment Share on other sites More sharing options...
