Pete in Lincs 14,750 Posted April 21, 2019 Share Posted April 21, 2019 One of my favourite Aircraft and you're really doing a great job on it. 1 Link to post Share on other sites
franky boy 2,084 Posted April 21, 2019 Share Posted April 21, 2019 Nice work Dennis. Lovely paint job. James Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted April 21, 2019 Author Share Posted April 21, 2019 Thank you to all of you for the likes & the nice comments. Dennis 1 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted April 25, 2019 Author Share Posted April 25, 2019 FAILURE !!! ... I mounted the gear on the UHU tonight. Shes a tail-sitter and there’s nothing to be done to fix it. I placed a bottle-cap on top just behind the cockpit. Filled it to to the point of overflowing. No good still sitting on her butt. So even if i add all that weight it wont help it. Oh well at least she looks pretty. Dennis 1 Link to post Share on other sites
Rob G 3,410 Posted April 25, 2019 Share Posted April 25, 2019 36 minutes ago, Corsairfoxfouruncle said: Shes a tail-sitter Darn. A few options present themselves. First, add a tail support from clear sprue at the rear, it's quick, easy and not too distracting. A variation of the above is a strategically placed trestle/ladder/barrel/crewman. Second, put the bird on a base and tie the nose wheel down, which is a good option if you don't mind bases in your cabinet. You can use wire through a hole or a screw into the nose wheel, as skills and inclination dictate. Third, drill holes in any place that you can find (under the cockpit, behind the cockpit, in the engine cowlings) and add as much fishing weight lead as you need, fixed in place with a dribble of superglue through the holes. You may actually manage to hold the weights in place with screws or pins through the fuselage bottom, but that takes a bit of lining up and luck! Once it balances, make good the panel and paint damage. That's the most difficult option. Don't give up Dennis! 1 1 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted April 25, 2019 Author Share Posted April 25, 2019 15 hours ago, Rob G said: Don't give up Dennis! Not planning to ... But this kits definitely kneed my gentleman's spot more than once. I will most likely do a post of some sort ? Combined with chocks, know what german chocks looked like ? Were they square or triangular ? Like i said i took a water bottle cap and filled it to overflowing with lead. Didn't help a bit, so I'm not going to butcher a good paint job for that. Here is what shes looking like right now. With support and without. Questions, comments, jokes, or good stories ? They are all welcome as usual. Dennis 8 Link to post Share on other sites
Torbjorn 1,934 Posted April 25, 2019 Share Posted April 25, 2019 (edited) Make a base, glue it down? Maybe with a dowel through the nose wheel for extra attachment. edit: oops, already suggested above Edited April 25, 2019 by Torbjorn Link to post Share on other sites
Rob G 3,410 Posted April 25, 2019 Share Posted April 25, 2019 Re the post, you may be able to hide it somewhere just behind the main gear, under the fuselage. It will be less noticeable than under the tail. Chocks visible here, they're skeletal triangles. A packet of small Evergreen angle will do the job nicely, methinks. 2 1 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted April 25, 2019 Author Share Posted April 25, 2019 3 minutes ago, Torbjorn said: Make a base, glue it down? Maybe with a dowel through the nose wheel for extra attachment. That may be an option for the future. Currently all my built kits go into storage, i don't have space to display any of them. In fact I'm probably going to have to donate or recycle the majority of my older builds soon ? There is a local airport with a small museum i will try to donate them there first. They have about 5-6 aircraft including a T-2, T-33, A-4C & at least two Helicopters. Dennis 2 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted April 26, 2019 Author Share Posted April 26, 2019 Satin coat on today, next up is some basic weathering and antennas. 1 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted April 27, 2019 Author Share Posted April 27, 2019 Weatherings done i kept it simple with just the wheel wells and exhaust. Questions, comments, or good stories ? Dennis 9 Link to post Share on other sites
BerndM 3,179 Posted April 27, 2019 Share Posted April 27, 2019 Looks good and pretty close to finish. Wheel chocks of any kind are a good idea and too much weight will weaken the undercarriage. It worked well on my P-400 and i have used simple plastic triangles. 1 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted May 2, 2019 Author Share Posted May 2, 2019 Hello everybody... Slowly but surely this is getting there. Glued the gear doors, exhausts, and some other odds n ends on tonight. Antenna’s next and then i can wrap this one up. Dennis 2 Link to post Share on other sites
trickyrich 16,531 Posted May 4, 2019 Share Posted May 4, 2019 she does look really nice Dennis, you've done a great job on her. I seem to remember it took an awful lot of weight to get her to sit correctly, maybe you are able to pop off one of the cowlings? Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted May 4, 2019 Author Share Posted May 4, 2019 29 minutes ago, trickyrich said: maybe you are able to pop off one of the cowlings? Not the way i glue things. Im just going to finish the build and store it. When i have space in the future to build a small base i will figure out how to display it. Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted May 5, 2019 Author Share Posted May 5, 2019 Hello all... Well this beast just will not go gently into the night. Its fighting me tooth and nail, and it almost won a one way trip to the bin. I think i will be skipping P/E antenna’s on Night-fighters on future builds. These 5 antennas took just over an hour to get all to connect, behave until the glue set, and not feed the carpet monster in the process. I did lose the center one though to the monster, thus the reason its not painted. Luckily i had extras. These two on the belly weren't much easier. The glue just didn't want to set the same problem i had with the nose antenna’s. I use C/A Gel which usually sets in about 45-90 seconds. But on some of the etch it took 5-10 minutes. Does C/A gel go bad ? I know regular C/A can be effected by time. The C/A fingerprint in that last photo has been wet-sanded away for the most part now. Time to go have a Guinness. Dennis 4 Link to post Share on other sites
trickyrich 16,531 Posted May 5, 2019 Share Posted May 5, 2019 hmmm some ow this message below didn't post......here it tis again "you know you could always remove the props, drill out the centres and fill the nacelles with shot or small fishing weights? I've done that before, just stick some plasticine in first to stop the weights from going rogue!" Yeah CA glue does have a mind of it's own, I find it'll happen glue something where it shouldn't be instantly (as with fingers) but stuff you need to dry inlace seems to take forever. I only use Tamiya's Extra Strong stuff, it's strange like that. 1 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted May 10, 2019 Author Share Posted May 10, 2019 Hello all... Well head cold and diabetes crashing sugars not withstanding, i was able to wrap this one up. I have added the photo’s to the gallery. I will also add more photo’s to an RFI. https://www.britmodeller.com/forums/index.php?/topic/235055125-a-luftwaffe-owl/ Questions, comments, jokes, or stories ? Dennis 8 Link to post Share on other sites
trickyrich 16,531 Posted May 11, 2019 Share Posted May 11, 2019 well done Dennis you finally got there and she does look rather nice! Dragon does produce a nice model of the He-219 but you do unfortunately have to work for it. I found the other day my Tamiya 1/48th version I started about 20 years ago, complete with Verlinden upgrade kit. I think you may have inspired me to drag that old beast out and finally finish her. What's that "tarmac" from? it does look rather good for a base for her. It's always a pleasure to have you along Dennis, hopefully the build wasn't too painful, but you managed to produce something nice in the end so again well done. 1 1 Link to post Share on other sites
Corsairfoxfouruncle 23,398 Posted May 11, 2019 Author Share Posted May 11, 2019 14 minutes ago, trickyrich said: I found the other day my Tamiya 1/48th version I started about 20 years ago, complete with Verlinden upgrade kit. I think you may have inspired me to drag that old beast out and finally finish her. Good to know my work may help you decide to build/finish yours. 15 minutes ago, trickyrich said: What's that "tarmac" from? it does look rather good for a base for her. It came with my Hasegawa 1/48 F-8E Crusader, it was actually printed on the inside of the box. I just cut it out and use it to give me a basic base for photo’s. At least until i can get a real base made that can be used multiple times over. 18 minutes ago, trickyrich said: It's always a pleasure to have you along Dennis, hopefully the build wasn't too painful, but you managed to produce something nice in the end so again well done. Thanks I'm sure i will be in more builds... Whats modeling without a little head bashing from frustration once in awhile ? Dennis Link to post Share on other sites
trickyrich 16,531 Posted May 11, 2019 Share Posted May 11, 2019 3 minutes ago, Corsairfoxfouruncle said: Thanks I'm sure i will be in more builds... Whats modeling without a little head bashing from frustration once in awhile ? tell me about it....this Viggen!! 1 Link to post Share on other sites
Greg Law 4,960 Posted May 11, 2019 Share Posted May 11, 2019 It turned out real nice Dennis. I to have the 1/48 Tamiya one. However, I don't see myself getting to it for some time. I have too many projects and too many ideas. This is what I like about the Group build. It inspires me to get something completed. I'm pleased to see you got the front panel of the cockpit painted black. 1 Link to post Share on other sites
CliffB 8,927 Posted May 11, 2019 Share Posted May 11, 2019 You've obviously had a productive few days Dennis, getting a couple of your many builds finished (something I need concentrate on too ). Your Uhu looks very striking and the PE parts do add a lot (so worth your effort IMHO). Cheers Cliff 1 Link to post Share on other sites
Mottlemaster 2,934 Posted May 11, 2019 Share Posted May 11, 2019 Congratulations ,a superb result . 1 Link to post Share on other sites
modelling minion 12,914 Posted May 11, 2019 Share Posted May 11, 2019 Excellent work Dennis. Just read your thread from start to finish an I'm really impressed by your Uhu, I really like the scheme and think you've done a great job on the mottling especially as it's in 1/72 scale. Well done mate. 1 1 Link to post Share on other sites
