18 hours ago, Julien said:
I still have 83 even after selling a few.
Now thats what I call a Sabre enthusiast! Puts my 10 to shame!
Terry
Can't help but tinker with some details.
Scratch cylinders were painted Aluminium, aa 'oil' wash applied and little dry brushing. Now all cemented behind the intakes.
Moulded exhaust stacks removed and apertures made for the exhausts. Moulded venturi removed.
Scrap plastic stuck to the insides, ready to receive exhausts in due course.
Engine cowlings opened-up. (Sorry for the image)
Stuart
Those cylinders are an excellent improvement. Great technique too. One which I will shamelessly plagiarise urm I mean seek inspiration from, undertake further proof of concept tests, and report my findings back to your good self...:winkgrin:
This is looking very interesting - you're making good progress.
I think the Seafox is a really attractive aeroplane - I don't suppose anyone has ever made a 1:48 kit of one? Vac? Resin?
Keep up the good work and I will follow along if I may?
Nick.
Thanks Tomo.
Thanks Nick. AFAIK, nothing in 1/48.
Have been farting about with the crew figures and stuff.
Borrowed from the IWM
I didn't want to use the 'typical' clothing of FAA crew as it is very dark and when 'plonked' into their seats, you wouldn't see them so I looked for an alternative. It just so happens that I stumbled across a recent BM thread about this alternate but can't for the life of me, find it now. After a scan of the WWW and b/w photos, I've came up with this.
...and I came up with a crew member looking like this, my best guess.
More happy fellows all geared-up.
Temporary fitting of crew in their locations.
I was going to knock-up an i/p but experiments with fuselage halves closed and pilot fitted meant that you saw 'diddly squat' so the kit representation of an i'p is staying as-is but I will tackle the observers area though.
Stuart
With the Avon Sabre completed and sitting in the cabinet, it's time to turn my main attention back to the Seafoxes.
Not much but control sticks have been added, as have the headrests that have been 'punched 'out of card. The i/p's are not going to be seen at all, so the i/p faces have been painted black and pilots have been secured in place.
Next stop is to join the fuselage halves.
Stuart
Update...
Fuselage halves joined together and will be left a while to cure. Overall the joins don't look too bad, nothing a little PPP and tlc can't sort out. The observers pit is still to sort out with a few boxes, the gun and the mount .
The kits gun is 'pants' and will be replaced by the Mini World option.
...not much difference eh. The gun mount will need to be scratch built.
Here is the kit's oil cooler and although was well defined for the 80's, is not by today's standards, so a scratch built option will be made.
It has been said that the cooler should sit in that hollow on the top of the fuselage but as yet, I haven't seen anything to confirm this. Matchbox has moulded this as if the whole thing is metal and if this part is removed to leave just the cooler, what should you see instead, top of the engine maybe and I don't want to go there. Do any of you guys know?
Float sides have been glued together except the top centre sections as if this was done, a lot of work would have been needed to get the float decks to fit. A little bit of filler and sanding was required on the top forward/ aft sections. Rudder control lines will be fitted, as will the float tow rings on the nose.
Flaps removed from the top wings. I have made an attempt to reduce the wing ribbing by sanding but not sure if I'm happy with it. I Might remove it all and try that masking/ primer process to get a more realistic ribbing effect. What do you guys think?
Lower wings still to have there flaps removed and lets not forget the bloody ribbing.
I'm pointing at what I believe is the landing light and want to replace it but I'm not 100% as to what it should really look like. Can anybody help?
While I wait for some answers, I have lots to get on with.
Stuart
I don't why how I missed this site, it's full of Sea Foxes!
With this new found source I have found that the oil cooler does indeed sit in a trough. So, measurements were taken from the kit part and a scratch part was made from two different sized vanes sandwiched together, enough for two oil coolers. A coat of metallic paint and a wash should work wonders.
One of the two Seafoxes will be for L4526, and I've noticed that it has an 'extra' engine cowling on each side.
Openings made on both sides.
One of the two vents.
Extra cowl vents fitted.
That 'killed' a few hours this evening.
Stuart
From the same site:
Chris
@dogsbody, yes Chris, lots of good stuff.
Something else that I've have noticed is the assembly in the bottom right hand corner of the above pic, 'rear spar attachment also serves as a catapult spool'. One of these aircraft being built belongs to a catapult squadron but their are no bits in the kit. Something else to add to the list maybe, it might have been a standard fit on all Seafoxes?
Stuart
Looking the business Stuart. All the extra detailing and scratch work is really bringing them to life. Plenty of reference material at hand now. No excuse for missing any of those little vents and further scratch detailing to the nth degree heh heh ;)
Evil child.:wink:
Stuart
Hi Stuart,
This is how I solved the rear gun many years ago.
The brownish light grey is my early attempt on Cerrux Grey - the main reason I was not very happy with the kit in the end.
Edited by Patrik
Time for a little update.
Oil cooler painted up.
MiniWorlds Vickers painted up.
Fairey Hi Speed gun mount built and painted.
The main work is happening on the wings and getting rid of most of the excessive ribbing and looking at possible rigging sequences.
Stuart
A little more done on the Seafoxes.
Lower wings have had their 'solid' landing lights removed. The recess was painted Interior Green with a blob of liquid chrome for the light itself. A suitable piece of clea sprue was shoehorned into place, filed and buffed. These are now ready for rigging holes to be drilled into them.
Main wings have had their struts fitted, One has dried overnight and has had filler added and sanded, the other is still in the cement drying stage. Once I'm happy with the filling and sanding, I'll turn my attention to the rigging holes.
Show for now
Stuart
Very nice double build Stuart. Loving the attention to detail.
Terry
This is fantastic! The Seafox has aged very well all things considered.  It’s only getting better too.  You are doing a brilliant job.
Cheers Terry. We're heading towards the rigging holes scenario and I'm not fond of drilling lots of small holes.
Cheers Putty but in the scale of things, you're FE2b is artizan work.
Stuart
Looking good! The oil cooler is very satisfying. The Miniworld guns are amazing, but my personal problem with them is how you can actually get to enjoy the detail on the finished model without macro photography...
[edit] the land plane version on the deja vu site looks pretty weird. Maybe Seafox number three?? :wicked:
Regards,
Adrian
4 hours ago, AdrianMF said:
Looking good!
Cheers Adrian. I tend to agree with the Miniworld parts but I just couldn't bring myself to use those kit parts, they were just pants.
...er :hmmm:, no.
Stuart
A landplane Seafox! There's something I didn't know about. That would certainly look different: a wheeled Seafox with the observer's canopy removed.
Hmmm....
Inclement weather this afternoon has confined me to the cave, ho-hum.
You may have noticed that this build isn't following any particular pattern, it goes where it goes, so back to the floats.
PE control horns added to the float rudders.
Mooring rings made from brass wire added to the float noses.
Stuart
Everything is now primed, time to move forward.
Attention is now being concentrated on one Seafox until its ready for decals. Here, I thought I'd try a new paint Aluminium paint from MIG and the jury is still out as to whether like it or not. Initially, I had issues from the start as it didn't want to flow, it spat but with a little persuasion, it went on. I thought, it being acrylic, it would dry quickly so I can do the other sides but oh no, I have to leave it, so that's what I'm going to have to do.
Next obviously, will be to do the other sides and let's not forget the floats, then I might have to rig this 'aquatic' Fox.
Stuart
Edited by Courageous
Very nice work sir. Lovely detailing.
On 5/4/2019 at 3:32 PM, Courageous said:
Nice set of ear rings you have there.
