Delayar
1/48 F-16AM RNLAF Demo Jet (Tamiya Conversion)
Hi!
Already finished last November, i only now found time to take pictures.
It is a model of the demo jet of the Royal Netherland Air Force, as it flew in 2013, flown by capt. Stefan "Stitch" Hutten.
The WIP thread is here:
As a basis,  I used the Tamiya Thunderbirds kit. To convert it into an A(M) model, i used the KASL set, which fitted fantastic. Only the tip of the vertical tail had to be made into an A tail, because KASL had a C shaped tip.
Other aftermarket accessoires:
Tamiya detail set (pitot tube, AOA probes, stiffener plates)
Aires exhaust
KT Model Resin Works Smokewinders
Master Models static dischargers
And of course decals from Syhart.
The decals for Capt. Huttens helmet are self made.
I used the piants from Mr. Paint, which are made specifically for this jet. The lighter orange is a two layer paint, the first providing the orange base color, the second adds the metallic sparkle.
to be continued...
I love the execution of this one ..
The paint job is great and the stand you made makes it pop out ....
 cheers, Jan
Beautiful work!
The Perspex rod that the aircraft is mounted on, did you bend it yourself or can you buy them like this! I ask as I want to do much the same with a Starfighter in the near future.
Thanks
James
Hi!
18 minutes ago, franky boy said:
Beautiful work!
Thanks
James
I bent the rod myself. This can be done easily with a heat gun. However, you have to heat it up slowly, turn it round and round, until you can bend it. If you heat it too much, you will get bubbles in the perspex.
Markus
Not much to say other than simply stunning!
Beautiful colors, beautiful model......great work
Regards Djordje
Gorgeous! Always put up a stunning display.
Pete
I was wondering where this build had gone to :)
Stunning result Markus! Really good!
Edited by Avgas
shhpelling
