Puff Baghdaddy's Maritime Striker: 1/72 Dassault Mirage F.1EQ-5
MikeR
I know, bad joke, but it was one of the more amusing nicknames the Western press bestowed upon Saddam Hussein.....
Here's completion number two for the year, Special Hobby's Mirage F.1EQ/ED kit built as the Iraqi Exocet-toting Dark Sea Grey over White EQ-5 option. Paints are Humbrol throughout - 125 over 130 for the main colours. Aftermarket used was a Master turned brass pitot tube with CMK providing the Mk-10 ejector seat, Remora ECM pod and Sycomor decoy pod. Peewit provided the masks for the canopy although I had to raid my leftover Eduard masking sets so I could cover the landing and refueling lights. The Exocet is included in the kit and I suspect it's actually the Eduard Brassin item although Special Hobby don't mention that. Other small alterations have been done using Miguel Garcia's excellent "Iraqi Mirages in Combat" book as reference.
Now for the photos!
You can see that I used the Magic-1 AAMs - the Iraqis never received the -2, so ignore what the instructions say and use the ones without the notch in the tail. Another thing that SH didn't mention is that for the EQ-5 and 6, you don't use resin part 8 (which represents the attachment for aligning the gyroscope from an external device). For the EQ-2 and 4, you do.
The kit includes the intake for the elevator power control unit on the upper starboard rear fuselage - remove if building an EQ-2, otherwise keep for the EQ-4,5 and 6
This shows how deep the Exocet pylon is. The clearance must have been quite tight between the nose gear door and the nose of the missile during retraction and extension!
If you look very closely, you can see that I added a second drainage outlet on the port side behind of the existing one - this is correct for the EQ-4,5 and 6. The EQ-2 only had one per side.
CMK Martin Baker Mk-10:
Remora Pod:
Sycomor Pod:
Comments welcome!
Mike.:)
  • Like 23
