panzerlehr46 Posted February 20, 2019 Share Posted February 20, 2019 Hi guys. Im keen to portray a Postwar Lancaster or.Im going to get the Freightdog ASR lifeboat set.Would the Airfix b.111 kit be suitable for postwar lancasters?,Not the Dambusters kit or mk.2 lancaster kit.The F.e tiger force is hard to find. Many thanks for any advice. Rich. Link to comment Share on other sites More sharing options...
Guest Posted February 20, 2019 Share Posted February 20, 2019 (edited) It should be fine - the Freightdog set has the relevant late Lancaster bits you need - Lincoln rudder and wheels, plus the tropical filters for the engines and the rear fuselage camera fairing. All you need to do is cut the requisite windows in the rear fuselage. Don't rule out the Hasewgawa kit if you can get one cheap, try that instead - it comes with the tropical filters and rear fuselage camera fairing on the sprues anyway, plus the glazing for the later rear fuselage windows is also included. The build is much easier than the Airfix kit but less detailed whilst the outer engines may need some shims to get them to hang correctly. Edited February 20, 2019 by The Wooksta! Link to comment Share on other sites More sharing options...
panzerlehr46 Posted February 20, 2019 Author Share Posted February 20, 2019 Thank you Wooksta for the information.I think i have the Revell kit stashed away in wardrobe if all fails.Will see what i can forage around for. Cheers from Richard Link to comment Share on other sites More sharing options...
71chally Posted February 20, 2019 Share Posted February 20, 2019 Don't forget the large stb'd side fuselage scoop, which I think is missing in the Airfix FE kit. I really like the Hasegawa kit, it does have a slight issue with the upper glazing arrangement from memory, but lovely kit. Link to comment Share on other sites More sharing options...
Mancunian airman Posted February 20, 2019 Share Posted February 20, 2019 I have the Airfix kit in the stash and as far as I am aware it is supposed to be the F.E version suitable for a post-war Lancaster. I dont know precisely when they introduced the Lincoln style rudders as the kit doesnt have them but its a simple fix to add the square at the bottom. It also has the post-war turret which is a bonus over the older Airfix kit. The starboard side heater scope shouldn't be that difficult to replicate. Good luck with the build but do your research as not all converted post-war Lancs had the camera housing beneath the rear turret or the windows opposite the rear door entry. Link to comment Share on other sites More sharing options...
panzerlehr46 Posted February 21, 2019 Author Share Posted February 21, 2019 Thanking you gents for your thoughts and advice.Its much appreciated. Rich. Link to comment Share on other sites More sharing options...
Graham Boak Posted February 21, 2019 Share Posted February 21, 2019 None of the Airfix kits provide the deeper radiators needed for the FE version and many post war examples. However I don't know how many post war aircraft retained the standard radiators, so it is a matter of checking photographs for the particular example you want to make. It is not the most obvious of alterations, but... Link to comment Share on other sites More sharing options...
