ProfSparks
The Gannet, the airbrush, the etch and its' folding tool.
Hi All
On 4/2/2019 at 3:17 PM, CedB said:
Berna clamp problems? I think the jaws might be on the wrong way around… mine have the flat bits on the outside?
Hi Ced, do you mean the yellow rubbery bits on the ends? They are reversible to grip either flat or convex surfaces. The trouble I had was the legs swinging around whilst trying to get them in position, then them gradually weaselling themselves off just as I thought they were in a good spot.
No more of that, thanks to the Miracle Of LEGO!
Anyhoo, the results are in from the Dark Sea Grey mini-experimental sideline.
I must admit it's not what I was expecting, even after watching hours of YouTube tutorials.
There again, I nearly drowned when I was young because I rushed straight into a swimming pool thinking I could swim after watching the Rolf Harris series "Learn To Swim".
So, the contenders are Vallejo Model Air 71.048 Dark Sea Grey and Tamiya XF-54 Dark Sea Grey.
Vallejo tried mixed with about 20% of their Matt Medium 70.540 and a drop of Airbrush Thinners 71.261 to try to get it translucent like I've seen done, but it proved so thick that it wouldn't spray at all, so it was abandoned and just sprayed neat from the bottle with a drop of Thinners.
The Tamiya was diluted about 30% with their X-20A.
Here they are on the Light Grey
And here on the NATO Black / Black
And the Vallejo on both
Not much of a waistline.
So where does that leave me?
Well, the Vallejo is the darker one and closer to the Dark Sea Grey I've seen in the photos of the 1:1 aircraft, so that's the one I'll be using, the Tamiya seems like an ordinary grey.
They both sprayed about the same, oddly slightly thick, though each being drops as opposed to a mist, and yet wet and runny.
It's a mystery, swimming is much easier.
Right, less pontificating about the bush, and on with the build proper.
Comments and suggestions welcome
Steve
Yep, that's what I meant. The inventor has posted here to much, er, reaction. That said, I like them for their 'gentle grip'.
That said they are a bit 'Marmite'.
I like 'em! :)
Hi All
Hi @CedB, the trouble I was having with them was getting them in position in the first place, one hand holds the kit, one hand holds one jaw, and another hand is needed to catch the other jaw swinging around and clamp it snug.
Now I can maneuver them single handedly and I like 'em again too!
Anyhoo, I bit the bullet and over a couple of snatched sessions managed to get a coat of light Sky on all the undersides parts
The props are Tamiya XF-3 Flat Yellow, masked up waiting for some sort of black.
Also got the wheels done
The photos I've seen of her don't show her nose wheels in colour, so I've painted Port Red and Starboard Green for a bit of interest.
I dabbed on some wash that seemed to flow everywhere, need to be more sparing if I'm to use it on the surfaces.
Little steps.
Steve
Good news Steve :)
Looking good in the Sky.
Great work with an undercarriage and wheels, Steve! :like:
The photos I’ve seen shows that you’re done it absolutely right.
Cheers! 😎
Hi All
Quite a mixed bag these past couple of days, involving realisation, frustration, resignation, trepidation, and elation with a liquid almost, but not entirely unlike, Guinness.
First up, I realised that to fit the flaps the fully deployed as I had previously planned, I'd have to alter the wing trailing edge slots for the adapted brackets to fit.
Secondly, I became frustrated at the mess I was making of the also previously applied Sky finish while doing the remedial work (yes I know I should have done the work and sorted out a solution before spraying, but what can I say?). No photos obvs.
Thirdly I became resigned to mounting the flaps retracted to hide the scar tissue, and also as I'd snapped three brackets and lost a fourth to the Carpet Monster.
I've no idea why Revell supply parts to have the flaps half way, there seems to be scant photographic record of them this way in operation.
Anyhoo, it was with great trepidation that I masked off and prepped for spraying the Vallejo Model Air 71.048 Dark Sea Grey
The result?
I'm so happy.
So, so, happy.
Steve
Looks good! 👍
Cheers! 🙃
There's a frood who really knows where his towel is. :D
Looking very cool Steve.
Looking awfully good already, you are right to paint the nose wheels to show port / starboard
I've seen that on almost every Gannet I have looked at
I suspect its to assist the deck crews in unpacking and towing around the ships, there's a long unwieldy hookyclampysteery device that was used to handle Gannets with the big whizzy things spinning about just above their heads
Colour coding the wheels would ensure they were put on the plane quickly, in the right orientation maybe
At any minute now James will pop in, I hope, to tell us the real reason
3 hours ago, perdu said:
hookyclampysteery
I so love a good “Billismdescriptor”
Steve, this is a great narration of a very entertaining build! Neither a subject nor scale that I would necessarily build, but nevertheless I'm hooked*
Alan
Can't beat a good HGTTG reference 👏👏👏
*(sophisticated flight deck related wordplay, yeah?)
The nosewheels had colour coded cover discs because they were different internally.  The port wheel had a clutch mechanism which enable the two wheels to lock together over a certain speed so to reduce shimy on take-off landing etc, but able to disengage for ground handling reasons.  You wouldn't want to mix the wheels up!
Lovely work on your Gannet Steve.  Flaps half way down was take-off, if I remember right the positions were housed, slow handling flight, take-off, and landing.
Hi All
You know what it is, occasionally a blinding flash of "YES! EXCELLENT! WHY WOULD IT BE ANY OTHER WAY!?!" comes along, and it all make sense.
Brilliant, thanks!
And then, to crown it all
Looking with renewed purpose through t'Interweb photos, I can now see the blurred grainy pattern appearing.
I missed them all first time around, @71chally frood and no mistake!
I used to have a bright yellow one of those for the steering wheel on my Fiat 126 as an Anti-Theft Device. One night someone broke in and stole it, left the car.
Anyhoo, time to assemble the motly collection of parts
Tail dry fitted
Wings just as good
Underside has a slight gap
Here's where the Hudson Experiment comes in
A drop of Tamiya XF-21 Sky in with the PPP
Aaand...
Might give them a second application if they niggle me, might not.
So, after a couple of sessions
Flaps and, er... flaps to add to the wings, then let's see what happens.
Steve
Tail dry fitted
Looks perfect, Steve - as the other assembly, too! 👍
Cheers! 😺
Edited by Nikolay Polyakov
Aaand...
😮 Why have I never seen this technique before? Simple but genius.
Alan
Great tip for colouring the PPP Steve - the Prof's science helps us again!
Looking really good and I love the smooth finish :)
Lovely clean work Stephen, good tip with the filler.  However just noticed the belly shots, there is a ruddy great line down the middle on real Gannets to separate the bomb doors
Hi All
Yeah... I know... and there's the split down the join of the two large nose wheel doors too... After reading about the horror fit issues I was going for less filler at the expense of accuracy. However, as I now know it's just down to the internal floor being too wide in the first place, my future self Gannet build will have that seen to.
The final push now with the canopies. They have 'tails' on them to indicate the rails when they are closed, so they came off
The Eduard masks for these are a bit vague, elongated horse-shoe affairs filled in with Maskol
The spinners got some masking love too
And also the aerial post
Removing the nose masking was slightly underwhelming
I've a feeling the forward white stripe starts from behind the blade opening and not the base of the nose cap.
I'll see if I'm still niggled once the blades are in
Hmm...
I'll give it a clean up and dwell on it.
Anyhoo, next up Stickers!
Steve
Hi All
Stickers on!
They've gone on really well and have settled down mostly with an application on Micro Sol.
A couple of areas to note are the lines indicating the step holes up to the front cockpit
They should stop on the perimeter of the step opening, so I'll have to carefully cut them back.
They should be trimmed shorter before putting them on, so now you know.
Also requiring some attention are the teeny little yellow marks to the sliding canopy corners
I'm going to run my sharpest blade round them and hope they don't dissolve.
I don't know if slicing the outside edge off before putting them on would have helped, as that would make them smaller than the very small thing they already are, but it might be worth a try if you have an electron microscope.
Anyhoo, matt varnish next on the list, then cockpit internals and legs on.
Steve
Looking so good. As @Bigdave22014 has already observed, a good dose of EDSG over Sky is just so the way things should be!
Terry
