ProfSparks
The Gannet, the airbrush, the etch and its' folding tool.
Hi All
This was earmarked to be done in the Maritime Patrol and Coastal Command GB, but realistically will outlive it.
I thought it's time I moved on to a more modern kit, so the subject of this session is the regular Revell 1/72 Fairey Gannet AS Mk.1/4
Also upgraded will be this!
Hopefully it will make throwing the paint around that little bit more refined.
More refinements will be
The Airwaves etch says it's for the Revell/Frog Gannet, but turns out to be for the old old (solid cockpit) Frog so I don't know how much of it will be applicable.
I got the Eduard interior PE set to make up the postage on the masks, so that'll be a first time experience.
However, I'm going to begin with this experience, the RB Productions Flip-R10 Folding Tool
Parts writhed from the frames and filed smooth
Yes the instructions look like they're from the 60s with dot-matrix photos, but onward.
Step 1 fold up the 'ears'
Not sitting flat, but that's ok, more later.
Step 2 has you put two of the little round pieces in the ear recesses, and slot in the tabs on part 2
However, this proved quite tricky, so I put the two round pieces on part 2
And slotted them in
Hmm, something not quite right, the ears are bent outwards and the plate is bowed. The instructions aren't much help either
I took one off each end and it seated better, nice and flat
I put the errant pieces on the outside and added a drop of CA to secure them
All that was left was to slot in piece 3 and Robert's your dads' brother
The clips raise the back of the tool so it's level, a nice touch
Anyhoo, with the hardest part of the build out of the way, the rest should be a doddle...
Comments and suggestions welcome
Steve
After that, I assume you will be completing the Gannet wing fold in the next hour...
Looks exciting, Steve! Recently bought a T.5, so I’m in and watching with an interest.
Have a good build here! 👍
Cheers! 🙂
Wow, it looked as though this might be a nice simple build... Well, a mini brake press to fold the PE parts, interesting because, you haven't shown us the kit parts yet. I worked on Gannets on 849 NAS back in 1964/5 so you have me hooked.
Colin
Hi All
Colin
Hi Colin, perhaps you should look away now, the kit parts are on their way...
But first I scanned through the etch diagrams and highlighted the parts that would need adjusting.
As it's an interior Zoom set, most of the parts to alter are in the cockpit.
Putting off losing the tiny metal parts for as long as possible, I turned to the Revell build sequence and was soon off to a flying stop.
The roof of the front wheel well (on my thumb) is to be attached to the roof of the bomb bay (the comb thing on the right) but there is no definitive location
So I got out the fuselage halves to see if there was anything to help there
That's an interesting sprue gate, careful now!
There was a fair amount of flash on some parts
And fitting the bomb bay brought up the first of I suspect many fit issues. That's the rear bulkhead and our old friend the Careful Sprue Gate.
*sigh*
I was going to leave the bay doors closed, but if it's going to be a chew on to get it all lined up, I might as well split them and have them open.
The nose section fits a little better, but not exactly where I thought
The main spar section (of which there are numerous tales of fitting woe) went in no bother once some flash had been moved on
Thso, initial thoughts are that 90% of the tricky build is sorting internal locations, and once the halves are buttoned up it should be fairly plain sailing (or flying)
With this in mind, I may keep each of the internal sections separate and fit them individually.
Steve
This is my kind of build, I'll be watching with interest.
I built this kit a few years back, it was a bit of a challenge, I just couldn't get the fit how I wanted. I got there in the end though. My canopy parts were completely pancaked, they fell victim to Revell's end opening box. To Revell's credit they sent replacements.
It's also an incredible tail sitter. I filled the front of mine with enormous amounts of liquid lead. And it sat on its tail!  I found the same with the Trumpeter AS4 and Sword AEW as well.
Hi All
Thanks DAG058 and 825, I'd read I'd need a small horse in the nose to keep it on its' front leg, and so far the canopies remain unscathed!
As a mater of interest, is RAN XA334 in the walkarounds section prototypical for what I should be aiming for?
If not, are there photos of XA321 on t'interweb?
Steve
Hi All
I only ask because, back in The Lab...
I drilled out the control column and had a look at the supplied pedals
There's etch for the pedals and the centre wheel, so instead of filing them off I just used a scrap piece
First etch, BOOOM!
However, it may have been premature.
I sanded off the cockpit wall detail
It wasn't that special, and Revell supplied a duplicate sprue anyway as an apology.
They required fitting and sanding and fitting to get to fit without pinging orf, made tricky by the glued on column and pedal board.
Anyhoo, all fitting so far, even with Eduard telling you to shave off the locating lugs from the bulkheads
However, as the rear ones' are locating for the side walls, I may wait and see if I can adjust the etch round them
I opened up the holes in part 15
And may be tempted to do a touch of wiring on the backs of the IPs
Steve
Good start, Steve! 👍 It’s nice that you have to dry fit everything before touching the glue and paints. The Eduard’s PE set is a good addition to the Gannet - looks very promising.
Cheers! 🙂
Hi All
As some of the rear of the IP will be visible I drilled out and fitted some wire from a phone charger
While that was setting, I had my first go at bending
Success!
The hardest part was finding it again when it pinged out of the Folding Tool.
I ended up not using the clips, just holding the former down with my finger.
The current crop of internals were given a blast of Vallejo Air 71.251 NATO black from my new airbrush
I'll have to adjust my technique, as this Infinity is a wholly different beast to the weighty, clunky, seal-free copy I've been using so far.
Those seatbelt strap hangers were almost as small as I could see, and couldn't really feel them, but they're on
Continuing with the etch, I put the pieces on the panels
And gave the dials a blob of Kristal Klear
A quick question for those further along the etch line, how do you blend the edge of the part in with the surface it's mounted on, getting rid of the shiny edge?
Steve
Hi All
That's canny stuff!
So I started on the side walls
And as you can see, the rear bulkhead locating tab fouls the etch.
Eduard would have you file the plastic away, but I thought I'd rather have the locating tab, so cut away the etch instead
I doubt anyone will notice once it's all tucked away inside.
The sides completed
The Eduard colour is decidedly on the blue side of dark grey/black, and the glue backing is awkward to remove from the edges as it all just slides around, but it should all be ok with a thin wash.
Parts washed with the same NATO Black thinned, and ready for assembly.
I'll give them another wash with something else once they're all together.
Steve
Oh, Steve! And how do you going to charge it now?! 😂
Superb!
Excellent work with a PE! 👍 I’m not a fan of the pre-painted etch, but looks like you’re get the best from them.
I think the better way is to match or mix the same color and accurate apply the paint on an edge, then spray (it’s a true purism, sounds strange) it with a semi-gloss clear to imitate the «grain» of the original «print» (not necessary action). I have some (all the) colored PE sets for my Voodoos, so I’ll have to try it someday...
Excellent work, Steve! Looking forward for your next updates.
Cheers! 😎
Edited by Nikolay Polyakov
Looking good, that I/p looks rather impressive, looking forward to seeing how the tub looks when all together.
Stuart
Looking good , love that panel wiring .. I knew there was a reason I've kept a stack of PC wiring
On ‎2‎/‎18‎/‎2019 at 12:56 PM, ProfSparks said:
Folding Tool
Did make me laugh , a folding tool that could use a folding tool to make it and if you do it without a folding tool …. Do you actually need a folding tool ?
 Just saying . I looks good though. How much are they ?
Edited by bzn20
Hi All
Well, I don't know if I'll need it until I need it... It was about £20 years ago, and as I was getting a set of £7 Micro Saw Blades and the postage was about £10, it seemed like a good idea at the time.
Anyhoo, Adventures In Fitting PE Part 1
I got the pedals in (without the aid of The Tool) and gave it a wash with Tamiya Panel Line Accent Colour Brown
The rest was dry fitted to check the fit
As you can see, the edge of the PE stands proud of the cockpit tub, so it's off with it and thin down the walls a touch more
Good job it's Self Adhesive and the glue's a bit claggy
Very careful not to wreck the forward section as it fits ok
I've touched up the scratches and whatnot, and as they're drying I fitted the forward rear bulkhead as a datum
I'll leave that to set too, and go and do something else.
Steve
Hi All
After several tries the sidewalls were secured
They look a bit agricultural out in the open, but are ok when enclosed
The gaps along the upper edges where they meet the fuselage will squeeze flush with a drop of CA.
I dot the instrument clusters on, and hey-presto a cockpit!
It's had a thin wash of Tamiya Panel Accent Colour Brown to tie it all together
And should be acceptable once the canopy and centre section covers go on
Back to the rear soon.
Steve
Hi All
And so to the single seat cockpit
Guess what I'm going to have to do here?
Yup, file the kit part right back so the etch sits flush
Even filed right down, the kit part is still proud of the sill
What it needs to be is thus
So basically the top section of the kit side wall needs to come off
With the etch perched over it
The kit sides were glued to the floor, and when set, the etch was placed on and a drop of CA seeped under it
Fits nice and snug now, they'll nip up once the halves are joined
I got the upper panels on after checking they fitted
You'll not see much of them anyway.
You know when you take something apart and put it back together again there's sometimes a little part left over?
I found a place for it, and gave the whole assembly a quick wash with the usual
I've since removed the cotton bud hairs and general detritus.
That's about it as far as the internals go, I'll have to load the nose with some home made scones and close it up next.
I'm probably going to leave the portholes and fill them with Kristal Klear later, and now I'm tempted to open up the bomb bay doors and nose gear and wing flaps too, depending on how the next etch episode goes.
Steve
Nice show on this building. Following
Hi All
A slightly truncated Lab Session today, on account of the Airbrush content of this WIP.
I sprayed the interior with Vallejo Model Air 71.251 NATO Black as the rest of the cockpit, and found it difficult to control as before.
It's not come out too bad, 15psi with the 0.2 setup in my newly acquired 2-in-1
There's more to it, I've just taken it apart to see why it wasn't behaving as the online video would suggest.
I found this is why
There seems to be no lower half on the needle actuator on the trigger assembly, so it was wobbling around in the body and not doing what it should.
New trigger ordered, should be here in a couple of days, but until then it's removing and cleaning up parts for me.
Steve
56 minutes ago, amblypygid said:
That's odd, you'd expect that to be picked up before it left the factory.
Well, it's not exactly factory fresh, came as part of an online auction win that included many 1/72 heavy bombers, 1/32 and 1/24 Spitfires, Mustangs, Mosquitos, a compressor, tools, and enough Tamiya paints to make Josephs' tailor pause and re consider.
Don't know whether to WIP them eBay them, or keep them as a retirement fund :huh:
Steve
