SUB-SAM Posted February 17, 2019 Share Posted February 17, 2019 After finishing the Nieuport I said I would do something other than a ww1 subject. I must truly be stuck on ww1 because I've just started two more. I Fancied the all-white craft of Herman Goering but also really wanted to try some of the lozenge camo. I couldn't decide so I thought why not build two at the same. Not sure which one to do along side Goering's but I can choose that later. First job: The upper wings had considerably too much chord, about 1.5mm which is a huge amount in this scale. So I sanded this off to correct dimensions. Also the wings have recessed rib lines which I of course replaced with stretched sprue, yep every single rib! Once sanded to shape it should look great. 5 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted February 17, 2019 Share Posted February 17, 2019 😳 Taking my seat now. Link to comment Share on other sites More sharing options...
pheonix Posted February 24, 2019 Share Posted February 24, 2019 Which kit are you using or is this a scratch build? Either way I am sitting alongside Corsairfoxfouruncle and will be interested to see these progress. P Link to comment Share on other sites More sharing options...
