Courageous Posted February 16, 2019 Share Posted February 16, 2019 (edited) Hi all. After watching this YouTube video I find myself deficient of a Fighter Bomber Sabre in my growing collection of Sabres in 1/72. Firstly, can anybody tell me where the bomb pylon would be located as I have heard/ read and seen different things. I've read that due to fuel tank plumbing, the bomb pylon is located further outboard but the video shows it located inboard of wing tank? Does anybody have a better image of the bomb pylon? Does a decal sheet exist for Fighter Bomber Unit from Korea, for an F-86 Sabre? Hopefully @Sabrejet, @Tony Edmundson and other helpful fellows will bale me out. Stuart Edited February 16, 2019 by Courageous Link to comment Share on other sites More sharing options...
Sabrejet Posted February 16, 2019 Share Posted February 16, 2019 Bomb pylons, various: fitted on dual-store wings in the inbd/ferry tank location. Here it's fitted with a rocket pylon (with Delmar target gear attached), in between the bomb pylon and the drop tank. And a couple more. The bomb pylon has two sway braces and an aft attachment for towing flag targets. On dual-store wings the drop tank is usually on the outboard pylon and the inner location (if anything is installed) has the bomb pylon or ferry beam installed. It's rare (but not unheard of) to have a drop tank on the inner and nothing located outbd. Outer drop tank pylon is located further outbd than the location on the single-store wing. Pylon locations explained here: 4 1 Link to comment Share on other sites More sharing options...
Tony Edmundson Posted February 16, 2019 Share Posted February 16, 2019 Always wondered why the various F-86F kits have their pylons mounted wider than Sta 99, now I know, it's after serial numbers 51-13170. thanks S.J. 1 Link to comment Share on other sites More sharing options...
Courageous Posted February 16, 2019 Author Share Posted February 16, 2019 4 hours ago, Sabrejet said: Bomb pylons Thanks for sharing Duncan, very useful. From a 1/72 perspective, what would the distance be from centre line to the inboard pylon at Sta 72 and while we're at it, can we confirm the distances to Sta 99 and Sta 118? What about the bomb pylon length? 2 hours ago, Tony Edmundson said: Always wondered why the various F-86F kits have their pylons mounted wider than Sta 99, now I know, it's after serial numbers 51-13170. Would you say that the kits have the mount fitted at Sta 118? Stuart 1 Link to comment Share on other sites More sharing options...
Sabrejet Posted February 16, 2019 Share Posted February 16, 2019 In 1/72 the Buttock Planes are (measured from the aircraft centre line): BP 72 1/4: 25.5mm BP 99 1/2: 35mm BP 118: 41.5mm (figures rounded to nearest 1/10th of an mm) I'd do a kit-by-kit analysis because I suspect some got it right while others didn't. Manufacturers have a nasty habit of re-boxing their 'F-86F; as a 'Sabre 6' without changing anything but the decals. 1 Link to comment Share on other sites More sharing options...
Courageous Posted February 16, 2019 Author Share Posted February 16, 2019 1 hour ago, Sabrejet said: I'd do a kit-by-kit analysis Armed with these figures, I definitely will. Stuart Link to comment Share on other sites More sharing options...
Tony Edmundson Posted February 18, 2019 Share Posted February 18, 2019 the only kits that have the pylons at 99.5 seem to be the kits of the F-86D Tony 2 Link to comment Share on other sites More sharing options...
Sabrejet Posted February 20, 2019 Share Posted February 20, 2019 On 18/02/2019 at 06:01, Tony Edmundson said: the only kits that have the pylons at 99.5 seem to be the kits of the F-86D Tony Model plagiarism then... 1 Link to comment Share on other sites More sharing options...
72modeler Posted February 20, 2019 Share Posted February 20, 2019 Stuart, See if these photos help. Good luck! (Miss Teena was my Dad's C.O.'s Sabre!) Mike https://www.google.com/search?q=F-86F+walter+Benz&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj2iK7WqcvgAhVLi1QKHTbXD-MQ_AUIDigB&biw=1280&bih=654#imgrc=T91jZICEEta_6M:&spf=1550700579043 https://www.google.com/search?q=F-86F+8th+FBG&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj6rMG5qsvgAhWnsVQKHb5dA7kQ_AUIDigB&biw=1280&bih=654#imgrc=LsCsQtyELuJx5M:&spf=1550700769065 1 2 Link to comment Share on other sites More sharing options...
Courageous Posted February 21, 2019 Author Share Posted February 21, 2019 Might have this Print Scale decal sheet '72-079' #7 & #8 are my options ...then I need to get myself some WW2 US 500lb bombs or a single 1000lb job...nothing in the spares box. Stuart Link to comment Share on other sites More sharing options...
72modeler Posted February 21, 2019 Share Posted February 21, 2019 (edited) Stuart, My choice would be Col. Benz's mount, for obvious reasons, but be careful, as the Sabre pictured on the Printscale sheet is not correct, FU-427 was not a 6-3 wing F-86F-30 Sabre, but was an F-86F-10/15, I think. I have attached a link to a neat website that has the history of the 8th, great Korean war coverage, and a photo of his Sabre, FU-427 that clearly shows it was a slatted-wing, normal span F-86F at the time the photo was taken. It could have had the 6-3 wing factory modification kit fitted at some point, so I guess you could go either way if you choose his mount- I guess it depends upon how easy it is for you (probably a snap with your modeling skills!) to make a slatted wing Sabre out of a kit that has the 6-3 wing. My dad's C.O. Woodrow Wilmot, took over command of the 8th at war's end, and his Sabre was definitely an F-86F-30 with the 6-3 wing- I know this 'cause I sat in it! I'm hoping to do Col. Benz's 'Dirty Old Man,' as it's a slatted-wing Sabre, and then do Woody's 'Miss Teena,' as she is a 6-3 wing F-86F-30 Sabre. Hope you and the others enjoy the site! Mike http://yocumusa.com/sweetrose//sabrepilots/sabrejetclassics/sjc131.pdf Edited February 22, 2019 by 72modeler corrected spelling 1 Link to comment Share on other sites More sharing options...
