Douglas CC-129
My build for this GB will be a Douglas CC-129.
CC-129 was the designation given by the Royal Canadian Air Force.   The kit is from Airfix, the Dakota Mk.IV boxing.   Decals are from Xtradecal sheet X72207, representing CC-129 No 927, which is now preserved and on display in the Alberta Aviation Museum.
Let's look at the sprues.
Look at all that wonderful Airfixy goodness!  :wub:
  • 1 month later...
Apart from the decals, this is a straight OOB build.
The cockpit area has a number of bulkheads with some nice detailing - very little of which will be seen when the fuselage is closed up. One of the partions on the starboard side was distinctly curced. I thought thos was intentional as it looked to match the fuselage curvature.  Sadly, it wasn't.  I think the parts had bent when they were cooling.  It's not a problem thugh.  A bit of cyano and careful clamping meant that the partion took up the right position.
The floor was sprayed with a dark grey colour picked at random and then weathered with Flory Models grime wash.  The interior was sprayed with Xtracrylix XA1117 Interior green.
The seat assemblies were sprayed olive drab - again picked at random - simply to give a little bit of variety to the interior.   The windows are designed to be fitted towards the end of the build.  I have a recurring nightmare of getting that sort of thing wrong and the window falling into the interior...  😨  So I took the opportunity to fit them now.
Here comes the bit I was dreading - assembling the fuselage!  I built the airfix new mould Lancaster a few years ago and that was a nightmare. The fuselage was just so long and flimsy that it was a total pain to assemble.  More recently I built the Airfix 1/48 Meteor, which was similar.  I was expecting similar from this kit.
It never happened!  :phew:
The fuselage halves went together very nicely, especially considering the amount of interior detail which could have messed up the fit.
I masked the door appertures with lots of tissue paper and sealed them with masking tape and blutak.  I covered the transparencies to stop them getting damaged while I cleaned up the seams.
Having completed the cleanup, I masked the side windows.
