fjaweijfopi4j48 Posted February 12, 2019 Share Posted February 12, 2019 A model from 9 years ago: Today I will post two more models made from vacuformed kits of a very simple nature, as the subject seems to have picked up the interest of some of you. The one below is simple but generally correct, while the other (a Fokker Universal from VLE) is a kit that leaves a bit to be desired. The Abrams Explorer was a functional and elegant plane specifically designed for photographic survey. It first flew in 1937 being its performance, engineering and configuration notable for the time. It went through o change of power plant (from Wright R-975E to Wright R-975E-3, roughly 100 more hp) that implied the subsequent addition of short struts and increased vertical surface area. Execuform presents a vacuformed 1/72 kit in the simple lines that characterize its offers. You get the main parts plus the transparencies and a plan with the type technical description. It will take a bit of work, but again, it is highly unlikely that you will get an Abrams Explorer from the mainstream manufacturers, n’est pas? This kit reminded me of early times of my life....I was flooded by memories of the Modeling Monastery, with its walls of styrene reportedly scratchbuilt by the original monks in the foggy beginnings of modeling history. In those cloisters the monks were trained in the heavenly arts of vacuforming, the hard disciplines of puttying and sanding and the mysteries of airbrushing. Its underground vaults stuffed with building materials and arcane tools, its dungeons choked-full of the sanding dust produced by generations upon generations of monks. But I digress.... For the kit you have to provide engine, wheels, prop, decals and cater for the interior bits. I decided to replace the stabilizer instead of spending time sanding it down, but it is a matter of personal choice. Once the parts are removed you are left with a backing sheet of large area, from where you can get material for your scratched parts for this and future projects. The smaller shapes are the front wheel fairing (two parts) the air scoops on the side of the aft fuselage (two parts) a fairing on top of the aft fuselage (one part) and a part to make the carb intake (goes at the bottom of the cowling that surrounds the engine, see Execuform’s plan). If you follow the images they will give you an idea of the construction process. Wing halves and other twin parts like wheel pants and tail booms were glued at this stage; once these parts were dry and sanded, the control surfaces’ separation lines were engraved. None of the model’s flying surfaces have the ribbing that the real plane had. You may consider representing the ribbing with your method of choice, subtly on the wings and a tad more prominent on the tail surfaces. For the wing have in mind that the ribbing is seen on the aft two thirds of the chord, on the exterior panels, excluding the flaps. I decided to represent the fabric-covered parts with a different shade of paint. At this point it is of great help to start thinking about the building sequence. A decision was made to glue the booms to the wing taking care of their alignment (their bottoms don’t spoil the surface under the wing, only the top) and then later cut the portion of the wing shadowed by the fuselage. The wings will at a later stage be joined to the fuselage via a spar and the insertion of the tailplane will close the structural circuit. The mating of the transparent part of the fuselage with the opaque one also deserves some thought. The transparencies are on the thin side, which is good for clarity, and not so good for sanding and gluing. The parts will cover only the nose, so you have to cut two side windows and insert a clear strip there –see images-. Later you could glue the opaque fuselage sides –may be with an aft-closing bulkhead and some interior- then saw the nose off. Some details that are located in the nose could be added before gluing the frontal transparent parts. Those are separated vertically in the mold, which is ok since a metal strip runs there on the original plane. Decal strips would be used to depict the canopy frames. Caution here because there are some curved ones at the doors. As per photos control lead fairings and skids were added to the booms, while a “pan” was envisioned for the cockpit details later to be inserted, as said, before closing everything up with the transparent front part of the fuselage. A camera was also scratched and its port holes drilled on the fuselage bottom. The instrument panel in the original plane was small and attached to the roof. The roof of the canopy was tinted, probably in a green hue, to provide for some sun screening. Precautions are necessary to avoid a tail-sitter. I placed a bit of lead inside the wings’ leading edges. I found dealing with the provided front transparencies somewhat challenging and a tad frustrating; I “adjusted” them too much, and had to buy a replacement set from Execuform. As said, those transparencies are thin, so you don’t have much edge where to glue, and matching the halves with the thickness of stiff paper is not a pleasant task. And at the same time you have to match the cross section at the front of the sawn-off fuselage. Once the transparencies were adjusted to size I tried different glues on scrap pieces. Tenax, Model Master liquid cement and Plastruct Plastic Weld didn’t work well, so I Futurized them and glued them with cyanoacrylate. My suspicions that the frontal area of the model would consume most of the building time proved right. Retrospectively thinking, I think that to build the wing, booms and tail as a unit and then cut a niche in the fuselage to accommodate it is a better prospect. Even more retrospectively thinking I shouldn’t be building models at all. Furthermore, I shall be in an intergalactic ship in a discovery voyage through the universe, where no modeler has gone before. In any case the subassemblies (plane, front wheel housing and annular cowl) were primed and then a coat of black enamel was sprayed on in preparation for the aluminum finish. Venturi and Pitot probes were made and set aside, together with the home-made decals and navigation lights (for the later a step-by-step process is depicted in the accompanying images). I ended up adapting a stunning resin engine from Khee-Kha Art Products to be able to finish the model. There are enough images on the Net to have a very good idea of the real plane and detail it if so you wish. Just beware that the window panes are not symmetrically laid on both sides. My thanks go, once more, to (the late) Jim Schubert who provided input on the project. 19 Link to comment Share on other sites More sharing options...
occa Posted February 12, 2019 Share Posted February 12, 2019 So interesting and obscure, just how I like them 1 Link to comment Share on other sites More sharing options...
Baldy Posted February 12, 2019 Share Posted February 12, 2019 Another stunner Moa and I can see how the transparencies would be tricky to say the least. They say nothing is new and this aircraft concept reappeared in the 80's with the Optica which I saw at many an airshow as it was pushed as a cheaper than a helicopter observation platform. Wonder if there is a kit of that for you to build as a comparison? Cheers Malcolm 1 Link to comment Share on other sites More sharing options...
JWM Posted February 12, 2019 Share Posted February 12, 2019 Very nice and learnfull! Recalls me De Schelde 21 (https://en.wikipedia.org/wiki/De_Schelde_S.21) Cheers J-W 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted February 12, 2019 Author Share Posted February 12, 2019 42 minutes ago, Baldy said: Another stunner Moa and I can see how the transparencies would be tricky to say the least. They say nothing is new and this aircraft concept reappeared in the 80's with the Optica which I saw at many an airshow as it was pushed as a cheaper than a helicopter observation platform. Wonder if there is a kit of that for you to build as a comparison? Cheers Malcolm There is indeed an Optica kit, but I am afraid is a little bit too modern for me. Cheers 1 Link to comment Share on other sites More sharing options...
Jonners Posted February 12, 2019 Share Posted February 12, 2019 So, ‘Flight of the Phoenix’ meets Sikorsky S-51... Yet another fascinating background story to an obscure type. Love it. Jon 1 Link to comment Share on other sites More sharing options...
pheonix Posted February 12, 2019 Share Posted February 12, 2019 I too am reminded of the Fragonfly with that nose transapancy and the Optica with the enclosed engine. (I used to see the latter on test flights from Old Sarum airfield just outside Salisbury in the 1980's). I do like aircraft with booms and other oddities - something attractive about the slightly more complex construction. Super model again. P 1 Link to comment Share on other sites More sharing options...
Baldy Posted February 12, 2019 Share Posted February 12, 2019 3 hours ago, Moa said: There is indeed an Optica kit, but I am afraid is a little bit too modern for me. Cheers LOL! I thought so! 1 Link to comment Share on other sites More sharing options...
Dennis_C Posted February 13, 2019 Share Posted February 13, 2019 (edited) Fun model indeed. I can only applaud to those brave who are able to glue two piece of vacform transparencies together Anyway nice to see another twin-boomer I did not knew before. Edited February 13, 2019 by Dennis_C 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted February 13, 2019 Author Share Posted February 13, 2019 2 minutes ago, Dennis_C said: Fun model indeed. I can only applaud to those brave who are able to glue two piece of vacform transparencies together Anyway nice to see another twin-boomer I did not knew before. I rarely remember anything about old builds, after 300+ of them, but i do remember trying to put those two paper-thin halves together, at the same time, aligned along all the gluing edge. Brrrr! 1 Link to comment Share on other sites More sharing options...
