Colin W Posted February 11, 2019 Share Posted February 11, 2019 Hi Chaps. The 50s NATO GB contribution is almost finished so this is on cue. I bought 5 Airfix Hawks when they were released about 15 years ago. I've built 2 and here are the last 3. The last one I built was for the Britmodeller 2011 training GB! How time flies. Time might not allow me to make all 3 but I'm going to be attempting 2. One will be in a Dragon scheme as my daughter's at university in Wales and the other probably a TWU wrap around. Colin W 7 Link to comment Share on other sites More sharing options...
exdraken Posted February 11, 2019 Share Posted February 11, 2019 Nice choice(s)! 2 Link to comment Share on other sites More sharing options...
Col. Posted February 11, 2019 Share Posted February 11, 2019 Not one Hawk but two of them? Excellent Top choices of colour-schemes and marking as well 1 Link to comment Share on other sites More sharing options...
RJ-WobblyHands Posted February 13, 2019 Share Posted February 13, 2019 First we have Tigers in the Valley , now Dragons in Valley this will be fun , I will be watching this one 1 Link to comment Share on other sites More sharing options...
mackem01 Posted February 14, 2019 Share Posted February 14, 2019 PHEW! I was going to do one of those Dragon-Hawks. I'm sure you'll do a much better job. 1 Link to comment Share on other sites More sharing options...
Colin W Posted February 18, 2019 Author Share Posted February 18, 2019 Well I've made a start on the Hawks, starting with the cockpit. Tubs and fuselage assembled and painted med sea grey. Seats in dark sea grey and rear instrument cover in 137 rubber. I did the 6 seats so I can choose the best 4 or build the 3rd hawk. Colin 3 Link to comment Share on other sites More sharing options...
Colin W Posted February 25, 2019 Author Share Posted February 25, 2019 Made some progress on this build over the weekend. Seats were done during the week but now with the Tubs installed in the fuselage. Rear instrument panel assembledin the coaming. Fuselage assembly next. Meanwhile I started on the wings. One will be flaps up with the other down. Both were sanded on the inner face to thin the trailing edge. Flaps up was straight forward. For the other I cut out the flaps before joining the halves. I glued some strip to the upper surface before joining the halves. This has allowed a sharper edge and filled the gap between the two. I'm finding working on the pair to be quite efficient. Colin 4 Link to comment Share on other sites More sharing options...
Colin W Posted February 26, 2019 Author Share Posted February 26, 2019 Ripping along now. Fuselage halves assembled and the resin rear deck added. Flaps finished and ready for installation. I'll do the intakes next as they were a bit of a challenge on my last build. Colin 2 Link to comment Share on other sites More sharing options...
Colin W Posted February 28, 2019 Author Share Posted February 28, 2019 A little bit of progress this week. Intakes added and gaps filled. These seem to be an issue for all Hawk kits and I don't see why. I Have filled in the gaps in both wings and flaps so ready to either fit the wings or add flap actuators next. Colin 3 Link to comment Share on other sites More sharing options...
Col. Posted March 2, 2019 Share Posted March 2, 2019 You look to be making great progress with both of your Hawk kits Colin 1 Link to comment Share on other sites More sharing options...
Colin W Posted March 3, 2019 Author Share Posted March 3, 2019 Cheers Col Looking like a near miss for the Red Arrows, I decided to put the wings on and start looking more Hawk like. It took quite a lot of adjustment to see the gaps closed so hopefully not much filler needed. Colin 2 Link to comment Share on other sites More sharing options...
Colin W Posted March 4, 2019 Author Share Posted March 4, 2019 Wow it's been quite a busy weekend on here. I found my post at the bottom of page 2 after 24 hours. I've done most of the cockpit work with the exception of the seats. The flaps have been a bit tricky. I spent ages working on the flaps to get them looking close to the real thing. My hawks are early boxings and all the numbers for the flap actuators on the instructions are jumbled up which didn't help. Once I got that sorted the problem became the centre spoiler which always sat too low. Finally I fitted it above the main flap then cut away the upper wing until it was in the correct position. This also means that it's ok from the bottom. Now I know why few Airfix Hawks are seen with the flaps down. Colin 3 Link to comment Share on other sites More sharing options...
CliffB Posted March 4, 2019 Share Posted March 4, 2019 It's definitely been worth the effort with those flaps Colin. Top marks! 1 Link to comment Share on other sites More sharing options...
Colin W Posted March 4, 2019 Author Share Posted March 4, 2019 Cheers Cliff, It's interesting to see how often Hawks have their flaps down on the ground. Usually jets have them up nowadays. Colin Link to comment Share on other sites More sharing options...
Col. Posted March 7, 2019 Share Posted March 7, 2019 Both look to be coming on well for you Colin so that hard work is clearly paying off 1 Link to comment Share on other sites More sharing options...
exdraken Posted March 8, 2019 Share Posted March 8, 2019 looking good!! 1 Link to comment Share on other sites More sharing options...
Colin W Posted March 10, 2019 Author Share Posted March 10, 2019 A bit more progress now. Undercarriage bays done in light aircraft grey, canopies and wing fences fitted then a primer of Mr Surfacer to check the finish. I found some air bubbles in the resin so these had to be drilled out and filled, otherwise ok. Colin 3 Link to comment Share on other sites More sharing options...
Colin W Posted March 12, 2019 Author Share Posted March 12, 2019 Well I've gone from grey and white to black and grey. Wrap around green next for #2. For the black I used the new Tamiya lacquer. It's given me a really good gloss. The DSG is normal gloss, flat by comparison. Wing fences are fitted and air bubbles filled. Nav lights added sanded and masked. Black hawks are pretty smart! Colin 5 Link to comment Share on other sites More sharing options...
Colin W Posted March 14, 2019 Author Share Posted March 14, 2019 I'm looking for something different to fix to the TWU Hawk. These are rocket pods from Academy's Hunter. Are they the same for the Hawk? It seems reasonable but they're quite big. Colin Link to comment Share on other sites More sharing options...
Col. Posted March 15, 2019 Share Posted March 15, 2019 At first I thought they looked far too big but I'll offer up this image and let you decide... https://goo.gl/images/k7VPpa 1 Link to comment Share on other sites More sharing options...
Colin W Posted March 17, 2019 Author Share Posted March 17, 2019 Thanks Col That's a good link back to Britmodeller. I have an Airfix Canberra in the stash so I'll see if I can recover the 18 shot SNEB from that to see how they compare. Colin 1 Link to comment Share on other sites More sharing options...
Colin W Posted March 17, 2019 Author Share Posted March 17, 2019 Another busy weekend for the Hawks. Too many imperfections in the black gloss lead to a sand and repaint. The grey needed a touch up before masking and application of the green. Main undercarriage units applied and masking removed from the wheel bays. I have 2 sets of aftermarket wheels in white metal. 1 set won't fit due to the brake drums being cast onto the legs and the other set arn't even round. I've been trying to recover something but have now decided to use the kit ones. Colin 4 Link to comment Share on other sites More sharing options...
Colin W Posted March 22, 2019 Author Share Posted March 22, 2019 Started decaling the models this week. The first Dragon was the hardest but the second went on much better. The TWU Hawk scheme is more typical so no problems there. Nose wheels and undercarriage over the weekend by the look of it. Colin 7 Link to comment Share on other sites More sharing options...
zebra Posted March 22, 2019 Share Posted March 22, 2019 Looking good Colin. Dragon decal looks like it’s gone on nicely and that Tamiya black lacquer looks great - I might have to try that. 1 Link to comment Share on other sites More sharing options...
Col. Posted March 23, 2019 Share Posted March 23, 2019 Both looking great there Colin 1 Link to comment Share on other sites More sharing options...
