canberra kid Posted March 2, 2019 Share Posted March 2, 2019 Thanks. I would definitely give it a woft over with some primer to see if there are any areas that require a second pass with the filler. John 1 Link to comment Share on other sites More sharing options...
Timmas Posted March 2, 2019 Share Posted March 2, 2019 (edited) Crikey, page 2 already and I've only just cottoned on. I'd like to tag along if I may? I have a recently-acquired Canberra in my stash (1/72 scale...not a bigg'un like this) and I'm interested to see how your's comes out. Edited March 2, 2019 by Timmas typo fix 2 Link to comment Share on other sites More sharing options...
72modeler Posted March 2, 2019 Share Posted March 2, 2019 On 2/13/2019 at 8:01 AM, Mikey-1980 said: Found some great colour footage again of the RAAF @canberra kid John, What is that black panel seen in the video beginning at 1:20? It's under the port wing inboard of the engine nacelle. Some sort of antenna or sensor? Never noticed it before. Mike Link to comment Share on other sites More sharing options...
canberra kid Posted March 2, 2019 Share Posted March 2, 2019 1 minute ago, 72modeler said: @canberra kid John, What is that black panel seen in the video beginning at 1:20? It's under the port wing inboard of the engine nacelle. Some sort of antenna or sensor? Never noticed it before. Mike Hi Mike Yes it's the doppler aerial they can have one two or non, dependig on Mk. and date. John 2 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 3, 2019 Author Share Posted March 3, 2019 I think that's about as good as I can get the join lines around the cockpit. I sprayed primer and it didn't look too bad. The primer came out a bit thick though so I wiped it off so it doesn't ruin the lines that are meant to be there! I'm not sure whether to give this a wash over with dark dirt wash after painting, these Canberras look quite clean in most photos. Maybe just on the light grey undersides. 4 Link to comment Share on other sites More sharing options...
Mikey-1980 Posted March 4, 2019 Share Posted March 4, 2019 (edited) Done a decent job there! A lot better than my effort Edited March 4, 2019 by Mikey-1980 1 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 4, 2019 Author Share Posted March 4, 2019 1 hour ago, Mikey-1980 said: Dona decent job there! A lot better than my effort Not sure about that, I'm reserving judgement until it's painted! 😂 Did you leave the tiny windows in the nose until the end? Seems better to paint first then glue them in and attach the nose cone, but with all the nose weight stuffed in there it's become a tight squeeze. Link to comment Share on other sites More sharing options...
Mikey-1980 Posted March 4, 2019 Share Posted March 4, 2019 they attached from the inside so I glued them in and then masked them over.....infact I totally forgot about them until you just mentioned them.....need to pull off the maksing tape haha! 1 Link to comment Share on other sites More sharing options...
Mikey-1980 Posted March 4, 2019 Share Posted March 4, 2019 haha, errrrr dropped a bollock........there are 2 decals on the sheet I sent to you that I actually need......the small black registration number XH165 that go on the front landing gear... Oops.......will have to go with out them.....*face palm 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 4, 2019 Author Share Posted March 4, 2019 29 minutes ago, Mikey-1980 said: haha, errrrr dropped a bollock........there are 2 decals on the sheet I sent to you that I actually need......the small black registration number XH165 that go on the front landing gear... Oops.......will have to go with out them.....*face palm If you send me your address I'll send those back to you, no probs! 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 4, 2019 Author Share Posted March 4, 2019 The instructions say to use the smooth upper ailerons, but the kit includes a set with bumps that match the bumps on the wing. Which is correct? 2 Link to comment Share on other sites More sharing options...
canberra kid Posted March 4, 2019 Share Posted March 4, 2019 You are correct, it's the ones with the other part of the power controls failings John 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 4, 2019 Author Share Posted March 4, 2019 Damn. Is it true if you leave glued parts in the freezer you can pull them apart? Should have asked before gluing! 😕 Link to comment Share on other sites More sharing options...
canberra kid Posted March 4, 2019 Share Posted March 4, 2019 2 minutes ago, Lord Riot said: Damn. Is it true if you leave glued parts in the freezer you can pull them apart? Should have asked before gluing! 😕 The law of sod! If it screws up I have spares in stock if you need them, it's the ones with the lumps you need to use. John 1 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 5, 2019 Author Share Posted March 5, 2019 14 hours ago, canberra kid said: The law of sod! If it screws up I have spares in stock if you need them, it's the ones with the lumps you need to use. John Yes please John, that would be fantastic, thank you! I can't unglue mine, the freezer technique didn't work. I'll pm you. It's just the standard ailerons I need, without the bumps. Thanks! Link to comment Share on other sites More sharing options...
Lord Riot Posted March 11, 2019 Author Share Posted March 11, 2019 A bit more progress this afternoon; the fuselage was a bit narrow at the bottom, I think very slightly bowed in, so I stuck a couple of sprue pieces in there to make the camera bay fit properly. Seems a pretty smooth fit now: 4 Link to comment Share on other sites More sharing options...
canberra kid Posted March 11, 2019 Share Posted March 11, 2019 Looking good, more good progress, if the post works ok you should have the spears soon. John 1 1 Link to comment Share on other sites More sharing options...
Graham T Posted March 11, 2019 Share Posted March 11, 2019 On 3/1/2019 at 7:16 PM, canberra kid said: It is hard work to get it to fit, I've not succeeded yet to get a 'good' fit when I get around to my definitive PR.9 build I'll try to nail it. JESUS MY EYES!!!!!!!!:) 1 Link to comment Share on other sites More sharing options...
canberra kid Posted March 11, 2019 Share Posted March 11, 2019 I think that's what most of Belfast were saying for a while! 😎 John 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 12, 2019 Author Share Posted March 12, 2019 I still wasn't happy with the fit of the cockpit fairing area, so used a bit for filler then Clearfix, sanding it smooth after. I'll give it a light spray later to see if that's finally resolved the join line issue. 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 15, 2019 Author Share Posted March 15, 2019 Starting to look more like a Canberra now. I believe the wings have no dihedral and are completely straight. They'll need a tiny bit of filler along the top of the roots though. 3 Link to comment Share on other sites More sharing options...
Mikey-1980 Posted March 15, 2019 Share Posted March 15, 2019 Coming along beautifully thee David! You've got the cockpit looking great too! how much weight are you packing into the nose section now? 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 15, 2019 Author Share Posted March 15, 2019 Thanks Mike! Feels like I've been sanding and filling that cockpit area for weeks! 😂 I bet there'll still be joins! I've got about 90g in the nose so far, I'm planning to pack in a few more in the nosecone as well, so hopefully it'll stand up properly. I'll just stuff in as much as I can. 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 16, 2019 Author Share Posted March 16, 2019 The gaps at the wing roots were very narrow but definitely noticeable for the whole width of the wings. Link to comment Share on other sites More sharing options...
Lord Riot Posted March 16, 2019 Author Share Posted March 16, 2019 Hopefully that's sorted it. Filled, sanded and buffed smooth ... 2 Link to comment Share on other sites More sharing options...
