Karlj72 Posted February 11, 2019 Share Posted February 11, 2019 (edited) Having ordered the new Border models Panzer IV G I then found the Dragon kit at a good price and thought I will do a side by side comparison on both kits. Will be looking forward to building both kits and figuring out what kit will be the best. The only thing that I might be scratching my head at is the use of what gun barrels to install as both kits come with L/43 and L/48. Edited February 11, 2019 by Karlj72 Link to comment Share on other sites More sharing options...
JackG Posted February 11, 2019 Share Posted February 11, 2019 (edited) Your comparison/findings should be interesting to see. The only negative comment I've seen about the new Border kit was no Filzbalgfilter option is provided. This was the air filter canister found on the right hand side of the hull, and would be present on some of the late ausf.G marks. According to references, depending on the factory, these were added as early as July 1943, but ceased and also ordered removed, in February of 1944. regards, Jack Edited February 11, 2019 by JackG Link to comment Share on other sites More sharing options...
Karlj72 Posted February 11, 2019 Author Share Posted February 11, 2019 55 minutes ago, JackG said: Your comparison/findings should be interesting to see. The only negative comment I've seen about the new Border kit was no Filzbalgfilter option is provided. This was the air filter canister found on the right hand side of the hull, and would be present on some of the late ausf.G marks. According to references, depending on the factory, these were added as early as July 1943, but ceased and also ordered removed, in February of 1944. regards, Jack Thanks Jack I plan on doing both kits for Kursk so the Filzbalgfilter should not be a problem. Link to comment Share on other sites More sharing options...
