Mitsubishi A5M4-K Claude
zegeye
Ok, I have started today. I prepared some literature....
But believe or not... there is almost nothing about two seat version. So I decided not to scratch to much.
This is definitely not Tamiya kit. But it isn't very bad.
And this is result of the first evening of my work.
Edited by zegeye
Nice progress. Yes there is indeed not much information on the trainer version.
The small parts in this kit are not well defined, similar to the stuff in the Kora kit I intend to build. I wonder if you are not better off just using the fuselage and use a plastic kit for the rest.
Cheers, Peter
OK. The end with caresses. Now the real modeling is started....  The two halves of main body doasn't fit perfectly...  I had to fill some gaps...  And I started cutting off some engine cover parts.... Although it is tricky... the first one gone without problems
Nothing special here... and nothing that I wouldn't expected 😄  I have to use a lot of putty to fill some resine distortion on the bottom of mainframe.
And the engine cover seems to be good enough. And it fits very well.
The Claude does indeed start to look like an airplane! Looks like a lot of hard work went into this build to get it to that stage.
I like to use super glue with some talcum powder mixed in as a filler. This works specially well on resin kit and it is much easier to scribe panel lines into than into putty as it has a similar hardness than the plastic and you can control it - more talcum powder max it softer, less makes it harder.
Cheers, Peter
