JOCKNEY Posted February 8, 2019 Posted February 8, 2019 This is my Hawker Henley, I originally started a Formaplane Vacform version, then was gifted the Magna Resin one instead, this is the ideal chance to build it. Good luck everyone ! cheers Pat 10
Col. Posted February 8, 2019 Posted February 8, 2019 I had a dream about one of these things last night! Except it was in Royal Navy Pacific Fleet colours and had folded wings That'll teach me to lay off the cheese before bed-time. 5
JOCKNEY Posted February 9, 2019 Author Posted February 9, 2019 13 hours ago, Col. said: I had a dream about one of these things last night! Except it was in Royal Navy Pacific Fleet colours and had folded wings That'll teach me to lay off the cheese before bed-time. Well Col, you will have to put it down to Group Build Hypnosis, looks like others share your taste in nighttime cheese ! http://beyondthesprues.com/Forum/index.php?topic=312.0 Cheers Pat 1
Col. Posted February 9, 2019 Posted February 9, 2019 4 minutes ago, JOCKNEY said: http://beyondthesprues.com/Forum/index.php?topic=312.0 That second one, with the two tone blue scheme...
JOCKNEY Posted February 9, 2019 Author Posted February 9, 2019 1 hour ago, Col. said: That second one, with the two tone blue scheme... That would be the influence of the blue cheese I imagine Yes yes I know... 1
JOCKNEY Posted February 9, 2019 Author Posted February 9, 2019 I think if it was me I would like the rope to be a bit longer ! photo from Wikipedia 6
JOCKNEY Posted February 10, 2019 Author Posted February 10, 2019 10 hours ago, zegeye said: Ugh... That's wan't be easy build. Hi zegeye, I don't think I've ever been lucky enough to find an easy build ! Thanks for breaking the bad news to me so gently, if you have wrestled with a Magna kit before, any tips would be really appreciated cheers Pat
Avereda Posted February 16, 2019 Posted February 16, 2019 On 2/10/2019 at 9:34 AM, JOCKNEY said: Thanks for breaking the bad news to me so gently, if you have wrestled with a Magna kit before, any tips would be really appreciated @zegeye likewise
JOCKNEY Posted March 3, 2019 Author Posted March 3, 2019 Apologies everyone, I have been fighting a Condor in the Maritime GB, so my trainers have all been neglected. I have done a bit of painting to some of the parts, so will trying to get my finger out and post some pictures. cheers Pat
rossm Posted March 24, 2019 Posted March 24, 2019 On 2/10/2019 at 9:34 AM, JOCKNEY said: Hi zegeye, I don't think I've ever been lucky enough to find an easy build ! Thanks for breaking the bad news to me so gently, if you have wrestled with a Magna kit before, any tips would be really appreciated cheers Pat The main thing I found was that the cockpit floor and consoles etc needed a lot of narrowing to allow the fuselage halves to close. Other than that it's not a bad kit. I also used a lot of drilling and plastic rod inserts to help align wing and tail surfaces but other methods like jigs will also work. 1
Seahawk Posted May 6, 2019 Posted May 6, 2019 I've seen a beautifully made one on the Magna stand a couple of decades back. And I've got the main airframe components together without undue difficulty. Where it has stalled for me (about a decade ago) is cutting out and masking that canopy (which has probably since yellowed anyway). That really is the stuff of blue-cheese nightmares! Another one of those aircraft one hopes the likes of Special Hobby might bring out one day: it's at least as deserving a subject as the Bermuda. 2
rossm Posted May 6, 2019 Posted May 6, 2019 (edited) 1 hour ago, Seahawk said: Where it has stalled for me (about a decade ago) is cutting out and masking that canopy (which has probably since yellowed anyway). The masking is where mine stalled and, yes, the canopy has now yellowed ☹️ Edited May 6, 2019 by rossm 1
JOCKNEY Posted May 12, 2019 Author Posted May 12, 2019 Progress at last Got a bit carried away with the red and yellow paint Not sure how much if anything I'm going to see when the canopy goes on Just in case you didn't know, it's a Magna kit, it's carved into one of the parts ! Much swearing and clamping later the fuselage is closed up, apart from all the gaps Finally, the front is going to take a lot of work ! The finish date for this GB seems to be racing towards us, going to be a bit of a struggle to finish ! cheers Pat 2
Grandboof Posted May 12, 2019 Posted May 12, 2019 Best of luck Pat only a little swearing ? Martin H 1
JOCKNEY Posted May 12, 2019 Author Posted May 12, 2019 2 hours ago, Grandboof said: Best of luck Pat only a little swearing ? Martin H Had to stop for breath every so often. 2
AdrianMF Posted May 12, 2019 Posted May 12, 2019 Gosh that makes a Pegasus kit look easy by comparison. Mind you, the Henley is a fine looking aeroplane, once you find it somewhere in that lump of resin. Looking forward to more. Regards, Adrian 2 1
JOCKNEY Posted May 13, 2019 Author Posted May 13, 2019 Work continues, currently excavating what appears to be the main wheels from a block of resin, this is more like an archeological dig that building a kit. The blob to the right of the recovered wheel is actually a part not part of the scrap resin ! After much filing scraping and cursing I have attached the wings and tailplane. Its starting to look like the pictures at last. I'm glad I took the time with the parts to keep the filling down to a minimum. I need to find my blu-tak and a new blade to extract the canopy later, I have to be careful as I have promised the "spare" one to someone with a stalled build. more later cheers Pat 4
rossm Posted May 13, 2019 Posted May 13, 2019 Coming on well Pat, sure mine had white metal wheels though. 1
JOCKNEY Posted May 13, 2019 Author Posted May 13, 2019 56 minutes ago, rossm said: Coming on well Pat, sure mine had white metal wheels though. Trust you to go for the posh version PM me your address so I can post the long overdue spare canopy, (then the Jockney clan can have a place to stay when we next come down to Cornwall ! ) Kidding about the invasion ! cheers Pat
JOCKNEY Posted May 14, 2019 Author Posted May 14, 2019 This is the winch prop which as you can see is going to take some time this is the canopy being removed from the rest of the vacform backing. There must have been dirt / grit in the blutac as I have ended up with some scratches on the inside, can you use Klear on vacform plastic ? Finally after 2 steps forward we have 1 step back... This is what happened when your Henley falls off the coffee table and hits a tiled floor ! I shall try to recover my sense of humour tonight and continue the build A very Grumpy Pat ! 4
rossm Posted May 14, 2019 Posted May 14, 2019 16 minutes ago, JOCKNEY said: Finally after 2 steps forward we have 1 step back... This is what happened when your Henley falls off the coffee table and hits a tiled floor ! I shall try to recover my sense of humour tonight and continue the build A very Grumpy Pat ! Oh no! 😢 At least it looks like the joints came apart rather than pieces shattering into tiny fragments. I prescribe generous quantities of amber liquid from your favourite Glen or island 😉 It won't fix the damage but it will help you be more philosophical about it. 1 1
stevehnz Posted May 14, 2019 Posted May 14, 2019 3 hours ago, JOCKNEY said: can you use Klear on vacform plastic ? Yes Pat, no problem. There was I thinking how good this was looking when I saw the results of your mishap, buggeration! How about trying 5 minute epoxy rather than superglue, a less brittle join should result. Steve. 1
dude_gan_ainm Posted May 14, 2019 Posted May 14, 2019 Jeez Pat,this Hawker Henley is like a Marlin.She puts up a good fight but keep in there & you'll land the beauty. No problem using Klear on vacform canopies Pat,best of luck. Jimbob. .. 1
