exdraken Posted April 4, 2019 Author Share Posted April 4, 2019 6 hours ago, Aardvark said: This clause in the 1974 Regulations remained unchanged from the 1955 Regulations . Regulations of 1955 only in scanned copies in Russian: http://scalemodels.ru/modules/forum/img_718832_1342849455_rrrsr-srsrsrsr-srjossrrr-2.jpg.html 🤗 B.R. Serge Thanks Serge! My " problem" is that I am doong an aircraft pre 1955! And that I do not have a photo.... But thanjs for confirming my basic thoughts! Link to comment Share on other sites More sharing options...
exdraken Posted April 4, 2019 Author Share Posted April 4, 2019 (edited) Just decided, it will 38 RED Next question.... Red Stars on 6 or 8 positions? Thanks! Edited April 4, 2019 by exdraken 1 Link to comment Share on other sites More sharing options...
exdraken Posted April 5, 2019 Author Share Posted April 5, 2019 6 it is for the time being.... these are Trumpeter decals as stars...a bit on the light side? or is board number dark? cheers, Werner 2 Link to comment Share on other sites More sharing options...
Aardvark Posted April 5, 2019 Share Posted April 5, 2019 18 hours ago, exdraken said: Next question.... Red Stars on 6 or 8 positions? "The main identification mark of the Air Force "five-pointed star" was applied to the wings from the bottom and from above (red enamel A-13 or nitro-enamel red) and from both sides on the vertical tail. Until 1955, the "star" was also deposited on the sides of the rear fuselage.Along the outer contour, the star was bordered with white (A-11 enamel or AP nitro enamel white) or aluminum (AP al nitro enamel), and then red stripes. "Star" when applied to the aircraft should have the largest possible size, but not exceed the established standard sizes" (See size table by link.) "The “star” was applied on the wing in such a way that the distance from its center to the end of the wing was 0.1–0.15 span, and from the leading edge of the wing to the top of the “star” - within 50-150 mm. With its lower ends, the “star” (without edging) should not have gone beyond the boundary between the wing and the aileron. On the ailerons allowed to put only edging "stars". On the vertical fin, the star was located in the center of the fin area below the stabilizer. The ends of the "star" should have been located away from the edges of the fin and rudder at a distance of 50-150 mm." If 1952 year then "Red Star" in 8 position! But (!!!!!!) : 18 hours ago, exdraken said: Just decided, it will 38 RED For 1952 as written E.Arsentev : "The side numbers were additional identifying marks and were applied on both sides of the nose of the fuselage. The planes initially had three-digit numbers (less often four-digit ones, as a rule, Plant No. 153), and with the approval in 1955 of a new order on Air Force insignia, two-digit ones (less often three-digit ones). The numbers on all airplanes that are part of this aviation unit began to be plotted from number 01 and up to the list number of planes in the part and were painted in one color — red, blue or yellow, and were edged with a black stripe 10-15 mm wide. The color was established by the orders of the commanders of aviation connections (the commanders of aviation schools and schools) and determined which part of the aircraft belonged to, and the sequence number determined the belonging to the aviation unit. The figures had to fit into a conditional rectangle, the upper and lower borders of which were separated from the bypass of the lower and upper parts of the fuselage by 100-250 mm. The width of the figures was 2/3 of their height, and the thickness of the lines that make up the figure is 1/6 of their height. The typical sizes of the figures were established by the “Regulations of the Air Force Identification Marks”: 400, 600, 900, 1200 and 1500 mm." Resources on Russian with photo & size table: https://arsenal-info.ru/b/book/1198779448/29 So, Werner If You MiG-15 before 1955, then - "Red Star" in 8 position & 3 or 4 digital number. If You MiG-15 1955 and after, then - "Red Star" in 6 position & 2 or 3 (rare) digital number. By regulations Air Forse it turns out. 🤗 B.R. Serge P.S. Strange but La-9/11, MiG-9 & Yak-15/17/23 have 2 digital number before 1955....probably between regulations 1943 year & regulations 1955 year was unknown regulations? 🤔 1 Link to comment Share on other sites More sharing options...
exdraken Posted April 5, 2019 Author Share Posted April 5, 2019 31 minutes ago, Aardvark said: So, Werner If You MiG-15 before 1955, then - "Red Star" in 8 position & 3 or 4 digital number. If You MiG-15 1955 and after, then - "Red Star" in 6 position & 2 or 3 (rare) digital number. By regulations Air Forse it turns out. 🤗 B.R. Serge P.S. Strange but La-9/11, MiG-9 & Yak-15/17/23 have 2 digital number before 1955....probably between regulations 1943 year & regulations 1955 year was unknown regulations? 🤔 Hmmm... thanks!! Then these photo is either not from Austria, rules were not adheared or.... Still a lot of research necessary... I have seen photos of 3 digit MiG-15s... but always wondered id they were photoshopped! Link to comment Share on other sites More sharing options...
Aardvark Posted April 5, 2019 Share Posted April 5, 2019 (edited) 59 minutes ago, exdraken said: Hmmm... thanks!! Then these photo is either not from Austria, rules were not adheared or.... I also thought about this photo. This photo MiG-15UTI probably could have been taken in 1955, ( not in 1953) when new regulations during! See, no "Red Star" on fuselage, only fin, then "Red Star" in 6 position - it's new regulations 1955 year and in 1955 Soviet Air force was in Austria! MiG-15UTI was not only trainer, it's was also liaison aircraft, for the delivery of various important dispatches, reports or a V.I.P. As a version, someone could fly in with the inspection to check how the withdrawal of the Soviet military from Austria proceeds? About P-39. It's old, 2 WW style digital number. And don't forget: 1 hour ago, Aardvark said: Strange but La-9/11, MiG-9 & Yak-15/17/23 have 2 digital number before 1955....probably between regulations 1943 year & regulations 1955 year was unknown regulations? 🤔 The Soviet airforce marking and camouflage from 1945 to 1955 is very mysterious. According to the 1943 regulations, all airplanes, including the IL attack aircraft, should be gray ... but what then is this: Why green not grey? Mystery.... B.R. Serge P.S. About You MiG-15bis. You can not alter anything in the model and just redo the title: "MiG-15bis Soviet Airforce 59th Air Army in Austria 1955 1/48" 😉😎 Edited April 5, 2019 by Aardvark 2 1 Link to comment Share on other sites More sharing options...
exdraken Posted April 5, 2019 Author Share Posted April 5, 2019 (edited) 5 hours ago, Aardvark said: I also thought about this photo. This photo MiG-15UTI probably could have been taken in 1955, ( not in 1953) when new regulations during! See, no "Red Star" on fuselage, only fin, then "Red Star" in 6 position - it's new regulations 1955 year and in 1955 Soviet Air force was in Austria! And don't forget: The Soviet airforce marking and camouflage from 1945 to 1955 is very mysterious. According to the 1943 regulations, all airplanes, including the IL attack aircraft, should be gray ... but what then is this: B.R. Serge P.S. About You MiG-15bis. You can not alter anything in the model and just redo the title: "MiG-15bis Soviet Airforce 59th Air Army in Austria 1955 1/48" 😉😎 hmmm 1955 that would be an option indeed.... then are you sure that before the stars were on 8 positions? I have just red that the 2 stars on the fuselage were replace with 2 wing top mounted ones in 1955 regulation.... https://web.ipmsusa3.org/sites/default/files/reviews/famous-russian-aircraft-mikoyan-mig-17/specialty_fra_mig-17_page_31.jpg and http://www.tinfeathers.com/Museum/Airports/Forney/Forney.htm no idea if these colors are original of course..... on this Museum MiG-17 very very mysterious indeed Cheers, Werner Edited April 5, 2019 by exdraken Link to comment Share on other sites More sharing options...
Aardvark Posted April 7, 2019 Share Posted April 7, 2019 On 4/6/2019 at 12:50 AM, exdraken said: then are you sure that before the stars were on 8 positions? The military and after the war period until the introduction of the Regulations of 1955 is a very difficult period, so 100% confidence in anything can only give high-quality color photos from above, below and on both sides, but this is from the category of unscientific fiction!😁To believe or not to believe the official Regulations and the Order is not a confirmed photo is a private matter for everyone. As examples. This from officials Order about identification of IL-2 4 Air Army in early 1945: Thus, at the beginning of 1945, attack aircraft were respectively painted 332 ShAD, 199 ShAD, 196 ShAD, 233 ShAD, 230 ShAD, 260 ShAD. Resources: https://igor-valchuk-01.livejournal.com/1957.html But photo IL-2 with this element identification my unknown.Does it mean that we should not trust this order if there is no photo? Here everyone decides for himself. The same with the stars in the 8-position. About "stars in the 8-position" quote from book E.Arsentev & L.Krylov "Fighter MiG-15" - Armada #10. E.Arsentev He is considered the main expert on MiG, which is not surprising because he works in the MiG design bureau, in my opinion he is even the director of the museum MiG. Strange, but in his book I did not find a photo of the MiG-15 with a red star on top of the wing, despite the fact that he wrote about it in his book. Well, I will ask him what he was guided by when he wrote, I quote literally: ""five-pointed star" was applied to the wings from the bottom and from above" 🤗 On 4/6/2019 at 12:50 AM, exdraken said: and http://www.tinfeathers.com/Museum/Airports/Forney/Forney.htm no idea if these colors are original of course..... In my subjective opinion, this coloring is doubtful in terms of the original belonging to the USSR Air Force of the 1950-60s. Need to look at the stencil on this aircraft, if they are preserved then can talk about the original color, if not - sorry. B.R. Serge 1 Link to comment Share on other sites More sharing options...
exdraken Posted April 7, 2019 Author Share Posted April 7, 2019 thanks again Serge! will keep my eyes open for a photo for the time being I will put 1955 to be on the safe side! 6 Link to comment Share on other sites More sharing options...
John Masters Posted April 14, 2019 Share Posted April 14, 2019 Looking very good! Link to comment Share on other sites More sharing options...
exdraken Posted April 24, 2019 Author Share Posted April 24, 2019 closing in on to the final straight line a bit of gray planel line whash and some brown oil dirt on top: looks good on the aluminium 1 Link to comment Share on other sites More sharing options...
exdraken Posted April 24, 2019 Author Share Posted April 24, 2019 and now cleaned a bit : 2 Link to comment Share on other sites More sharing options...
helios16v Posted April 24, 2019 Share Posted April 24, 2019 Nice! 🍻 1 Link to comment Share on other sites More sharing options...
Col. Posted April 24, 2019 Share Posted April 24, 2019 Just the right level of dirt and wear to get the correct effect Werner Link to comment Share on other sites More sharing options...
exdraken Posted April 26, 2019 Author Share Posted April 26, 2019 (edited) some late updates: on cannon bay, seat, canopy etc: Edited April 26, 2019 by exdraken 3 Link to comment Share on other sites More sharing options...
CliffB Posted April 26, 2019 Share Posted April 26, 2019 I've just seen the photos in the Gallery - what a nice MiG Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted April 26, 2019 Share Posted April 26, 2019 Very much agree with Cliff ... Great looking Mig. Link to comment Share on other sites More sharing options...
modelling minion Posted April 26, 2019 Share Posted April 26, 2019 I'll add my name to the list of people who like your Mig-15, well done Werner she looks great. Link to comment Share on other sites More sharing options...
Col. Posted April 26, 2019 Share Posted April 26, 2019 Good work Werner Link to comment Share on other sites More sharing options...
exdraken Posted April 27, 2019 Author Share Posted April 27, 2019 some more photos, I just updated the gallery with better one and one with its GB brother F-84G Thunderjet - Yugoslavian Air Force cheers everybody! 3 Link to comment Share on other sites More sharing options...
John Masters Posted May 5, 2019 Share Posted May 5, 2019 Very nice! Just checked out the gallery too...sweet Mig. Link to comment Share on other sites More sharing options...
Peter Lloyd Posted May 7, 2019 Share Posted May 7, 2019 Top work there, thanks for a great thread. Link to comment Share on other sites More sharing options...
