stevej60
Italeri C-47.70 Stormo Italy 1963.
Hi folk's,Second build goes against everything I should avoid namely Silver and Gloss white finishes! I love Italian roundel's on an aircraft
and the scheme should look great if I ever get it finished.Same boxing as my other entry here's the proposed scheme.
20190208_112322
Nice choice Steve and you're so right about Italian roundels :coolio:
Lovely choice!
Mind you, just needs a bit of dayglo to round off the "don't-go'there" list of paint finishes! 😄
Nice choice, interesting to see an Italian C-47 without that strange lamp unit on the nose as seen here, or for that matter, as Spad says, liberal amounts of dayglo!
Hi folk's,a start made on the two build's interior assembled, this build will have the cargo door's closed as you can see they are a good fit
no filler needed a base coat of interior green applied.
20190210_191206
20190210_204234
Hi folk's,same script as the other build gotten way too ahead so I'll give it a rest  for a couple of week's and finish a couple of camera project's.
20190213_113254
caution:
I do not think that the aircraft you are reproducing, of the 70th Wing, had the big left hatch, rather the normal access door ...... I suggest you consult the photos of the real aircraft.
10 hours ago, Vincenzo64 said:
caution:
Thank's Vincenzo,I think you are correct the few photos of Italian c-47's show no cargo door only artwork on a couple of site's show aircraft
with the cargo door's,I'll fill it in and re-scribe.
Some do have the cargo door. Found this when I built mine for Radial Engines Rock GB
2019-02-18_06-29-54
20171031_150200
Thank's John,would you believe I was just about to post an update,filled and sanded then rescribed the area today,I'm going to paint the fuselage
and wing's before assembly on this one,I ditched the interior aft of the cockpit so I can get the windows in from the inside had a dry run should be OK.
20190218_180459
Thanks for this suggestion, may come in hand when I start my delayed  build.
Hi folk's had to do a fair bit of sanding especially on the fuselage top surface with that white finish in mind,now done,rescribed and as you can
see nicely primed.
20190227_122219
Morning folk's,first hurdle over with three coat's appliance white.
20190301_110228
Hi folk's this one going well,sprayed the lower fuselage and fitted wing's after adding the glazing.Now masked up for primer then silver
on the wing's etc.
20190301_192302
12 hours ago, janneman36 said:
What kind of silver paint are you using?
Hi Janneman,Tamiya rattle can silver over their gray primer,it spray's well and gives a good polished look but can be toned down easily for a
worn finish.
DSC01122
10 hours ago, colin said:
Is that Tamiya AS-12 Steve
My apologies Colin,it's Humbrol 11!
Hi Folk's this one's moving again after removing the masking waiting for the inevitable disaster I was pleased to see all was well with the silver
finish,so masked the nose for painting.
20190311_123556
Hi folk's,the build of the two  I thought would be the most trouble seem's to be running the smoothest,the white of the decal's have no density thankfully
with two build's of the kit I have been able to double up on the roundel's the fuselage roundel even has a third white disc included,just busy spraying the
tailplanes outside before work.Again I've used the wrong intake's but with the silver finish I'm not going to risk cutting them off so they will stay.Wheel's
fitted as you can see.
20190315_105726
Edited by stevej60
new photo
Good afternoon Steve
Very good job she looks great with the decals on  👍
Patrice
Looks awesome Steve!
great idea ditching the interior aft of the cockpit to get at the windows from the inside 💡
Edited by Dansk
